Old 11-25-2003, 11:40 AM   #1141
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
i went to the hobby shop yesturday looking for brushes
i asked for trinity 4499's
they gave me a set of 4499P
is there a diffrence???
i know that they have 2 wires comming out of each brush
is there anything diffrent about the brush itself??
Calvin Ng is offline   Reply With Quote
Old 11-25-2003, 05:02 PM   #1142
popsracer's Avatar
Default is there a diffrence???
Calvin Ng;
Other than having the dual shunts, they are the same compound.
If the brushes are going in a MS, pull the shunt wires through the slot on the motor tabs and solder them there. OR, one on the Tabs and one on the hoods. (there IS a difference)
popsracer is offline   Reply With Quote
Old 11-26-2003, 11:00 AM   #1143
mike_Webb's Avatar
Send a message via AIM to mike_Webb
The Parma One will ruin your brush Hoods and bend them also. You have to be very careful with it. Getting one like the Big Jim Bar is a better option.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 11-26-2003, 09:22 PM   #1144
evaa's Avatar
hi guys. i'm trying out a motor i got, its a banzai stock motor, i think its p2k or p2k2 based, not sure, but it looks more like p2k2 based, i tried in on the motor run-in on the pulsar and at 4.8 volts, it gave a reading of 7.4 amps and at 7.2, it had a reading of 8.7 amps, question is, what do those numbers mean? Tanx.
evaa is offline   Reply With Quote
Old 11-26-2003, 09:57 PM   #1145
mike_Webb's Avatar
Honestly... they really mean nothing.
I can have a motor that pulls 6amps at 4 volts and have it run better then a motor that pulls 12amps at 4 volts. Just use your pulsar to break in the motor and then use the track as a test for your motor. Gear the motor low for one run and then go up in a tooth until your track time laps fall off...then you will know right where to gear your motor.
Old 11-26-2003, 11:51 PM   #1146
TakDrift's Avatar
I try to go with a low amp draw motor which is more effecient and powerful than a high amp draw motor. A motor drawing low amp doesn't heat up as much which equals to more power throughout the race.
TakDrift is offline   Reply With Quote
Old 12-01-2003, 11:39 PM   #1147
fatdoggy's Avatar
R/C Tech Charter Subscriber
P2k arm in Mvp can. Does anyone know what brush spring combo works well?
fatdoggy is offline   Reply With Quote
Old 12-02-2003, 11:26 AM   #1148
Registered User
Calvin Ng's Avatar
Since stupid trinity decided to put a more softer (crappier) comm on the monster stock
what are good brush and spring combinations for it?
Old 12-02-2003, 12:11 PM   #1149
Suspended
Trader Rating: 28 (100%+)
Are you sure of this calvin?
racenut123 is offline   Reply With Quote
Old 12-02-2003, 12:58 PM   #1150
As far as I know, the same brushe you'd use on any other stock motor should work just fine on the Monster stock motor. I typical use the new Trinity 99+ compound or Putnam brushes. It seems everyone has their favorite brushes... I personaly feel you can make any decent brush work, sometimes differnt brushes like differnt springs, but ussualy you can find some combo that works reasonably well if you try.
DynoMoHum is offline   Reply With Quote
Old 12-02-2003, 01:23 PM   #1151
fatdoggy's Avatar
Calvin Ng - If the putnams arn't working for you then just throw in some 767's.
Old 12-03-2003, 01:41 PM   #1152
Ted B.'s Avatar
Send a message via Yahoo to Ted B.
Originally posted by pro3racer
whats the equivelent to a 767, please tell me its a trinity 4499.
I believe the CLOSEST thing to a 767 is the Putnam Blue............................. probably very similar compounds
Ted B. is offline   Reply With Quote
Old 12-03-2003, 04:15 PM   #1153
popsracer's Avatar
Guys;
The statement of Trinity using a softer Copper in the coms of the newest motors, is based on the feedback of several different experienced racers.
This has NOT been confirmed as fact, but is offered as a probable reason to why Putnam brushes do not seem to work as well in the newest samples of EPIC motors as they have in the past.
The Good news is that in these newest batch of motors, Reedy and Trinity brushes seem like they now work better. (go figure?)
Old 12-04-2003, 08:34 AM   #1154
Interesting...
I've not purchased any stock motors in about a year... so if this has happend, I woldn't have noticed it myself... This is the first I have heard of it however, and I frequent alo of differnt web sites...
Old 12-04-2003, 09:37 AM   #1155
Ted B.'s Avatar
So your saying that the comms are made to soft now?
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
