Like Tree86Likes
Tamiya TB Evo 6
Old 06-14-2018, 05:48 PM
  #2641
I use ceramic dry bike chain lube. No issues with dirt getting stuck on the gears
mac853 and Raman like this.
WagwanBumba is offline
Old 06-15-2018, 01:36 AM
  #2642
mac853's Avatar
It means need grease anyway.
Thanks!
mac853 is offline
Old 06-15-2018, 06:32 PM
  #2643
Raman's Avatar
Trader Rating: 59 (100%+)
Thats precisely what I use.. finish line ceramic dry lube
Raman is offline
Old 06-20-2018, 06:04 AM
  #2644
mac853's Avatar
Could someone are using Exotek alu bulkhead and shock tower with ssbb shock tell me, are 2 inner holes of shock tower are unusable since the shocks lean too much without make any rebound?
Best regards
mac853 is offline
Old 06-20-2018, 11:27 PM
  #2645
mac853's Avatar
Someone with Exotek alu bulkhead with shock tower could tell me if fits using SSBB shocks, in fact i could feel the shock towers are high to use shorter length shocks.
mac853 is offline
Old 06-21-2018, 03:16 PM
  #2646
MikeR's Avatar
Trader Rating: 15 (100%+)
For the new SSBB shocks you can unscrew the bottom cup by 1.5mm. Cannot use the inner shock hole on the low setting because the shock will hit the sway bars.
MikeR is offline
Old 06-21-2018, 06:55 PM
  #2647
mac853's Avatar
I guess is better use original shocks again, i think use only low setting of tower is usable due high is unworth.
BTW, if use short spring need use those spring spacers of SMJ.
About cannot run inner hole?
This is difficult in fact i run carpet then o didn't notice it woult hit swaybars.
Anyway, thanks!
mac853 is offline
Old 07-11-2018, 07:00 AM
  #2648
aracefan's Avatar
Trader Rating: 54 (100%+)
Originally Posted by zxcvb1t View Post
Hello everyone it's me again. I want to know how your guys arrange antenna on exo 6 v2? The upper deck is different from V1 so the center hole doesn't exist anymore.
Little late to this, sorry, but I fold the antenna over itself (like an accordion) and use a piece of shrink tube and put it between the servo and Rx. Problem solved, nice and neat, too.
aracefan is offline
Old 07-11-2018, 04:56 PM
  #2649
Raman's Avatar
same here
Raman is offline
Old 07-12-2018, 06:17 AM
  #2650
Hi, Quick question, do you know if the MS alloy chassis fits onto the std TBevo6? Thanks
Qatmix is offline
Old 07-12-2018, 06:33 AM
  #2651
Tom1977's Avatar
Yep! They are exchangeable.
Tom1977 is offline
Old 07-12-2018, 08:28 AM
  #2652
Raman's Avatar
If you’re running the awesome exotek bulk heads and still feel you need some more blue in your life.. you can now opt for the TB05 aluminium diff case 42324
https://www.thercracer.com/2018/07/n...p-ups.html?m=0
NutDriver and aracefan like this.
Raman is offline
