CRC Carpet Knife >
CRC Carpet Knife
CRC Carpet Knife
Old 12-08-2003, 11:48 PM
  #31
Registered User
Default Re: CK vs. Corally
Originally posted by Geek
3) Hi-speed wandering. I was running a 10 single with 98 spur/24 pinion - the track we have is huge (100 foot long straight) and I was hauling major a$$ at the end of it...
The car felt GREAT in the corners.. if anything I had a bit too much traction but on the straight it seemed to "wander" a bit. Didn't always track the same. Anyone have any suggestions on how to make it track better at speed or what I may have adjusted wrong?
I had the same problem. In my case, it was too much play in the rear axle. I shimed out the play and centered the rear wheels.
thatdog is offline
Old 12-09-2003, 04:40 AM
  #32
Trader Rating: 35 (100%+)
I race stock and haven't experienced this problem, but I'm wondering if your issue is not related to chassis tweak???
Geppetto is offline
Old 12-09-2003, 12:16 PM
  #33
Hey Geek,
Ya know I was thinking about your wondering problem...Im thinking it had something to do with the binding in your rear pod from those links. My car was doing a little of that, but I have 2mm of side play in my rear axle which after reading this thread was prob making my car wonder at med speed. Now under high speed my car tracked ,like at the end of the straight my car very solid. Under acceleration it went staight, so im guessing it was the play in the rear axle.
scnsaracer is offline
Old 12-09-2003, 01:40 PM
  #34
Geek's Avatar
You are probably right Scott...
When I talked to John this morning I ordered another proper pivot instead of that "jury rigged" one I came up with
I too went through my entire car threadlocking metal to metal and CA'ing metal to plastic.
Geek is offline
Old 12-09-2003, 03:52 PM
  #35
newracer's Avatar
Default Re: Thread returned from the dead...
Originally posted by ApexSpeed
I looked for any setup sheets for the CK or any other 12th scale car and I didn't find any that covered everything I wanted, and that includes the CRC factory sheet. So I did what any proactive racer/graphic designer would do and I made my own. It is very detailed and probably more than most guys would care to keep track of, but anyone who wants it is welcome to use it. If there is anything missing or something that you think would make it better, let me know.Carpet Knife Setup Sheet
-doug
nice setup sheet
I used it as a template and made it editable, email me if you want to check it out. I still need to figure the best way to mark the traction compound for the tires though.
newracer is offline
Old 12-16-2003, 12:12 AM
  #36
I am looking to buy a CK3.2 and wondered what bits I will need on top of the car purchase to be able to set it up for different tracks.
I am guessing that alternate springs would be required but which ones ?
There are two venues near me - One is small tight and carpet , The other is more open and flowing on asphalt ( indoor )
We now have an official importer in the UK who uses the correct exchange rate rather than 1GBP = 1USD so the price of the car and the spare parts are now cheap.
Any advise for building and setting up the CK3.2 when it arrives would be welcome.
Bob The Builder is offline
