Old 12-04-2003, 01:11 PM   #1156
hierog's Avatar
i've heard that the monster stock's run best at a final gear ratio of 7.1 to 7.3. Is this true? If so, do all stock motors, or all motors for that matter, have a "preffered" final gear ratio, or a gear ratio that works the best for that specific motor?
thanks
vic
hierog is offline   Reply With Quote
Old 12-04-2003, 01:23 PM   #1157
That would be highly dependant on the type of vehicle your using, and even the size of tires on a perticular vehicle type. It also depends on the type of layout you'd be running on... It depends on MANY factors.
Motors most deffintely will run better or worse depending on how you gear them. It's very critical in fact... However it's also very hard to tell you exactly what it should be, without knowing ALOT of details about what your going to be doing, and what your goals are.
DynoMoHum is offline   Reply With Quote
Old 12-05-2003, 12:13 AM   #1158
war11x's Avatar
Trader Rating: 17 (100%+)
thanks
vic
Hierog
try this site for your gear settings ( STARTING POINT )
http://www.rcracing.com/Page.cfm?InfoID=1100
remember the larger the track the higher the gear setting ( remembering to try and keep the motor as low to the ground as possible
also check out other sites for car settups and tips on diferent motors
all stock motors are not the same , ie the monster pro is a high reving motor( Large track ) where the ,say P2K2 great for low end punch (small track )
i run a rolout of 29.45 with my monster at our track
, but i run a rollout of with the P2K2 of 31.67 at other smaller tracks
the best thing is to spend some time at the track and test a few spurs / pinions and find what suites your driving / car
war11x is offline   Reply With Quote
Old 12-07-2003, 12:33 PM   #1159
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Ok, I have another noob question.I ran on a very short oval last nite.Since I am a off-road notro guy I can't help but temps sruff.My P2K2 PRO came off the track at 190 degrees.I also note my 3300 Pro-match NiMH reach 120 degrees at the end of a charge.Are either of these temps out of line? What temp should I see on the engine after a hard run? What is too high? Same for the batts.Thanks!!
SOuthernFRIED is offline   Reply With Quote
Old 12-07-2003, 02:17 PM   #1160
fatdoggy's Avatar
R/C Tech Charter Subscriber
190 is too high, my mvp gets into the 170's after a hard run. Use a smaller pinion.
fatdoggy is offline   Reply With Quote
Old 12-08-2003, 07:23 PM   #1161
Send a message via AIM to thenooee
Default better
What can I do to make the motor faster while keeping it legal?
thenooee is offline   Reply With Quote
Old 12-08-2003, 08:33 PM   #1162
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
That is very vague, what are you doing to it now? Brushes, springs, etc.?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-11-2003, 10:46 AM   #1163
Registered User
Default Rookie Question?
What is the benefit of using soft, meduim or hard springs on the brushes? Isn't there a sweet spot, speaking of clearance, between the comm and the brushes or do the brushes need to touch the comm.
Demetris Taylor is offline   Reply With Quote
Old 12-11-2003, 11:06 AM   #1164
sosidge's Avatar
The brushes HAVE to touch the comm, otherwise no current would flow through the motor and the motor wouldn't turn.
Heavier springs just limit brush bounce, but also add more friction.
So, a lighter spring will allow the motor to rev more, but with less torque (due to the brushes bouncing away more as the motor spins).
A heavier spring will keep up the torque (less bounce), but also decrease the revs (more friction on the comm).
Old 12-11-2003, 12:15 PM   #1165
Registered User
Talking Thanks Sosidge!
I told you it was a ROOKIE question.
Old 12-11-2003, 12:57 PM   #1166
Actualy... really light springs can make a motor have less RPM then medium tension springs. There is some point where the spring tension is too great, and it does sart to decrease the RPM due to friction, but that point is actualy alot higher then many people might expect.
The correct spring tension depends on many factors as well... I used to be one who beleived you should run the lightest springs possible... but lately I lean towards just the oposit... I put on the stiffest springs I can, untill there are signs that it's actualy decreasing power. Unfortunately you almost have to have a dyno to figure out what that point is... or have lots of time to do track testing.
Old 12-11-2003, 02:09 PM   #1167
Speedie's Avatar
the motor temp varies by motor some run hotter than others. 190 is a little hot try not going over 170. and your batteries could actually get a little warmer try increasing the peak cutoff by .01 till it reaches 130 to 140 after a charge.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 12-11-2003, 04:21 PM   #1168
Thanks for all the info guys...very helpfull!!
Old 12-12-2003, 01:14 PM   #1169
fowlerJr68's Avatar
whats a good combination of springs and brushes for the Trinity Binary. Also, what rollout should i use if i'm running rubber tires.
Steve
fowlerJr68 is offline   Reply With Quote
Old 12-12-2003, 02:01 PM   #1170
Trader Rating: 37 (100%+)
fowlerJr68.
rollout for rubber...i thought that was more of a measurement using foams...
anyway...i would try Team Hurricane 'Gold Brushes' with the purple/purple or purple/red springs. i've been experimenting with the binary and have one tuned with just as much power if not more then my best monster stock.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
