Old 11-03-2003, 05:02 AM   #1051
sands's Avatar
best way to go fast is to practice.
When you can get around the track for 5 minutes without crashing, then you can spend money on go fast bits.
Take a look at the good guys at your track, most of them are probably running nothing special.
You'll need to learn proper maintenance, motor building, battery care, and car setup first.
Hope this will save you some cash!
sands is offline   Reply With Quote
Old 11-03-2003, 05:29 AM   #1052
fatdoggy's Avatar
R/C Tech Charter Subscriber
sands - You hit the nail on the head, there is a guy who just started racing at the track I usually run at, he's good, dam good. One of his packs is a radioshack 3000nimh pack this does not slow him down one bit.
fatdoggy is offline   Reply With Quote
Old 11-03-2003, 05:44 AM   #1053
horniez's Avatar
Originally posted by andrew12ph
hi guys! im a newbie for this hobby i don know if this a right section to ask? how can i make faster my rc its tl01 and tb01 model? any suggestion or parts that i will modified? thanks in advance!!!!!
Andrew
yup, practice definately...
not to mention tat u should have in-depth knowledge of your car...
know it's limitations so tat u know when to push your car...
a good mod for TL01 is
1) ball bearings (better efficiency)
2) Long arms (more stability)
hope this helps
horniez is offline   Reply With Quote
Old 11-03-2003, 10:32 AM   #1054
sands's Avatar
Any body know what reedy 767s and 766 are equivelent to for Trinity brushes?
Or asked another way, what trinity brushes work well with Orion Core's or MVPs. (I plan on following the general setup advice on about.com to cut the width of the brushes to square. Is this a good starting point? What about leading edge or trailing edge cuts to alter the timing?)
Old 11-03-2003, 11:44 AM   #1055
highwayman's Avatar
try trinity's 4499
highwayman is offline   Reply With Quote
Old 11-03-2003, 11:58 AM   #1056
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
I was told the 767's are about equivlant to Trinity 4499's and the 766 are the about the same as the 4503... I don't know if this is true or not so I can't say it's 100% right.
Flash Gordan is offline   Reply With Quote
Old 11-03-2003, 12:09 PM   #1057
Mercury Racer's Avatar
i tried team paradigm's 2152 brushes on my monster stock and it was a very good combination.
Mercury Racer is offline   Reply With Quote
Old 11-03-2003, 12:16 PM   #1058
popsracer's Avatar
Default Bru8shes
Guys;
Trinity has some new Brush charts in most of the recent R/C magazines. They're useful for comparing Trinity brushes.
popsracer is offline   Reply With Quote
Old 11-03-2003, 12:17 PM   #1059
Andrew
Aside from practice, here are some of my personal suggestions:
Check out the fast guys at the track... what car kits are they using, that's usally a good guage of what cars are good to start with.
Don't be afraid to ask them, they'll usually be friendly enough to help you with the basic stuff.
Nothing beats practice, practice and more practice.
Old 11-03-2003, 05:06 PM   #1060
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Sorry to say sands but there isnt a comparable when it comes to trinity brushes.They are just made up different.Trinity Brushes DO NOT work well in Reedy,Atlas,Corally or Top Based motor's(All made at the same factory).
I have tried a bunch of trinity brushes and cant get the same performance.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 11-03-2003, 05:35 PM   #1061
sands's Avatar
I've heard 767s are good, how do they compare to 766s? Run them polarized?
Or putnams?
What's the recomended setup for MVPs or Orion Cores?
Old 11-04-2003, 05:26 AM   #1062
fatdoggy's Avatar
sands - I run 767's in my Mvp, stock springs with a little taken off the neg spring(just a tad). I've done all the proper prep work(align brushes and the rest) and my motor can keep up with *almost* any monster I've ever raced against. It can pull harder out of the corners and has equal speed on the straight. If you want your motor to scream then do the laydown to stand-up brush trick(cut down laydown face to look like a stand-up) but since I don't race on tracks where rpm rules, I'd rather keep the extra torque and stay with full face brushes.
Old 11-04-2003, 09:34 AM   #1063
sands's Avatar
what rollout works for you on the MVPs? I run a tight twisty track in touring
Old 11-04-2003, 09:43 AM   #1064
Putnam's and trinity brushes work really well in Epic Based Motor's.
I havent had ANY luck with Putnam's or Trinity's in Top(Orion),Atlas(Integy),or Reedy Stock motor's.
I would run the 767s like he's stating and maybe even drill a hole in the middle of the positive side brush.
Old 11-04-2003, 09:53 AM   #1065
sands's Avatar
On epics, a hole will give a higher rpm and more efficiency at the sacrafice of torque, same for top based motors?
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
