Old 08-10-2005, 02:33 PM   #1
thecrow2k's Avatar
Default Rear Diff
Was cleaning me evo out today and cleanign the bearings etc and putting some lube on the gears etc and when i got it ack together revved it up, I decided to hold the back wheel and when on full throttle, with quite a bit of ease i could stop the back wheel moving whereas in the front with the oneway I couldnt. Is this meant to happen as it seemed the back wheels had little power going to them
thecrow2k is offline   Reply With Quote
Old 08-10-2005, 03:33 PM   #2
Send a message via AIM to BONZAIII Send a message via Yahoo to BONZAIII
Yes.The one way acts like a spool under power so both wheels will pull.The diff acts like that when one or the other tire is being held like that.I wouldn't think you could hold both rear tires.If that happens check your car.
BONZAIII is offline   Reply With Quote
Old 08-10-2005, 03:34 PM   #3
thecrow2k's Avatar
Yeah I did that, i set the transmitter to just over half throttle, its a bit harder to hold but not as hard as the oneway at all. Does it need tightening or not? If so, how do i tighten it
Old 08-10-2005, 03:39 PM   #4
Is this an XRAY?
Old 08-10-2005, 03:39 PM   #5
John_S's Avatar
there should be a screw in one side of the diff outdrives just tighten that and the diff will tighten, not to tight tho you still want the diff to slip ever so slightyl
John_S is offline   Reply With Quote
Old 08-10-2005, 04:00 PM   #6
thecrow2k's Avatar
yeah i just did that, thanks the diff is now harder to hold, someone told me to hold one wheel and the spur then try turn the other wheel and the wheel should be hard to turn while hurting your finger, before it hurt a bit now its quite hrd to turn without squaling pain. Thanks guys
IRS Rear Diff II Fast R/C Items: For Sale/Trade 8 10-06-2007 10:23 AM
Rebuild your rear Diff Ivan Dickson Nitro On-Road 4 02-23-2007 04:20 AM
Which diff is best for the Trf 415 rear end. racerkorer Electric On-Road 2 01-09-2005 03:56 PM
Rear diff gears graham1234 Nitro On-Road 1 07-18-2004 08:51 AM
rear diff oil?? goldenboy Nitro On-Road 0 04-24-2004 09:41 AM
