Old 04-04-2014, 12:49 PM   #1
blackshark3's Avatar
Default How to measure spring rates?
Just wondering how could I measure the spring rates of the coil springs of my touring cars...Do I need to buy special equipment or there is an easy way to do so? Thanks
blackshark3 is offline   Reply With Quote
Old 04-04-2014, 01:31 PM   #2
sosidge's Avatar
You can squeeze them against one another to see what is stiffer. You can measure the wire diameter, internal diameter and number of coils to try and calculate the rate. To actually measure the rate is hard with the equipment you might have available at home although I think some people have fabricated a jig using a drill press and a kitchen scale.
Old 04-04-2014, 01:37 PM   #3
samnelso's Avatar
Idea, trying to convey in words.
Place spring over a hole in a board. Put long screw with fender washer through the spring and hole. Hang weights off the screw (don't forget to account for the weight of the screw/washer) and measure the deflection of the fender washer relative to the board.
Spring rate, k = weight/deflection
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 04-04-2014, 01:49 PM   #4
howardcano's Avatar
Trader Rating: 35 (100%+)
It's a good idea to place both springs over a screwdriver, nutdriver, socket wrench extension, etc, when doing this. Otherwise they can fly really far when they go BOING.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 04-04-2014, 05:07 PM   #5
Send a message via Skype™ to slotracer577
Here is a thread that shows my spring tester and has a spread sheet to calculate spring rates. http://www.hobbytalk.com/bbs1/showth...ghlight=spring
slotracer577 is offline   Reply With Quote
Old 04-04-2014, 05:20 PM   #6
howardcano's Avatar
Looks great! Simple but effective.
Howard Cano
