Old 12-12-2003, 02:08 PM   #1171
fowlerJr68's Avatar
i meant to say final drive ratio
thanx for the info
Steve
fowlerJr68 is offline   Reply With Quote
Old 12-15-2003, 09:35 PM   #1172
Omar's Avatar
Has anyone tried a red/purple spring combo on the monster or is red/red the way to go.
The track is a Full 96' X 52' flat road course
here goes a picture of the track
Pic # One Pic # Two
Omar is offline   Reply With Quote
Old 12-15-2003, 09:37 PM   #1173
Omar's Avatar
Old 12-15-2003, 09:50 PM   #1174
yodace's Avatar
R/C Tech Charter Subscriber
I'm getting the new binary stock motor this week and was wondering, what I can do to break it? Somebody told me to true it up first and use tribo to break it? What spring combo do suggest for offroad?
yodace is offline   Reply With Quote
Old 12-17-2003, 09:27 AM   #1175
Birdy... where are you? How about if you ask your question here?
As I said before... your question could be debated indefintely...
My personal opion is look at the 32 and 38 amp step numbers, choose the the motor with the highest power numbers at those two points.
DynoMoHum is offline   Reply With Quote
Old 12-18-2003, 08:20 PM   #1176
danjoy25's Avatar
Trader Rating: 37 (100%+)
Default Increasing timing
I am currently running a monster stock w lock timing (24 deg). What are the + and - of changing the timing as we have a race next month allowing for this mod to be done to any 27 turn stock motor?
danjoy25 is offline   Reply With Quote
Old 12-18-2003, 08:48 PM   #1177
danjoy25's Avatar
Default 27 turn outlaw stock motors
another thing is that if anyone knows of any commercially available 27 turn outlaw stock motors in the market. Needing to find out where to get them and what is the difference with the approved stock motors (monsters, P2k2) (spec and speed)
Regard,
IRT#177
Old 12-18-2003, 08:52 PM   #1178
nutfluff's Avatar
Send a message via AIM to nutfluff
Default Re: Increasing timing
I couldn't tell you exactly but I believe this quesion will best be answered at www.rccars.com
Good Luck...
nutfluff is offline   Reply With Quote
Old 12-19-2003, 03:20 AM   #1179
sosidge's Avatar
More timing will give more power, at the expense of efficiency. Go too far with the timing and you'll start losing power again.
Back in the day, stocks ran with 36 degree timing. I have no idea whether that setting would still work on current stocks which have been designed around 24degree timing.
Old 12-19-2003, 05:52 PM   #1180
I don't think you would be able to change the timing on a monster, due to the flat spots on the can/endbell
Rory is offline   Reply With Quote
Old 12-20-2003, 07:41 AM   #1181
I beleive Todd Putnam is selling the Epic 'outlaw' motors, and he is one of a handfull of motor tuners I would endorse.
It'd be hard to change the timing on a EPIC stock motor, and/or their outlaw.. You may be able to crank the come a tiny bit, but not likely enough to matter.
Reedy stockers you can easily cut the timing lock on the endbell and change the timing. However I don't think they will run any better at higher timing, but maybe... a MVP with narrowed burshes and cranked to 36 degrees or so, might run well... I've not really played with it too much.
Typialy you loose some peak power but gain more power at higher RPM and get better overall proformance useing a smaller pinon, when you crank the timing up from 24 to 36 or so.
Old 12-26-2003, 01:59 PM   #1182
Hey everyone, I race on a very tight carpet track. Can someone please tell me what motor has the most low end torque? And what are some tricks( brush types, spring combos, ect.) to get more low end torque out of the motor? Thanks for the answers.
magerz24 is offline   Reply With Quote
Old 12-26-2003, 03:28 PM   #1183
fatdoggy's Avatar
I'd suggest running one of the following.
P2k
p2k2
Mvp
Core stock
If you want to run a monster or a motor that is rpm based in a torque application you can put on hard springs, say purple + and red -, but the wear and tear on the brushes and springs will be worse.
fatdoggy is offline   Reply With Quote
Old 12-27-2003, 06:08 PM   #1184
Send a message via AIM to BlackFlagRacing
doubleddoubled
BlackFlagRacing is offline   Reply With Quote
Old 12-27-2003, 06:09 PM   #1185
Omar, where is that track at? I race down here in VaBeach. I may want to make the drive up there to race. rob
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
