Old 04-27-2014, 03:20 PM   #1
Default What about a real brake?
Would the excitement and realism of racing benefit from a real (mechanical) brake?
I would think something like what is used on nitro cars, although I am open to ideas. In real racing (full sized) cars you drive as deep as possible into a corner, then stand on the brakes. Think how much more exciting racing would be with the excitement of late braking and trying not to lock up the brakes.
Has anybody tried this on an electric car? I realize it would not comply with IFMAR/ROAR/whatever rules.
Lipo?
Brushless??
I'm still running Sanyo NiCds with a mechanical speed control.
FrostyDude is offline   Reply With Quote
Old 04-27-2014, 03:36 PM   #2
ThePanda's Avatar
Trader Rating: 65 (100%+)
whats the point? the motor gives you essentially the same thing, and is more consistent when set up correctly. the only reason i see this as a benefit is that it would remove some of the strain from the motor and be able to change brake bias.
ThePanda is offline   Reply With Quote
Old 04-27-2014, 03:43 PM   #3
You can't be serious. The motor barely slows you down compared to a mechanical brake. Have you done or even seen any full sized racing???
It's all about the braking. Whoever can brake deeper and later is going to be able to pass into the corner.
Lipo?
Brushless??
Old 04-27-2014, 03:46 PM   #4
it would be nice to have front brakes on my f1 car. might make it brake better and not step out going into corners. then i could have more braking. instead of the miniscule amount of brakes i have now.
dragonracing is offline   Reply With Quote
Old 04-27-2014, 03:49 PM   #5
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I can set the brakes on my sedan to lock up on carpet and asphalt. I don't see an advantage.
Old 04-27-2014, 03:53 PM   #6
You don't think that the braking from the motor lacks the feel and modulation of a mechanical brake? I think the braking from the motor feels more like an on/off switch than a real brake.
Lipo?
Brushless??
Old 04-27-2014, 04:19 PM   #7
i would agree. the motor does feel like an on/off switch. i had a 1/5 car for a while and i really liked the mechanical brakes it had. the felt linear unlike electric motor braking. much more smooth than electric.
Old 04-27-2014, 04:20 PM   #8
By the way, I have spent most of my time racing electric, and it is what I prefer. However, the thing I miss about racing nitro is the brakes. Much heavier nitro cars are able to stop better than electrics because they have real brakes.
Lipo?
Brushless??
Old 04-27-2014, 04:21 PM   #9
Exactly, you have way more control with mechanical brakes.
Lipo?
Brushless??
Old 04-27-2014, 04:34 PM   #10
vabroom's Avatar
Then it's settle! Now all you have to do is figure out where to put the brake servo and where mount the brake discs. If you have a mill and a lathe it should be easy for you.
I forgot which manufacturer made a mechanical brake for 1/8 ebuggy. Some like it but it didn't catch on.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 04-27-2014, 04:56 PM   #11
IndyRC_Racer's Avatar
Why not integrate a mechanical brake into the motor itself?
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 04-27-2014, 05:03 PM   #12
Loved the brakes of a nitro TC.
My current ESC the delay time for braking is inconsistent which makes the car hard to drive, I now use a little drag brake to help. My previous ESC the brake delay was consistent but slightly longer and a lot easier to drive.
I think the ESC brakes are the only lacking area of the current technology.
I would hope this could be fixed with better software.
Due to the corner speed a lot of tracks require very little braking.
More power, lower corner speed equals more brakes.
frozenpod is offline   Reply With Quote
Old 04-27-2014, 05:12 PM   #13
asc6000's Avatar
Trader Rating: 15 (100%+)
Nitro cars do not have "real" brakes. "Real" brakes imo would be one on each wheel. The only advantage that nitro 4wd cars have is it brakes the front drivetrain as well as the rear. They do make brakes that go on each wheel and they work just like real brakes.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 04-27-2014, 07:10 PM   #14
I completely agree with you. However I think it would be tough to implement 4 little brake discs with four tiny calipers to go on the wheels.
Lipo?
Brushless??
Old 04-27-2014, 07:16 PM   #15
I have actually been thinking about taking something like a Nitro TC3 or a Nitro RS4 and replacing the engine with a brushless motor. Then use a 3 or 4 channel radio and use the radio to mix the channels of the speed control and brake servo.
I am going to have to do some research about that brake for 1/8 scale electric buggies that you mentioned.
Lipo?
Brushless??
