Old 04-20-2004, 09:42 AM   #1366
jc510's Avatar
Red face .02
I have a bunch of most of these motors. First, stay with the epic/trinity motors. Currently they build the best stock motor. Which motor tuner is the tough question.
I have Birdmans, Paradigm, Team1, Fantom, and trinity tuned motors. In my opinion, Paradigm and Fantom tune the motor's the best. But most local tracks have a great motor tuner that will tune your motor for a fee. I pay $10 for each motor.
If I run them in my 1/12 they last about 10 to 15 batteriey packs. In my Touring car they last sometimes 2 runs. In my Off Road truck, about 3 to 4 runs.
I use the GreenMachine 3 for 1/12 only, touring cars will blow these motors up. The Monster is great for Touring, Offroad truck or buggy. The Binary is Great for 1/12, Touring or Buggy (this motor is said to be the most tempermental). The P2k2 is great for Offroad truck. Some racers like it for Touring cars, but the gearing is a big play. I've never been out motor'd by a P2k or P2k2 in my Touring car.
If I have to pick only 1 motor, it would be the Monster.
With that all said
lol
jc510 is offline   Reply With Quote
Old 04-21-2004, 01:27 PM   #1367
Cole Trickle's Avatar
Originally posted by Cole Trickle
This has probably been asked before, but it's hard to find...
Which bruches is good for the P2K and the GM3?
I'm racing on a tight technically carpet track. I'm using the standard springs.
I aint got enough time for a lot of maintenance, so it should be something, that lasts reasonably good. My second priority is torque.
Thanks.
Anybody...???
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-21-2004, 01:44 PM   #1368
rod_b's Avatar
Send a message via AIM to rod_b
In general, run the e-brush (Trinity 4499) with red + spring and green - spring. If you don't mind more maintenance, try Putnam green shunt brush on + and blue shunt brush on -
rod_b is offline   Reply With Quote
Old 04-21-2004, 07:49 PM   #1369
kvrc's Avatar
hey guys, check out my post in the for sale section. i have teflon washers for sale at a very good price. i wont clutter up this thread with the details.
kvrc is offline   Reply With Quote
Old 04-21-2004, 08:24 PM   #1370
BuddyB's Avatar
Send a message via AIM to BuddyB
Paradigm has probably given me the best results, and there brushes seem to work better than anything out there for my touring car. Just my 2 cents.
-Buddy B
BuddyB is offline   Reply With Quote
Old 04-21-2004, 09:09 PM   #1371
Default trimming brushes
I'm wondering if anyone has a a magic # for triming your brushes to get a desired % of wrap. I know every time you true the comm you decrease circumference and this will change your overlap. I don't have a dyno so I can't test this out for myself. Also is there a good method for balancing a comm. somebody suggested using razor blades on a level surface but i have yet to find a level that will produce usable accuracy let alone a cheap but good drill press.
Poppa Ray is offline   Reply With Quote
Old 04-22-2004, 12:25 AM   #1372
Thanks. I've found Team 1 4145/767 Serrated, cut Layd, for a reasonably price. Will they be harder on the comm? How about track performance?
Old 04-22-2004, 05:51 AM   #1373
sands's Avatar
Default Re: trimming brushes
if you have a dyno or a motor checker, take a run when you first get the motor from the tuner, then keep triming the brush until the amp draw gets back to that same number as you true the comm.
This is typically done at 2 volts, although other voltages will work. The key is consistency. At 2 volts, you should be between 8.5-9.5 amps or so. At least that what the guy at Putnam told me and it seams to work.
The problem is every motor is different. They will feal the same on the track with different amp draws. Gets hard to allways have the same amp draw on every motor and expect them to perform the same.
sands is offline   Reply With Quote
Old 04-30-2004, 08:44 PM   #1374
fatdoggy's Avatar
R/C Tech Charter Subscriber
Default suprising results
Somebody posted earlier that the p2k arm and the mvp can/endbell went well together, their right.
Mvp can and endbell
P2k pro arm
Stand-up brush hoods (aligned properly)
Bearings
36* timing
767 cut to stand-up (729's may be better)
Stock springs with a little tention added to the +
It's close to 19t performance. After 2 runs brush and comm wear is close to nothing, motor ran cooler then it ever did with the laydown brush hoods.
fatdoggy is offline   Reply With Quote
Old 04-30-2004, 08:59 PM   #1375
etzkev's Avatar
Send a message via AIM to etzkev
Default Re: suprising results
Mvp can and endbell
P2k pro arm
Bearings
36* timing
This is cool. I just have a few questions though. The 36* timing is stock...right? and how can you add stand up brush hoods?
Thanks,
etzkev
etzkev is offline   Reply With Quote
Old 04-30-2004, 09:10 PM   #1376
fatdoggy's Avatar
No the stock timing is 24*, I cut the tab and chocked it up to 36*. Stand-up hoods come with mod motors, I had a pair from an old motor I tore to pieces a while back.
Old 04-30-2004, 09:12 PM   #1377
etzkev's Avatar
Dang! Thats bigtime cheating man!
Old 04-30-2004, 10:59 PM   #1378
What does everyone think about the monster stock? I saw it at a local hobbyshop race and the TC3 running it was fast!!! It was the TQ for the intermediate class. I'm planning to buy a tc3 soon so I was wondering since the TC3 has good acceleration, should I get the monster stock and gear it a bit lower? Or get the p2k2?
rccardude909 is offline   Reply With Quote
Old 05-01-2004, 04:55 AM   #1379
fatdoggy's Avatar
Both the p2k2 and the monster are good motors. What is your local track like? For tight and techniqual - p2k2, for everthing else - monster.
etzkev - If I use it for anything it will be the 19t class, I won't be using it in stock.
Old 05-01-2004, 07:11 AM   #1380
etzkev's Avatar
Haha, thats funny! Do you think if I did everything but put the stand up brush hoods it would make much of a difference? Let me know what the difference would be.
Thanks,
etzkev
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
