Old 03-22-2014, 06:34 PM   #1
Exclamation steering shaking problem
hi guys*
i have a strange problem the video gonna explane every thing but one thing that i didnt mention it on the video but its in the description of the video that i change my one way diff to spool by welding the joints
here you go:
youtu.be/clCfDaDOvxU
i think cuz of the diff because every single thing is really fine and oiled*
Just add the http to the link
sos52 is offline   Reply With Quote
Old 03-22-2014, 07:16 PM   #2
DesertRat's Avatar
Can't fix that. Your universal joints are not designed to operate at that angle, you need a dual cardon joint of some sort or less steering angle... and as it's a drift car that's not an option to just run less steering angle.
If it makes you feel better, the car was doing it before you just couldn't see it.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 03-22-2014, 07:22 PM   #3
samnelso's Avatar
Your axle joints are binding. You can try double cardan style axles, commonly known as ECS or DCJ in the R/C world. However, with the steering extremes you're looking for I'm not sure those will completely cure the issue.
Edit: DR beat me to the punch
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 03-22-2014, 07:23 PM   #4
Trader Rating: 27 (100%+)
Nothing you can do about that. I think people call it "chatter"
The only thing you can do is buy aftermarket joints (called DCJ's) if they even have it for your car.
http://www.spec-r.com/default/index....3588a6e4f42d52
These are an example of what you'd be looking for. Notice where the joints come together, there's a piece in between. That coupling will allow better angles and prevent the chatter. Unfortunately, that's the only way to fix it.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 03-22-2014, 07:26 PM   #5
For desertrat:
I didnt understand the last part of your post I mean there wasnt shaking like that or at lest wasnt that much ...!!!
Also one more thing that I changed the diff to spool one and it was one way diff
also to samnelso
the same thing that before the spool diff every thing was ok
Old 03-22-2014, 07:32 PM   #6
DesertRat's Avatar
Originally Posted by sos52 View Post
For desertrat:
also to samnelso
Even when you ran a front diff the axle bound with each revolution, but the diff action smoothed it out and you it didnt hear it actually make noise. Standard joints are no good for that massive steering angle.
Old 03-22-2014, 07:33 PM   #7
Hyujmn
yea maybe you right but im wandering why this problem just happened right now !!!
What is the reason because before the problem happened every thing was ok
Old 03-22-2014, 07:56 PM   #8
A spool makes it worse. It happens even when you use a diff, but it's just not nearly as noticeable.
Again, nothing you can really do to stop it except buy after market parts for your car. I don't even know if they make ones that small.
Old 03-22-2014, 08:40 PM   #9
So the last decision now is ECS or DCJ
but additional question
what is the difference between them ?!
Old 03-22-2014, 10:01 PM   #10
ECS = DCJ
Xray calls ECS for "Equalized Corner Steering" but they're the exact same things as DCJ "Double/Dual Cardan Joints"
Old 03-22-2014, 11:35 PM   #11
chad_h's Avatar
Trader Rating: 22 (100%+)
xray names parts in their own, special, "luxurious" way.
chad_h is offline   Reply With Quote
