latrax rally problems!! >
Old 04-13-2014, 02:12 PM
Default latrax rally problems!!
i have a latraxx rally 1/18 scale and i was cleaning it out etc. put it back together ran it then i heard a bunch of clicking, took it all apart and checked everything make sure nothing was broken.. didnt see anything.?? confused!!
dutch73 is offline
Old 04-13-2014, 05:44 PM
Potoczak's Avatar
Trader Rating: 113 (100%+)
It's probably either the front or rear pinion going to one of the diffs that is stripped. I have stripped quite a few of them.
Potoczak is offline
Old 04-17-2014, 07:54 PM
good info!! i will check that out, do you know if any one makes metal pinions??
dutch73 is offline
Old 04-17-2014, 08:34 PM
uh60's Avatar
Trader Rating: 26 (100%+)
I had a similar issue. I just CA glued the diff to make it a solid diff.
Amain sells the diff gears for about 5 bucks.
uh60 is offline
Old 04-17-2014, 08:58 PM
Potoczak's Avatar
Actually latrax just came out with the Teton truck. It has all metal gears instead of the plastic. It's the same chassis so I would assume they should fit right in the ralley.
Potoczak is offline
Old 04-18-2014, 11:37 AM
thanks for all the info folks! so as for now i am currently making it a fwd untill i can get some aluminum parts!! wish me luck!!
dutch73 is offline
