STOCK motor forum
#1456
Originally posted by ottoman
I dont pay much attention to motors that only win at the club level... I am more interested in the motors that go fast at a national event... sorry
oh wait your just a "pitman" not a driver but your a top of the line pitman
#1457
i will say team one mtors are probasbly the most consistent... if the motor doesnt spin higher then a 60 on the fanmtom.... it does not get packaged.... i have known the team one guys a long time.. and there motors are al i run... they also tune for me at the big races...
so whatever the dyno sheet in the package says... is what it read for them... the second rebuild is when a motor starts to breath... most of my team ones are 68-70 and my best this past year was a 73.....
i use hurricane gold brushes.. or putnam greens.. red and purple spring combo's.. the break in is the key to a good motor... that secret is sealed ha....
another trick for u guys to try.... we did it this past season and for some reason it worked well... i was helping the team one guys build up some motors for tghere team guys... we took regular 767 brushes.. and re serated them over the serrations...we did this on brqnd new brushes... out of 20+ motors.. the lowest was a 65 and 10-15 were 68 or better...
#1458
I don't want to start anything, but I do have to say the monster's with double purple springs are pretty fast. We have a more tight and technical track, and double purple seems to work best on it. That is what most people are using.
RC Anonymous, I am not saying you are wrong, as I have never tried your setup. You are obviously a guru at motor tuning!
Just my input,
etzkev
Just my input,
etzkev
#1459
cool Burbs tell Danny D. that Geoff C. says hi unfortunately i wont be down to Trackside till early November or so to get ready for the Novak race...ive stepped up into the foam class so i can get my butt handed to me even more now
something to remember also is that every dyno reads a little different ...i know my dyno reads about 8 power lower then almost everyone elses that i have tried(might be the programming? i use an aluminum flywheel and have it configured right i think)...RPM's are the only thing extremely similar to the others...torque is lower but that could be because of my power source also
etzkev...i usually run double purples myself since we have a pretty tight track here, lots of 180's and corners(a slightly more open track i run a different combo)..ive tried red and green and it just doesnt feel right to me going down the straight, it sounds like a spark plug isnt firing or something but thats with sedan of course
#1460
Originally posted by racenut123
Hobbyworld on the other hand is a different story....Btw,good to hear your car is working now.
Thank you....The car works really well until the roach-coach comes by....I ran some laps in the low 12s & one 11.9 early on but everyone's lap times faded a bit after that....I also got some brand new CS-32s which seem to work GREAT on the car. After midday around 2 o'clock it feels a bit too grippy & underpowered (cause it is)....It felt better running even harder tires but I'd loose the rear end too much. I think I'll try a red sway bar front and rear
#1462
Originally posted by R/C Anonymous
is that why your never on the podium your too busy looking at other peoples stuff?
I seak out opinions from people who know about motors... people who's motors I have seen run well in large events.
Once you have reached that level I will give your opinion the same respect I give the other top tuners. I have watched your motors run and IMHO your not there yet.
Good luck with you new motor tuning company
#1463
I think you guys have said it pretty well, Stiffer springs for more torque. This is why they work on a tight track. I prefer a red/green or 7.0/6.5 Fs units. It works for me. Fiddle stick available from KT.
Not assocaiated with KT or anyone else yadda yadda..........
#1464
weve had a guy here that has run mod. brushless FOAM in stock rubber class..tell me that isnt a noticeable difference in lap times i dont think he ever finished a race though ...those PVC pipes are killer on graphite parts
#1466
brian.. we were using the purple zzip one from integy...
R/C Anonymous
are u using a fantom dyno???? and if so .. did u or anyone at any time change the lenghth of the wire going to the battery or power source???? if the wire has been changed it can make the reedings different... i have seen guys add and remove wire to to get them closer to everyone elses readings... it has something to do with the efficiency of the power source....
as for the team one dyno.. it from my expirience reads about the same as most of the ones i have used...i would say middle ground.. some read a bit higher and ive seen some lower...
R/C Anonymous
#1469
I am not sure what this has to do with my post... maybe I should make it simpler for you.
#1470
Black Kat....Steve never takes that thing off the Mod setting.Sorry but he cheated.He ran 19turn with us at Ripon last Friday night and we didnt realize he was running brushless untill after.Thats why they call him the Badboy.
