Old 10-24-2001, 07:21 AM   #106
HarshGuy's Avatar
hehe, yea I agree notice that when I posted my numbers all I was trying to illustrate was that they got much better than "out of the box" ...and in fact I said
Can't wait till real motor builders get a hold of this motor and start working their magic on it
...never claimed to be a motor builder, I can tune a motor OK but I ain't no Big Jim or Mike Reedy.
HarshGuy is offline   Reply With Quote
Old 10-24-2001, 02:43 PM   #107
stormperson's Avatar
Send a message via AIM to stormperson
i am going to be racing 4 cell stock, i got a GM3 pro and a p2k2, what should i do to the motors as far as break in, and springs/brushes? (i just got a ton of extra red's blue's and green's as well as alot of e-brushes, and i now realize it was a mistake but also some timed serrated brushes) anyway any advice would be great! thanks!
stormperson is offline   Reply With Quote
Old 10-24-2001, 03:44 PM   #108
tc3screamin's Avatar
Send a message via AIM to tc3screamin
alline the brush hoods, seat the bushings and break them in w something, metal polish toothpaste or trinitys bushing break in, center the arm and shim it so there is a little lash in the motor
tc3screamin is offline   Reply With Quote
Old 10-24-2001, 03:48 PM   #109
i ran the p2k for around 400 seconds at 3 volts and used the brownish trinity bushing oil. i also have some dry teflon stuff from paragon,should i use that instead?
Old 10-24-2001, 03:53 PM   #110
i have white lightning which is a waxy teflon lub but if u put more then half a drop to a drop it buts drag on the motor that u can see w a dyno and i rarely see a difference on the numbers using it so i dont usually put it on my motors
Old 10-24-2001, 04:24 PM   #111
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Originally posted by MDawson
hey Speedo,
Dieters motors are better too, so what?
BJ has made references to 100W at 20A. and @28A mid 120's.
Being 11pts off at 20A and 5pts at 28A is workable. We have only had these motors for a week.
What is your hot setup for a P2K2?
Well sorry, I didn't mean to insult your motor tuning expertise Just that an 11 percent difference is huge...I can feel a 5 percent difference with my P2K's. I'm just surprised...Maybe you got a bad motor...
Speedo is offline   Reply With Quote
Old 10-24-2001, 04:30 PM   #112
Trader Rating: 23 (100%+)
No insult taken. You seem to pass along a lot of learned information. What is the hot setup there Speedo for the P2K2?
What are your motors turning?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 10-24-2001, 08:18 PM   #113
Simon K's Avatar
I wish I had a dyno so I could race my motor numbers too
Need I say it, You Know I'm joking!
I'm being different and running an MVP, problem is there's no fast stock guys here to compare it to.
Anyone think a final drive ratio of 6.35 might be a bit high for a 4 minute race? I've done all the break in and brush tuning things, so it's running well under melting point ..
Simon K is offline   Reply With Quote
Old 10-24-2001, 10:20 PM   #114
Ok here is round two.
Constant Volt 7.00
RPM TORQ WATT EF AMP
23612 4.4 78 61 18
22593 5.5 92 65 20
21190 6.5 103 66 22.1
19608 7.9 114 64 25.1
18130 9.2 124 62 28.1
17296 9.9 127 59 30.1
TEAMORCA.SHOP
Old 10-25-2001, 05:17 AM   #115
what brushes/springs should i use for a 12th scale on a p2k2 and a GM3 (i am going to try out each motor, and see which one works the best)
Old 10-25-2001, 11:03 AM   #116
hey guys. just got a p2k2 last weekend. what are some tricks to get some rev's out of it. been in the hobby for a while, starting to get into motor tuning now. know of any online articles that explain the basics? any help is appreciated. thanx
TC3Killer is offline   Reply With Quote
Old 10-25-2001, 11:41 AM   #117
JB
JB's Avatar
Hey I have a P2k Pro and it has about 5 packs through it, most slow, only 2 on a practice day at a race track. I dont have a good comm lathe and im planning on racing on Saturday if it doesnt rain. Night race. First 'real' race and even though its novice, how much longer (# of packs, its a 1/12 with 6 cells @ 2000mah) should i go untill i try to find someone that would cut my comm at the track, if it needs it. I probably wont be around to racing till the new year sometime and during that time i could probably save up for a Hudy or something but im out of luck here.
I looked at the brushes and they werent discolored or anything BUT the serrations im estimating here, are maybe about half the original depth.
JB is offline   Reply With Quote
Old 10-25-2001, 02:20 PM   #118
what brush and spring combonation do u have on the p2k? the harder it is the sooner ull need to cut it, ive seen a com last months of weekend racing on soft brushes n ared/green spring and i only had to do 1 pass on it to tru it up
Old 10-25-2001, 02:23 PM   #119
JB
JB's Avatar
O wow. hehe
Uhm, theyre just the stock brushes and stock springs, im not sure about the brushes but the springs are just black (-) and red (+)
Its the exact stuff that came on the motor, its brand new besides the runs on it, nothings been changed.
Old 10-25-2001, 02:27 PM   #120
JB
JB's Avatar
Maybe i should put some lighter springs on it when its time to rebuild (soon). Maybe a lil more rpm's which is always helpful in 1/12 and theyre so light even if it takes some torq away, i already didnt need as much as it was giving me for my driving skill so far.
Any good moderatley high RPM preferably long lasting brush/spring combo's would be appreciated for the original p2k Pro. Im new to actaully trying to tune the motors in particular with different things and some advice for that would be helpful.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
