Old 05-20-2014, 08:22 AM   #31
b20btec's Avatar
Originally Posted by Lorents View Post
Thanks!
I considered taking them off but found them useful for transponder mounting The RC4 transponder wont work properly if its mounted on metal or carbon.
Tried a couple packs on the local track yesterday. Super happy with it so far! Very smooth and powerful.
Looks great. I'm still debating buying one. Your rc4 should work I. Carbon and metal.
b20btec is offline   Reply With Quote
Old 05-20-2014, 08:55 PM   #32
Trader Rating: 16 (100%+)
Thanks!
You should put it inside the receiver box...you don't need to mount it on anything, just inside that receiver box and it works fine.
And yes, remove those side plate...they looks ugly, and this is not a buggy afterall...LOL
Old 05-21-2014, 01:30 AM   #33
Ok, I get it. RC4 in the receiver box and away with the guards
Lorents is offline   Reply With Quote
Old 05-22-2014, 01:29 AM   #34
Agree... looks much better, saves a few grams and you are right about the RC4 in the rx box. Thanks for the tip!
Old 05-23-2014, 01:44 AM   #35
First failure...
Motor seized and the end cap popped. Have never experienced anything like that before... It was not hot and it is rated for 6S.
The good news is that the car is holding up well
Speed Power E801GT-20140523_080447.jpg   Speed Power E801GT-20140523_080259.jpg
Old 05-26-2014, 02:24 PM   #36
Trader Rating: 37 (100%+)
First failure...
woah...looks like the set screws or whatever backed out or something. Weird...what motor was that?
We made it out to the track this past weekend with our E801GTs. We ran the cars box stock with the exception of Alpha tires and Serpent shock springs. They were a blast to run in the mix of GT nitro and 1/10 nitro cars.
We did take some video and will try to get it online after downloading the footage.
Speed Power E801GT-img_20140525_123324901.jpg   Speed Power E801GT-img_20140525_123330336.jpg
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-29-2014, 08:58 PM   #37
Some basic fixed video I took with my MotoX smartphone sitting on the drivers stand. I have some better video using a head mounted cam that follows the cars. Uploading that later this week and will post.
Having some fun on the track with e801GTs. This video might have been our first run of the day running all stock setup with Alpha Soft tires. They're a blast to drive on this big track.
white/orange and blue/yellowish cars using Blaze 2450kv motors.
+ YouTube Video
Old 06-18-2014, 05:23 PM   #38
+ YouTube Video
Speed Power E801GT and E801B part 1.: http://youtu.be/6FjhTj-JkYM
Old 06-18-2014, 05:46 PM   #39
How do Sweep GT tires hold up when running on a GT-e car? I read all over that they don't hold up under the high torque and accel of an e car, compared to a nitro GT. But I would like to try some Sweep treaded GT tires for my local track. The track is an old parking lot with worn out asphalt, and is (probably) too dusty for slicks.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 06-18-2014, 06:59 PM   #40
I think a year ago or so there was a bad run of Sweeps. That changed or went back to normal after the inventory cycled through. I ran Alphas, but the other E801GT car was running older treaded Sweeps I think. They held up fine from what I could see in our pits.
We had 2450kv motors so plenty of power/torque being put down. I'll see if I can get Solara to post specifically what tires he ran.
Old 06-25-2014, 10:59 AM   #41
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Officially lurking on this thread.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 06-25-2014, 11:10 AM   #42
I have better video of the e801GT on the track, but I've been busy and haven't editted/loaded it up yet.
Old 03-24-2015, 04:47 AM   #43
NiteCap2k's Avatar
Hello Guys, I'm wondering if that Motor Mount limits the size pinion that can be used on this Kit. it looks a lot like the motor mount i took from a RedCat RC to build a conversion. thanks
NiteCap2k is offline   Reply With Quote
Old 03-24-2015, 08:42 AM   #44
What size pinion you looking to run? For the most part I know last summer we ran 2450kvs, 2200, and a 1900kv with no gearing issues.
Old 03-24-2015, 10:11 AM   #45
Unless you need to mount a 30T pinion........I have tried to mount a 25T pinion on that motor plate and I can still rotate the motor and mount something bigger...but honestly, running 4S powered 2750kv motor I don't think you really want to mount something that big in pinion.
