Old 08-10-2005, 02:32 AM   #16
Send a message via MSN to plucked_camel
Hi,
I've got a TT-01 as my muck around car but used to race it,
Check out ebay for hop-ups, I got quite a few GPM alloy parts from there
fairly cheaply. My recommendations are,
Carbon Upper Deck (Does make the chassis stiffer overall but no lower deck is avilable.)
Aluminium Steering Set (GPM version is just as good but cheaper)
Aluminium Front Lower Arm (go for GPM version also)
Front Aluminium Hub Carrier (GPM)
Also I had the Aluminium Propshaft
Ajustable upper arm
Ajustable Tie-Rods
and go for the Spur Gear Kit this way you have a lot more gearing options.
As for the dirt just blow it out with air or use a paint brush.
Hope this helps you
Nick.
plucked_camel is offline   Reply With Quote
Old 08-10-2005, 02:37 AM   #17
The Alu racing steering is really a worthwhile hope up if you plan on racing.
Ben.C is offline   Reply With Quote
Old 08-10-2005, 03:28 PM   #18
nekmiyevo2's Avatar
this is something that I heard, the many GPM option parts suck, but I dunno.
by the way, how about the motors? or the heat sink(the one I have always gets too hot i dunno if it is normal or not)
nekmiyevo2 is offline   Reply With Quote
Old 08-10-2005, 06:21 PM   #19
Well I haven't had any problems with the GPM Parts
As for the motor I purchased the TT-01 Aluminium Heat Sink
and noticed that while the heat sink is hot the motor performs
better than it did without it.
Old 08-10-2005, 09:00 PM   #20
I brought a tt-01 rtr in hong kong… it was great, but I am having some troubles with it
1) do rc cars get really dirty after they run on the streets?
2) how can I clean it easily (without using lots of money)?
3) is there any harder body that I can use? After a few crashes, the body starts to break apart.
4) what option parts or spare parts should I buy next? Now I have ball bearings, aluminum shaft, and adjustable upper arm.
Does these TT-01R kit came with ESC, universal shaft.Can anyone here that bought these kit tell me.
X1 CRT
KO HELIOS
9351,9451
STS.28
JP3
JConcepts
faiunie is offline   Reply With Quote
Old 08-10-2005, 11:38 PM   #21
A Ilievski's Avatar
Trader Rating: 39 (100%+)
it comes with the aluminum blue shaft and i dont think it comes with a esc
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 08-11-2005, 07:34 AM   #22
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
Originally Posted by 180sx
uh tamiya shells are crap, they break the easiest, go a frewer or protofrom
I have busted fewer tamiya shells than I have protoform. Tamiya shells seem to take alot of racing abuse. I have never used frewer so I can't say nothing about that.
Peace Aaron(W-W)
Schacht Design Works Trackside Hobbies Dirtheaven CRC Hobbies MidWest Tri-Clone RC Scoring Pro LiveRc.com 92 Zero Designs
Wicked-Wayz is offline   Reply With Quote
Starter Box Troubles. Mazda787b Rookie Zone 2 09-26-2006 10:50 PM
TS4N troubles TS4N Noob Australian Racing 1 06-23-2006 10:01 PM
Car troubles? acutts Electric On-Road 6 03-27-2004 06:16 AM
OS TR(P) Troubles Glenn Nitro On-Road 12 08-28-2002 02:38 PM
