Old 08-16-2005, 03:12 PM   #1
ChadCapece's Avatar
Default cycling while deadshorting?
How do ya'll cycle deadshorted 3300's? Is it just tray down to 5.4v after the race, then equalize, then deadshort, then just unsolder right before the next race weekend.
ChadCapece is offline   Reply With Quote
Old 08-16-2005, 04:14 PM   #2
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Thats the system i use. I've also found it best to take off the deadshort about a day before running the packs.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 08-16-2005, 04:26 PM   #3
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
My way is:
1) discharge to 5.4 volts
2) tray down to 0
3) short for a minimum 3 days
4) unshort and tray again for 5 minutes before charging.
I also use the packs twice as the 2nd cycle is the bomb.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 08-16-2005, 06:48 PM   #4
jeepnyy's Avatar
After the 1st run....what discharge tray do use? Do you completely discharge them with 30/35 amps then tray them before the 2nd run ? Coz' thats what I do. I was wondering what others do.
jeepnyy is offline   Reply With Quote
Old 08-16-2005, 08:58 PM   #5
racer-oZ's Avatar
danjoy, how far do you discharge after the first run before recharging the pack for the 2nd run?
racer-oZ is offline   Reply With Quote
Old 08-16-2005, 09:05 PM   #6
danjoy25's Avatar
This is a quote for Danny/SMC re IB3800:
"As long as the packs cool down for a couple of hours they can be used again in the sameday. When using them more than once per day place them in a discharge tray in between runs. Only deadshort when storing the packs after your race day"
Old 08-17-2005, 06:31 PM   #7
racer-oZ's Avatar
cool thanks... sounds like you are discharging each cell down to .9 volts between each run then. I will try the 2nd run idea and see how it goes
cycling batteries pecrichard Electric Off-Road 5 02-07-2008 10:15 AM
cycling batteries pecrichard Electric On-Road 0 02-05-2008 12:22 PM
cycling? Mitchell Rookie Zone 9 05-06-2007 04:32 AM
Deadshorting Battery Packs... Tpg racer Electric On-Road 7 01-23-2007 12:29 AM
