Old 08-07-2005, 08:54 PM   #1
aN4rK1's Avatar
Default Is my Servo compatible?
Ok ill be recieving a MX-3S radio soon and on towerhobbies it says the Reciever, AIRL0805, has "Z-Type" connecters. Now the servo that i have, a Futaba S9404, has "J-Type" connectors. Can i use this servo with this reciver? iam putting another order in Towerhobbies iam just wondering whether i should put the the adapter in with my order?
Here is a link to the reciver
http://www2.towerhobbies.com/cgi-bin...?&I=LXGRF1&P=V
aN4rK1 is offline   Reply With Quote
Old 08-07-2005, 08:59 PM   #2
Jeff Brown's Avatar
I believe the Futaba servo will have a "flange" on the plug. Just cut it off and you are fine. No need for an adapter.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 08-07-2005, 09:09 PM   #3
Jeff
As above...
Check whether your servo has that flange on the plug.If no,then you're good to just plug it into your new reciver.Or not just shave it off.The flange has not signigicant use....Its just there as a fail safe mechanism,as some manufactures are afraid that you'll plug in the other way round and fry your electronics.
If you're having your new reciever,just check the polarity of the pins,whether it coinsides with your servo leads.
Ben.C is offline   Reply With Quote
Old 08-07-2005, 09:16 PM   #4
aN4rK1's Avatar
I just checked my servo, and yes it does have a flange. The connector looks like this int he pic:
http://www2.towerhobbies.com/cgi-bin...?&I=LXH444&P=7
So i jsut shave that off and plug it in right? No wires criss-crossing right? Cuz in this adapter (the one that i "supposedly" need):
http://www2.towerhobbies.com/cgi-bin...?&I=LXLX67&P=7
the red and black wires get switched.
Old 08-07-2005, 09:27 PM   #5
Jeff Brown's Avatar
You can double check the wire color order but years ago I believe everyone went with the same wiring configuration. It used to be a bigger pain but I think they wised up.
Jeff
JR and Futaba compatible? Interceptor Radio and Electronics 1 10-28-2007 12:35 PM
brushless compatible b-man777 Electric On-Road 5 07-25-2007 09:50 AM
Compatible RXs for Sanwa M8 art L Singapore R/C Racers 6 02-08-2007 11:04 PM
Newer Motors, ESCs, Servo, AIR compatible 75MHZ FM Receiver Cain R/C Items: Wanted to Buy 8 03-10-2005 10:07 PM
