Closed Thread
Old 08-09-2005, 06:30 AM   #1
Default Money Making Message
How to Turn £3 into £10,000 in 30 Days with Pay Pal
(There are many different variations of this programme in existence on the internet, but do not be fooled by their claims.
This method is the most successful, lucrative and least time consuming of them all. It remains lucrative and LEGAL only as long as you follow the instructions below, TO THE WORD)
(If you have found this message on a MONEY MAKING MESSAGE BOARD follow the intsructions as normal)
This is a legitimate business opportunity, a perfectly LEGAL moneymaking enterprise as long as you follow the instructions below VERY CAREFULLY. It does not require you to sell anything. It does not require you to speak to your friends, family or anybody else (unless you want to). In fact, you do not need to come into contact with any people whatsoever.
You have most likely seen or heard about this project on TV programs such as 20/20 and Oprah Winfrey or you may have read about it in the Wall Street Journal. If not, here it is below - revealed to you in step-by-step detail. This program is by no means new. It has been in existence in many forms for at least ten years. But in the early days, it required a lot more time and effort, as well as an outlay of a few hundred pounds.
However, thanks to Pay Pal and the Internet, the outlay is now virtually zero. The entire process is also faster, easier, and more lucrative than it has ever been! This program works no matter what country you are in, or what currency you use. It doesn't matter how old or how young you are. You donít need to run a website, make phone calls, photocopies, or send out letters through the mail, or pay for advertising, and you donít require any technical expertise. The only things you will need are: ∑An email address ∑A Premier or Business Pay Pal account with at least £3 deposited in it.
(Details on how to obtain this follow)
(The process takes approximately 30 minutes to complete.)
LETS GET STARTED
Follow the instructions EXACTLY as set out below.
STEP ONE: If you're not already a Pay Pal user, the first thing you need to do is use the Pay Pal link below and sign up.
Here's the URL: https://www.paypal.com/uk/mrb/pal=5HDKFF9WZZ8QL
Be sure to use this link so you can sign up for a free PREMIER or BUSINESS account. You'll need to have a PREMIER or BUSINESS account (and not a PERSONAL account) otherwise you won't be able to receive credit card payments from other people.
STEP TWO: The first thing to do when you have your Premier/Business Pay Pal account is to send a £3 payment from your Pay Pal account to the FIRST email address in the list below, along with a note saying: "Please add me to your mailing list.Ē
Be certain to add this note, as this is what KEEPS THIS PROGRAM LEGAL. Instructions on how to send a payment are under "SEND MONEY" at the Pay pal Site.
Here's the current list:
1) [email protected]
2) [email protected]
3) [email protected]
4) [email protected]
5) [email protected]
STEP THREE: Once you've sent a £3 payment to the address at the top of the list (along with your note - this is VERY
important! DO NOT FORGET TO ADD IT) the next thing you need to do is to obtain a copy of this email message and send it out
to at least 40 people. The copy that you will send out will contain YOUR email address at number FIVE in the list - having
deleted the address at Number 1 in the list, and moving the others up a position. The easiest way to do this is to highlight
and paste the all of this text into a new e-mail message and make the relevant adjustments.
∑The first thing to edit is the email addresses in the list above. Delete the top email address, and then move the others up
a position, and then add your email address to the bottom of the list (the number 5 position). Be sure to use your email
address that is associated with your Pay Pal account. But do not forget to send £3 via Pay Pal (along with your note) to the
email address at position number 1 before deleting it. (Don't be tempted to add your name to position 1 in order to earn
money fast. It doesn't work like that. If you do that, you will only reach the people you directly send emails to, and then
your name will be immediately removed from the No.1 place. By adding your name to the Number 5 position, there will be
literally thousands of people receiving and sending e-mailís later - when your name is at the Number 1 spot)
∑Now you need to edit the Pay Pal referring URL (shown above in Step 1) with your own Pay Pal referring URL. You can find
your referring URL at Pay pal after you join. Just look at the bottom of the first page once you sign into Pay pal, and click
on the "referrals" link. You will be given a referring URL similar to the one above, except the code number at the end will
be different. Simply delete the current Pay Pal referral URL in Step 1 above, and replace it with your Pay Pal referral URL.
Once you've edited your email message as outlined above, send out a minimum of 40 copies of this email - but only to people
you know, or to people who respond to MLM offers, or to people who've sent you offers as this will prove most lucrative to
you (the chance of the recipient taking up the programme is more likely).
FURTHER INFORMATION
When you send out your emails, your email address will initially be at Number 5 in the list. That's the best position it can be in at this stage if you want to make serious money. On average, you can expect a response from about 25% of the people you send to. But let's be extremely conservative here and assume that you receive an average response rate of only 12.5%. If you send out your email to 40 different people, you can expect at least 5 of those people to do exactly what you did (12.5% of 40 = 5). By this time, your email address will have moved up to No.4 in the list, and this list will now have reached around 200 people (5 x 40). Out of those 200 people, you can expect at least 25 of them to participate (12.5% of 200 = 25), so that's a further 1,000 emails (25 x 40) being sent out and your email address will have risen to No.3 in the list. Out of those 1,000 people, you can expect at least 125 of them to participate (12.5% of 1,000 = 125), so that's a further 5,000 emails (125 x 40) being sent out with you now at the No.2 position. Out of those 5,000 people, you can expect at least 625 of them to respond (12.5% of 5,000 = 625), so that's 25,000 emails (625 x 40) being sent out with your address at the No.1 spot! Now, out of those 25,000 people, you can expect around 3,125 of them to respond (12.5% of 25,000 = 3,125). And since you will now
be at number 1 in the list, you will receive: £9,375 (3,125 x £3). This amount will enter your Pay Pal account in £3 payments. The first payments will arrive within a few days, and they will continue at the rate of about 100 payments per day for about 30 days. After that time, the volume of payments begins to taper off as your email address vacates the Number 1 position. But there's more!!! For each person who signs up with Pay Pal as a result of using your unique referral URL, you will automatically receive a referral bonus of up to £75 from Pay Pal!
If you want to operate this business continuously, you should consider obtaining bulk lists of email addresses from a reputable mailing list company. If you already have a legitimate mailing list, then this would be the most profitable way to make use of it. There are many websites that sell thousands of fresh opt-in email addresses of people who have subscribed to receive exactly this type of program. For example, check out: BusinessMailing.co.uk and Email2Success.com.
No cheating can occur as Pay pal only allows one account per person. Because it is so easy, the response rate is very high
and very fast - Internet email fast, and you will start seeing dramatic results in less than one week! Pay Pal lets you pay anyone with an email address and is the world's Number 1 online payment service. Pay Pal is accepted on over 3 million eBay auctions as well as a countless number of online shops. You can also use Pay Pal to pay your friends - for example, it's a convenient way to split the phone bill with your room-mate, send cash to your kids in college, or send cash to someone in another country. Better yet, you can also earn a referral bonus of up to £75 each time someone signs up for a Pay Pal account using your referral URL! When you send money through Pay Pal, you can fund your payments with your credit card or cheque account. You won't have to worry about your privacy, because Pay Pal keeps your accounting information safe and secure.
Making a purchase with Pay Pal is far more secure than mailing a cheque or giving your credit card number to a stranger.
That's why over 9 MILLION people from around the world use Pay Pal to move money. Signing up for a Pay Pal account is free, easy, and it takes only a couple of minutes.
Finally, it is advisable that you keep a record of all the e-mails you receive as this provides proof you are conducting a legal business.
losi-sw is offline
Old 08-09-2005, 06:36 AM   #2
Rod M's Avatar
your a idiot,
(report post to administrator)
Rod M is offline
Old 08-09-2005, 06:44 AM   #3
howard hudson's Avatar
R/C Tech Charter Subscriber
there is no such thing as easy money. These types of scams have been going on for years!!!!!!!!!!!
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline
Old 08-09-2005, 06:46 AM   #4
Another "dime a dozen" pyramid sceem
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline
Old 08-09-2005, 06:48 AM   #5
Ahh.... the days of being seventeen and not having a clue
Joe B is offline
Old 08-09-2005, 06:52 AM   #6
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Go out and earn your money and stop trying to con the rest of the hard working people. Its called a piramid scam and is very illegal in the US. So even if you go by your instuctions it is still illegel in the US. So please go and peddle you junk elsewere.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline
Old 08-09-2005, 07:12 AM   #7
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
If it were me, I would delete your post and Ban your IP. Then I'd call your parents to let 'em how you spend your time. This is a message board for R/C's can we keep it that way
James Cooper
SouthernFriedRacing
[email protected]
SOuthernFRIED is offline
Old 08-09-2005, 07:25 AM   #8
Many are set-up with loop holes making them legal......but nevertheless a "complete" scam to the regular guy involved in one (which ends up being 99% of the people involved)......and the 1% of the people at the top,(usually the guy giving the free seminar) make a boat load of cash by totally missleading the rest with false money making possibilitys.......nice huh
Joe B is offline
Old 08-09-2005, 07:34 AM   #9
Regional Moderator
Racer_Chick's Avatar
Send a message via AIM to Racer_Chick Send a message via MSN to Racer_Chick
Hey, I'm 17 and I'm not running these scams! This is middle school stuff, lol.
Toni Green|Munno Graffix|CFX Racing
Кто глупее? Дурак или дурак, который следует за ним?
Racer_Chick is offline
Old 08-09-2005, 07:44 AM   #10
lock or delete this thread
Old 08-09-2005, 07:45 AM   #11
Regional Moderator
I would, but I'm only a regional moderator
Old 08-09-2005, 07:46 AM   #12
But Howie,
we all need a place to vent our frustrations on the less considerate people of the world who think they can make free money off us......
LOL
-Shookie <><
Old 08-09-2005, 07:52 AM   #13
Originally Posted by Mr. Shookie
But Howie,
LOL
-Shookie <><
we need a place to vent eh ????? how about I post your PHONE NUMBER !!!!
Old 08-09-2005, 07:53 AM   #14
DETAILS DETAILS
Old 08-09-2005, 07:55 AM   #15
Sweet. Then I can add everyone to my next phone sales scam I LOVE Caller ID.........Thanks Howie always lookin' out....LOL
Closed Thread
A message to ROAR JLMG1971 Electric On-Road 12 06-16-2005 07:38 PM
A message to you all... Anders Myrberg Electric On-Road 30 12-25-2004 08:23 AM
Private Message box JasonC R/C Tech Site Forum 0 04-20-2004 11:27 AM
