Old 01-17-2004, 12:07 PM   #1276
Super Moderator
Grizzbob's Avatar
Well, I tend to do it based on how the comm looks after every run & how well the motor's still testing on my Robi, so it can be different for each motor. But in general, I'll go around 4-6 runs between rebuilds, & then I'll clean it, true the comm & change brushes(but there are instances where I've also needed to do it after 1 or 2 runs, when I accidentally overheated the motor, burned up the brushes). But overall, I'd 4-6 runs is about normal for the kind of high-silver brushes we use a lot these days....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-18-2004, 03:21 AM   #1277
Registered User
Originally posted by dontfeelcold
thats a big call
DontFeelCold....
Just kidding....I will be very happy if I can make it in the A's-main but there is nothing stopping me from trying. And with the information and help from the R/C Tech forum, maybe I can get that chances.
Cheers,
TheNoi is offline   Reply With Quote
Old 01-19-2004, 08:30 AM   #1278
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Default gearing and temps
Ok, I know gearing varies greatly ,but I need some help guys.I am running Paradigm motors one p2k2 based and one monster based.These are running on a fairly large indoor asphalt track with only one long back strait of roughly 60 ft.The track also transitions in elevation about 3 ft back to front.I am overheating the engines badly; in fact I burned the Monster completely up.I saw 200 degrees+ on the Monster and last nite I saw 170-180 on the P2K2. So could someone please just give a good starting gear range. I have heard 6.7 to 7.3 final ratio's and I have also heard 8.0 final gear ratio. Thanks for any help, I'm not looking for a specific number, just a range to stay in. I can get there after that.I hate burning up these engines they really run great.
SOuthernFRIED is offline   Reply With Quote
Old 01-19-2004, 08:44 AM   #1279
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Bflat-Yes its the same motor as the Orion Core's.
What kind of racing do you do Bflat?
Cole Trickle-What kind of racing do you do?How competitive are you local wise?
I cut every 4-6 runs by simply skimming the comm.This is better than waiting 10-12runs and having to take off alot more of the actual comm to get it clean again.Unless your running at a big event or at the top locally I run the same brushes for 2-3 cuts.Depends on the wear of the brushes.
Southern fried-What car are you running and what are you gearing the p2k2?What were you gearing the Monster?
This will help with the answer.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 01-19-2004, 08:56 AM   #1280
SoutherFried...
Do you narrow the brushes on your stock motors? If not, try it, it should make the motor run more effcienctly and/or cooler. I recomend triming about .015" off the trailing edge of any stock motor, perticularly high RPM stock motors. You can also try taking about .007" off both sides, but I personaly feel that is not as good as just triming the trailing edge...
DynoMoHum is offline   Reply With Quote
Old 01-19-2004, 09:04 AM   #1281
Dynomo.With the questions this forum has been recieving you might explain what the trailing edge is.
Old 01-19-2004, 09:06 AM   #1282
I have just started sedan racing(I am an off-road guy) so please forgive my ignorance.I am running a TC3....Ok don't laugh ,but I started the monster geared 28/70 and for the main I bumped it to 29/70.I smoked the motor but it was flat out hauling I got 3rd,that was last week.This week I ran the P2K2 and was geared 26/70. It didn't fry the P2K2 Paradigm but it was a good 180-190 as checked with the temp gun.Funny, I thought when I went electric I could get away from the temp gun...I still temp everything! Oh yeah, I run Pro match packs 1.65-1.69 and I use a INDI 16x9v6 to charge with.Thanks again guys for any help...I really need it.
To compare, my fast laps are 18.0 to 18.4 seconds, the fastest laps run are low 17's high 16's. Thanks again...
DynoMoHum- I have no idea how to narrow my brushes.I am running the brushes that Paradigm recommended with their motors.I usually run brushes for one nite (3 heats 1 main) and then change them and break them in for the next week.All of these motors were brand new on their first races.
Old 01-19-2004, 09:14 AM   #1283
K I would get use to the car before I would start worrying about lap times and so on.It may not be the motor or the batteries but how the car is setup and you getting use to sedan racing.
On the motor brushes do you replace them even if they arent worn out nor burnt?If so WHY are you doing this for club racing.That makes it very expensive.Like I said sometimes I will run the same brush for up to 3 cuts.It will depend on what brushes your running and how they wear(This will be different for EVERY driver due to driving style and how smooth they are).
The gearing on the Monster seems VERY HIGH.Expecially for a smaller track.You would actually drop 2 teeth below what a P2K2 is running at in that car when running a monster.
What brushes is Paradigm telling you to run?
What are you charging your 3300's at?
Im a offroader at heart myself.
Goodluck in the sedan scene.
Old 01-19-2004, 09:46 AM   #1284
I am replacing the brushes with the notion of re-serrating them later when I buy a serrator.
Brushes are Paradigm 21521 on the Monster and the P2K2.I am charging at 6 amps.
So where should I start with the gearing?
Old 01-19-2004, 10:03 AM   #1285
The Evicerator
Um, try a 24 pinion
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 01-19-2004, 10:05 AM   #1286
6amps is great.
Try 23-25 on the monster's next time and a 24-25 on the P2k2's.
I will email you or PM you on something else.
Old 01-19-2004, 10:25 AM   #1287
TexRacer-thank's alot I really appreciate your time trying to help me on this.
Old 01-19-2004, 10:34 AM   #1288
Best thing to do is gear like that and run the motor.If it's still pulling towards the end of the straight then you are doing good.Every Monster or P2k2 is different.So this will be a part of onroad you will just have to learn.
Goodluck out there.
Old 01-19-2004, 12:28 PM   #1289
Windtalkers's Avatar
Send a message via ICQ to Windtalkers
hi guys, does any1 run the tamiya stocks here?? if there is, is there any1 could let me know what's ratio ru running???
thanks..
Windtalkers is offline   Reply With Quote
Old 01-19-2004, 12:53 PM   #1290
yodace's Avatar
R/C Tech Charter Subscriber
I have a team orion Core stock motor? I have been running it for at least two weeks. I was wondering what brushs u guys suggest? How long do the brushs last that are it the motor now? They have a total of 10 runs on them already. You can't see the serations anymore.
yodace is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
