Old 03-28-2014, 02:24 PM   #1
Default ball diff for mini
I just got the TA 03 ball dif. hop up to put im my M 05, but not sure how to set it up.. iv read about grease, no wear grease or even no grease.. as long as its tight..
Not sure what to do... since they are a pain to get to...
coolair55 is offline   Reply With Quote
Old 03-28-2014, 02:52 PM   #2
SteveM's Avatar
Trader Rating: 142 (100%+)
Use the Tamiya AW black grease in place of diff lube and tighten the diff as much as possible.
SteveM is offline   Reply With Quote
Old 03-28-2014, 03:06 PM   #3
Build per the instructions. Cinch the diff screw down till it bottoms out and be sure to use loctite. You can use either the diff lube or the anti wear grease that came in your kit. The important thing is to use very little of either or you'll have a mess. Pay attention to how the cone or Belleville washers are oriented.
Orient the diff so that the outdrive with the shaft is on the right side of the car. It just makes it easier during maintenance.
There are a number of building "tricks" to tighten the diff action, but you'll find those in the Tamiya Mini thread.
Granpa is offline   Reply With Quote
