STOCK motor forum
#1096
my local hobby shop doesnt sell putnam brushes....
how bout reedy 767's
#1097
so purple purple springs are no longer better, and reds are the way to go?
#1098
Red springs allow the Monster stock to rev a bit more which is better on a longer track where top end is more of a concern.
#1099
#1100
Shimming
n00b question: I just cut the comms on two montser stock motors. What is the proper way to shim the armature? How much total end play should I have and should it be divided evenly?
Thanks,
John
Thanks,
John
#1101
Ok another NooB question.I am running a P2k2 Pro.I have raced exactly once.Anyone willing to part with some advice on getting the most out of this engine?How does it compare to others? Also I am running a TC3 also brnad new to me.I race Pro off-road Monster Truck ,but I have gotten into the electric touring cars to keep me busy during the winter..Thanks for any help guys!!!
#1102
Jcrouse.The common process is to take all the shims out and turn the motor to it's side.Brushes and Springs are NOT IN at this time.You then spin the arm and see where it centers up.After spinning it pull the arm down and measure the play in it.Spin it again and push the arm up in the can measuring the up travel and shim accordingly.This centers the arm in the magnetic field of THAT particular motor being they are all different.
Goodluck with the motors and if racing have fun.
#1103
P2k2 is a nice motor.If it's a pro version it will have trinity"e" brushes in it.This is a good all around motor.If you have BIG LONG straights then it may get beat top speed wise by a couple of other motor's out there.But the P2K2 is a great all around motor and nice for smaller to mid sized tracks.If your new to electric I would just keep running the motor and find someone to cut the comm on it for you about every 6-8 runs.This keeps the motor fresh and cutting it this early or skimming the comm will actually make the motor last longer than running it soo much it gets a deep pit in the arm making you take MORE off when cutting it.I would replace the brushes when they get discolored,burnt or noticable wear.
Goodluck.
Goodluck.
#1104
Re: Shimming
Thanks,
John
Thanks,
John
#1105
Originally posted by SOuthernFRIED
Ok another NooB question.I am running a P2k2 Pro.I have raced exactly once.Anyone willing to part with some advice on getting the most out of this engine?How does it compare to others? Also I am running a TC3 also Brand new to me.I race Pro off-road Monster Truck ,but I have gotten into the electric touring cars to keep me busy during the winter..Thanks for any help guys!!!
AND, no matter what anyone else says. ANY Motor can be used on any track. You just have to know how to Gear and tune to to overcome a Motors weaknesses.
#1108
Thanks for the tips guys.I'll try the Putnam's..where do I get them.Do they have different styles? or just one type? Thanks again!
#1110
is gearing a monster stock the same as a p2k2 pro???
thanx guyz
thanx guyz
