Old 09-16-2002, 01:54 PM   #1
Regional Moderator
kansasracer's Avatar
Default CRC Carpet Knife
I know there already is a thread for 1/12 scale racing, but shouldn't we have a place to share setups for CRC faithful?
I am in need of a setup for the new carpet track here...any suggestions?
Also, what are your views about the old school front end vs. the new front end...
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 09-16-2002, 02:35 PM   #2
F1-Fanatic's Avatar
Hi,
What is the track layout like and will you be running stock or mod?
F1-Fanatic
F1-Fanatic is offline   Reply With Quote
Old 09-16-2002, 03:53 PM   #3
newracer's Avatar
R/C Tech Charter Subscriber
I have heard that the kit setup is the best place to start. I am currently running on asphalt but a new carpet track is opening this fall. Can't wait, I bought a new Bloody Knife to dedicate to capret racing only.
newracer is offline   Reply With Quote
Old 09-16-2002, 03:54 PM   #4
Regional Moderator
I am running a Core stock, and I would say a pretty tight track layout, alot of 180 turns...
Does that help?
Old 09-16-2002, 07:36 PM   #5
F1-Fanatic's Avatar
It does. I like to set my 3.1 with a little more steering than most like but it works great with a mod motor and a few weeks back was absolutely wicked fast with a stock hand-out. First I like to true my tires (Jaco Grey rear and Purple front) down a little so that a) they don't chunk and b) there is less reciprocating mass. This is my setup.. and is not the most economical one for tire wear but as long as your ride height is around 3mm (no less because it will most likely rub the carpet) you should be OK.
Front Tires: Jaco Purple 46mm
Rear Tires: Jaco Gray 48mm
Front Springs: 20
Center Spring: Calandra Red
Shock Oil: 40 wt. Serpent
Side Springs: White
Dampening Tubes: Losi (standard) Hydra-drive fluid
Ride height 3mm all the way around
Front suspension: Non-reactive caster (flat top) with 1 shim to start.. as the tires wear remove the shim and then adjust the rear with axel pod inserts and true the fronts as needed.
Adjust toe to slightly out if any at all and adjust camber so that the tires wear flat. Rebuild the rear dif as necessary making sure to pay close attention to the flanged bearing closest to the diff adjustment nut. If you feel a gritty feeling at all in the dif and you had a few encounters with the boards, chances are this bearing is shot.. it only takes once and furthermore DO NOT over tighten this diff! the design is very poor because it requires this bearing to take a lateral load such as that of a thrust bearing which it was never designed to do in the first place. My advice is to adjust the diff so that it moves very freely while holding one wheel and rotating the other.. it should feel very silky but when you hold the spur gear should not slip. (this is a touch thing which you can ask someone at the track to test for you if you are unsure)
I hope I didn't leave anything out and this helps.
F1-Fanatic
Old 09-16-2002, 09:06 PM   #6
Regional Moderator
Thanks, I'll try that. My setup was close except for the red center spring...
Old 09-21-2002, 12:14 PM   #7
Thumbs up Knife Set Up
I have been racing a carpet knife for the last six years and think they are the only way to go.My set is pretty much standard except I have found that runnig heavy fluid in the dampners make the car very forgiviing and easy to drive.I have gone as heavy as diff ball lube.
The ride heigth is the most critical thing and must be kept level
to maintain best performance.
SrRC is offline   Reply With Quote
Old 09-21-2002, 07:51 PM   #8
I like 100 wt. shock oil in my dampers, it needs cleaned and relubed after ever other run, but I don't mind as there is so little maintenance compared to tourers..... Makes me feel like I am doing something....LOL
I have the latest version of the 6-pack (not bloody red) if anyone was interested.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-27-2002, 08:07 AM   #9
che
che's Avatar
Default Gearing?
Any suggestions on where to start gearing my CK3.1 using a 19t spec (Chameleon) on a smaller tight, technical track?
Also, what size should I true down a brand new set of tires?
4 cell, 8 minutes using standard kit 64 pitch spur gear...
che is offline   Reply With Quote
Old 10-18-2002, 11:51 PM   #10
Regional Moderator
Default Re: Gearing?
I am interested in this as well...any suggestions?
Old 10-18-2002, 11:55 PM   #11
fIShCaKe's Avatar
Send a message via MSN to fIShCaKe Send a message via Skype™ to fIShCaKe
Hi, I'm new to this... But the design of carpet knife looks just like the Team Associated RC12L3, guys, is there any diff between the 2 chassis, other than the amount of cells they take?
fIShCaKe is offline   Reply With Quote
Old 10-19-2002, 12:08 AM   #12
newracer's Avatar
the CRC Six Pack and the 12L3 are very simular, but the 4 cell Carpet Knife is a lot different in the rear end it doesn't have a T-plate, it uses springs and side dampening tubes. all have the same front end assembly.
Old 11-15-2002, 10:32 PM   #13
Lightbulb Carpet Knife
Ha guys lets keep this page going,I have been away for awhile
and had to dig deep to find it again.
My last race the knife was dialed--took second in the
A main after the switch on my speedo died!
It was fun turning inside of the Associated cars!
Will try again this Sunday .
Old 11-15-2002, 10:43 PM   #14
Regional Moderator
My Knife was dialed too last race. A Main winner, but all the other cars were Knifes too!!!
Old 11-16-2002, 07:17 AM   #15
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
I had a prretty good run last week in the Louisiana state race.....qualified 2nd. out of 15(with my Knife).....car still has a little too much push on turn in....finished 3rd. in the A-main.
Dragon Slayer is offline   Reply With Quote
Carpet Knife 3.1 Bloody Knife almost RTR ldp787 R/C Items: For Sale/Trade 2 11-04-2006 11:26 PM
CRC carpet knife 3.2r "bloody knife" roadrashracing R/C Items: For Sale/Trade 1 08-01-2006 12:01 PM
CRC 3.2R Bloody Knife/Carpet Knife 2 Rollers "ULTIMATEPOWER" R/C Items: For Sale/Trade 7 03-24-2006 07:59 AM
i want a carpet knife 3.2r / bloody knife have cash or stuff to trade!! mjs3350 R/C Items: Wanted to Buy 11 08-26-2005 11:42 AM
carpet knife 3.2 pimpjuice_101 R/C Items: For Sale/Trade 7 07-08-2004 04:44 PM
