Old 03-18-2014, 06:50 AM   #1
Default Choosing a motor.. What kv or turns?
Hi guys.. technology has come along way since i last raced on road..15-20years.. back then we just had a 540 based motor and a sliding esc.. the track that we run at is a converted netball court.. just a "medium grip asphalt" surface... fast but technical.. whats the best option for KV Ratings and what does it mean on a on road car.. higher the kv..more power? but heat may be a issue..
Cheers
black blood is offline   Reply With Quote
Old 03-18-2014, 08:59 AM   #2
DirkW's Avatar
kv is simply "RPM per volt" - so a 4500kv on 8V (random numbers here) should reach 36000 RPM (4500 x 8).
But it is not really standardized (so different manufacturers will come up with different numbers, even if their motors had identical performance), and in On-Road racing people tend to go by turns more than kv.
However, you need to tell us what type of car you're going to race on that circuit, and in what class (modified, stock, etc) before anyone can give you any reasonable tips.
Dirk
My On-Road cars: Xray T4'18 | Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | ((Xray X1'18)) | Xray X10'16 | Yokomo SD SSG | ((VIP-Performance Vorlon/VTE))
My Off-Road cars: Yokomo YZ-2 DTM | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory>>>((?Yokomo YZ-4SF?)) | Kyosho Ultima SC6 | Tekno SCT410.3 | ((Xray XT2'18))
DirkW is offline   Reply With Quote
Old 03-18-2014, 12:39 PM   #3
I'd have to agree with DirkW on what you plan on running and what c class. This will help narrow down what turn motor you should get.
Surface: F104 Pro Black Edition w/X1 parts, F104 w/upgrades, TB02, Exo Terra Buggy, Atomik V2MR, CR-01
Air: Tarrot 450 & Walkera Super CP
Futaba 4PLS and Flysky GT3C
Turnigy 9X
Measuredpath is offline   Reply With Quote
Old 03-18-2014, 01:51 PM   #4
I used to have a slider ESC as well 20 years ago! (damn those years fly by)
Had it in a old Tamiya!
Anyway....
Higher KV = More RPM so more top speed.
Lower KV = Less RPM but more torque (off-road)
For heat problems i find that my 7.5T gets hotter then my 4.5T since i need to crank up the boost/turbo alot more with my 7.5T to get the speed i want.
For starter i would go for a 10.5T. Hope this helps and enjoy
Lyrix is offline   Reply With Quote
Old 03-18-2014, 03:46 PM   #5
ThePanda's Avatar
Trader Rating: 65 (100%+)
you might want to buy a faster motor then, as pushing it with timing will never be as good a just a quicker motor.
just fyi KV is rpm per volt under no load theoretically. so it can't be used to compare motor very accurately.(already mentioned) turns is better, and for racing it is usually what is used.
ThePanda is online now   Reply With Quote
Old 03-18-2014, 05:13 PM   #6
Yep, but just one problem.. We always want to go faster! So you end up changing boost and turbo on the 4.5T too
