Old 04-23-2014, 05:34 PM   #1
Default How do I increase camber?
I'm new to rc and I think anyone can see it from this post but I'm wanting to increase the camber on my rc car but I don't know what to get to increase camber more than what it already is...
What part can I buy that'll increase camber?
Thanks!
Dabubaschmuck is offline   Reply With Quote
Old 04-23-2014, 05:41 PM   #2
Bubblehead's Avatar
Which car do you have?
Bubblehead is offline   Reply With Quote
Old 04-23-2014, 05:49 PM   #3
Not too sure, it was my brothers... I know it's a 1/10, but it's a cheaper car, Exceed might be the brand? Sorry, I don't know too much about it
Old 04-23-2014, 05:50 PM   #4
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Positive camber is increasing camber. You probably want to decrease camber to -0.5 through -2.0 degrees. You need a turnbuckle wrench and a camber gauge. A camber block can also be used instead of a gauge.
If it has fixed camber then you need to buy turnbuckles and and ends. Camber helps increase or decrease traction while cornering.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 04-23-2014, 05:54 PM   #5
asc6000's Avatar
Trader Rating: 15 (100%+)
post a pic of it
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 04-23-2014, 06:12 PM   #6
Trader Rating: 27 (100%+)
Usually in rc when someone says 'increase camber' they actually mean 'get more negative camber'
You don't want to run positive camber, ever.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 04-23-2014, 07:16 PM   #7
IndyRC_Racer's Avatar
Originally Posted by hyujmn View Post
...You don't want to run positive camber, ever.
...Unless you are running oval.
In response to the OP (original poster), I would suggest downloading the Xray T3 setup book here - (http://www.teamxray.com/teamxray/sho...p?file_id=6143)
The Xray T3 setup book does a very good job of explaining what all the different adjustments are/do on an R/C car. Even if your car is a different brand or model, it should be very helpful to understand how an R/C works/is built.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 04-23-2014, 07:22 PM   #8
Originally Posted by F. Mendoza View Post
Positive camber is increasing camber. You probably want to decrease camber to -1.5 through -2.0 degrees. You need a turnbuckle wrench and a camber gauge. A camber block can also be used instead of a gauge.
Well I already cambered my wheels but I want to go further... So I'm guessing I have to buy a new part to achieve that?
Old 04-23-2014, 07:36 PM   #9
I haven't posted enough to put links -_- so I mean have more negative camber as someone mentioned, so the top of the wheel is tilted inward... I've already tweaked it to where they are slightly cambered but I can't go further, and that's the problem I want to fix.
Old 04-23-2014, 07:44 PM   #10
What are you trying to accomplish? More camber just for the sake of having more camber?
Its not necessarily a problem, but we have no idea what car you have and no idea if you even have adjustablr camber links.
Old 04-23-2014, 07:52 PM   #11
http ://imgur.c om/pydg6WT here's a picture of my car
Old 04-23-2014, 08:27 PM   #12
[ar QUOTE=hyujmn;13209400]What are you trying to accomplish? More camber just for the sake of having more camber?
Its not necessarily a problem, but we have no idea what car you have and no idea if you even have adjustablr camber links.[/QUOTE]
Yea I guess that's true, I like having quite a bit of camber but I have a limit. I'm not exactly doing it do benefit my car, but I don't want it to the point it where it's just ridiculous
Old 04-23-2014, 08:37 PM   #13
ThePanda's Avatar
Trader Rating: 65 (100%+)
ahh, it appears that it is a drift car and you are trying to go for the extreme camber look to tuck the wheels under the fenders, and increase traction a bit?
to go with higher camber angles you will probably have to go with a different car. if the turn buckles are bottoming out then the bones will probably soon also. to get the insane drift camber angles you will need a chassis designed to take high camber in the first place, or a chassis that the geometry allows it.
ThePanda is offline   Reply With Quote
Old 04-23-2014, 08:55 PM   #14
Originally Posted by ThePanda View Post
[IMG]http ://i.imgur.c om/pydg6WT.jpg[/IMG]
Do you know of any chassis that can take it but isn't taking my whole bank account with it?
Old 04-23-2014, 09:21 PM   #15
ThePanda's Avatar
you will want something with CVD's and long turnbuckles. I would suggest a VDF chassis as those are going for about 325, but that is really a carpet only chassis, and anything but carpet or brand new asphalt will just destroy the carbon chassis. (you want plastic for road driving)
you really don't need to run such high camber angles anyways, and it really is only necessary for CS or RWD or just for cosmetics
