Grease for rc car >
Grease for rc car
Grease for rc car
Old 04-16-2014, 09:06 PM
Default Grease for rc car
Can I use real car break&caliper grease on my rc car?
like between pinion and spur gear
eugene2245 is offline
Old 04-16-2014, 09:07 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
the pinion and spur gear doesn't use grease.
ThePanda is offline
Old 04-16-2014, 09:22 PM
dan_vector's Avatar
Trader Rating: 27 (100%+)
You have to be careful with oils and greases because certain ones can affect plastics and carbon fibre materials used in RC. As Panda says definitely no grease between the spur and pinion!
Main areas to be kept well cleaned and lubricated with a good black grease (I like Xceed greases personally) are the driveshaft ends and drive cups really as well as silicone diff grease for ball diffs.
dan_vector is offline
Old 04-16-2014, 10:14 PM
ThePanda's Avatar
for plastic gears use ceramic grease.
ThePanda is offline
Old 04-27-2014, 10:52 PM
Default Thank you and another question
Thanks for stopping me to use that grease
I just got Team Losi Racing Hi-Pressure Black Grease.
So, I can use it on each end of center drive-shaft and gears where they connect to drive-shaft, right?
Old 04-28-2014, 07:07 AM
ThePanda's Avatar
I prefer not to use grease on those parts as it attracts lost of dust and dirt and can sometimes be more harmful than helpful.
ThePanda is offline
Old 04-28-2014, 09:08 AM
Do not put grease on anything exposed. Only put it on things that are completely sealed. Dust and dirt sticks to the grease and turns it into an abrasive paste.
Stregone is offline
Old 04-28-2014, 10:24 AM
ThePanda's Avatar
Exactly. A light coating of ceramic grease on the sealed trans is all you really need, and some prefer to bypass this anyways.
ThePanda is offline
