Old 04-30-2014, 07:35 AM   #1
Default Suspension Spring Question... I have been searching forever
I will be the first to say it.. I hate it when people don't search, however I just can't find any answer that suits my question best.
I am looking for a spring set for my TRF shocks. I would like to have some different spring rates so I can better match conditions. I will be racing asphalt this summer and will be running the Tamiya TCS race in July. I would prefer Tamiya parts so i can use them in the TCS race. Any help would be greatly appreciated.
legacyruss is offline   Reply With Quote
Old 04-30-2014, 07:43 AM   #2
Tower Hobbies has spring sets from Tamiya.
Goals Achieved....Running at the End and Not Dead Last.
mooby64 is offline   Reply With Quote
Old 04-30-2014, 07:55 AM   #3
Yeah I just don't know which ones would be appropriate. I don't know if I buy the short springs etc.... and then do i really need a full selection of rates or are there some that would be better than others. I see they sell springs in pairs etc...
Old 04-30-2014, 08:50 AM   #4
niznai's Avatar
Just buy a set of hard/medium/soft and adjust rate by preload. There's more adjustment in preload than there is in the entire range of springs. That's the idea behind them selling in such sets anyway.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-30-2014, 09:16 AM   #5
moparSRT's Avatar
preload changes your ride height ...
moparSRT is offline   Reply With Quote
Old 04-30-2014, 09:19 AM   #6
moparSRT's Avatar
You will find a lot of GOOD info here : http://www.reflexracing.net/RSD-Univ...art_ep_58.html
springs in the 14lb range are a good place to start with
Old 04-30-2014, 11:01 AM   #7
niznai's Avatar
True.
Team Greasy Weasel
Old 04-30-2014, 01:56 PM   #8
sosidge's Avatar
Most Tamiya touring car setups are based on the "Hard On-Road Tuned springs" #53440. You'll also see people using single-colour versions of the springs that have been limited edition parts at various times over the years but they are the same rates.
If you are running a Mini then people use the Short springs.
If you don't have to run Tamiya parts most people now run HPI or Yokomo springs on the TRF shocks (with the large diameter retainers), these have a much finer difference between rates.
Old 04-30-2014, 04:11 PM   #9
Trader Rating: 17 (100%+)
Not if you lower it back down with the droop screws HA!
T.O.P Racing USA
"This T-bird will put a spell on you"
Mr.A Morris is offline   Reply With Quote
Old 04-30-2014, 04:18 PM   #10
moparSRT's Avatar
good luck with that setup
Old 04-30-2014, 06:31 PM   #11
samnelso's Avatar
And has no affect on spring rate with linear springs...
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 04-30-2014, 06:52 PM   #12
moparSRT's Avatar
yep
Old 05-03-2014, 04:16 PM   #13
No change on Spring rate as long as changing the ride height with preload does not compress the spring any more than when you start. IF it further compresses the spring, you in effect change the spring rate too because you would need a higher spring rate spring of the original length to get the same stiffness as the compressed spring. Same with linear or progressive springs.
John Wallace2 is offline   Reply With Quote
