Old 03-27-2014, 01:55 PM   #1
AL1983's Avatar
Post HW V3.1 vs MM Fleta Pro!
Need advice.
I'm fairly new to touring cars but have my mind set on two ESC's, I know that both are world class esc's.
I'm in between HW V3.1 and MM Fleta Pro, which should I choose? Does the fan size matter? What other difference are there if any? Program card differences? Software?
I want the best possible combo, I'll be running mod and have my eyes set on one of these motor's, HW V10 or Fleta ZX both 4,5R, which esc + motor combination is best?
Thx for replying!
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 03-27-2014, 02:09 PM   #2
dan_vector's Avatar
Trader Rating: 27 (100%+)
For out and out performance the Fleta Pro and Fleta ZX motor combo would probably be best. If is quite an aggressive setup and some drivers have found the fleta pro too aggressive for them. I had Jang from Muchmore setup mine at TITC and I much preferred it to the HW 3.1 I had used previously.
The program cards and setup methods are similar between the two and so this shouldn't influence your choice. Both would be run on stock software which gives you the options for timing boost and hybrid boost settings etc. Some of the modified softwares don't give you those options. The Fleta s/w does however.
As you say either one is world class and probably the best esc/motor brands out there. The only other would be the Speed Passion Reventon 1.1. Ultimately I think the fleta has the edge over the HW and I love both.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 03-27-2014, 02:18 PM   #3
The HW v3.1 is one of the top ESCs on the market, but I'm partial to HW.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-27-2014, 02:28 PM   #4
DirkW's Avatar
Originally Posted by dan_vector View Post
As you say either one is world class and probably among the best esc/motor brands out there. Another would be the Speed Passion Reventon 1.1. Ultimately I think the fleta has the edge over the HW and I love both.
Took the liberty und edited it just a little bit. Sounds a little less exclusive that way (as there are a few other products on that level as well - at least in my opinion).
Dirk
My On-Road cars: Xray T4'18 | Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | ((Xray X1'18)) | Xray X10'16 | Yokomo SD SSG | ((VIP-Performance Vorlon/VTE))
My Off-Road cars: Yokomo YZ-2 DTM | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory>>>((?Yokomo YZ-4SF?)) | Kyosho Ultima SC6 | Tekno SCT410.3 | ((Xray XT2'18))
DirkW is online now   Reply With Quote
Old 03-27-2014, 02:52 PM   #5
blackshark3's Avatar
I have quite a few Reventons (Basically difference between that and Muchmore is the firmware, and I did load the MM software on the SPs) but they all die on the track for no reason. I know someone working at SP (who also OEM for Muchmore) and he uses HW, go figure.
blackshark3 is offline   Reply With Quote
Old 03-27-2014, 03:12 PM   #6
AL1983's Avatar
Thx for the replies! Helps me and alot of others with same questions.
Old 03-27-2014, 05:34 PM   #7
dan_vector's Avatar
Except the latest reventon 1.1 and the fleta pro both have independent hardware designs as well as bespoke softwares. Prior versions shared hardware however now that isn't the case.
Old 03-27-2014, 06:36 PM   #8
The SP is different to the Fleta Pro. Earlier versions of speed passion and fleta's were all Hobbywing Esc's.
The reventon is made just for speed passion, the fleta Pro is also its own esc.
I have the hobbywing, fleta pro and had a reventon. The revention was iffy, it was a pain to program. The HW is great, easy to use and feels quality, the Fleta is also easy to use and I find it very smooth and responsive. I use the fleta pro in my main car and the Hobbywing in the spare.
They are all good (the SP reventon less so) the orca is also meant to be very nice but I haven't used it.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 03-27-2014, 07:31 PM   #9
Such as......
Orion R10 Pro & Vortex VST2
Current 2wd off-road and TC world champion
LRP Flow Works Team & X20
Current 4wd off-road world champion and (I think) 2014 TC champ
Those can't be too bad a choice.
The orion is about to be superseded though, with a new version which is basically the guts of a HW V3.1 funnily enough...
cplus is offline   Reply With Quote
