Tamiya TB Evo 6
#2581
Has anyone raced this against the awesomatix A700 in vta or usgt. How do they compare
#2582
I own both an Exo 6 and A700. Both similar feel but I've had less time with the A700 before chucking it on a track to race. Biggest pro of the A700 is the steel pinion/crown gears but running in 21.5 action you should be fine with the carbon plastic gears in the 6.
But both cars, like any, really come down to setup.
#2583
The Exo’s are great cars and are rock solid and competitive.
I personally prefer the A700 in VTA. The rotation from the AX cars is second to none.
I modified one of my Exo’s to incorporate active rear toe and it was very close in rotation to the AX but I still preferred the A700.
The A700 is an engineering masterpiece and requires a LOT of care between races to ensure your camber/castor doesn’t change. The Exo six was a robust tank that delivered results without much maintenance.
Can’t go wrong with either car.
#2585
Hi,
I was going to order them, but I have just read on the website they are not compatible with the standard evo 6 chassis.
This is really surprising since the exo 6 works with the standard gearbox.
What makes them incompatible and tis here a way to overcome this limitation?
Thanks,
Ale
Thanks,
Ale
#2590
Hi,
Thanks,
Ale
Thanks,
Ale
#2591
Hi,
Thanks,
Ale
Thanks,
Ale
#2592
[QUOTE=MikeR;15170170]It's still February... and as promised...
Hi Mike, Its a great news !
If any option for the bearing holder to the sway bar?
#2593
The rear central gear box is not attached to the top deck. So there should be no problem at all.
In my oppinion it should fit the original Evo6.
Btw. are there gear covers planed for the exo alu bulkheads?
Greetings Rainer
#2594
anyone know how much can cost a second hand car like this one and if it's easy to find ?
