Old 10-22-2001, 11:44 AM   #91
Default New to TC
I am also a newbie to this eletric on road. I run mostly offroad gas, but need some practice for the winter. Got a XXXS like mostly everyone, but know little about it.
cubie is offline   Reply With Quote
Old 10-22-2001, 05:35 PM   #92
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Mike, I said it was tight, and it is fairly technical.
Gear for the corners, not for the straight.
Speedo is offline   Reply With Quote
Old 10-22-2001, 05:43 PM   #93
tc3screamin's Avatar
Send a message via AIM to tc3screamin
does ne one calculate there tire height into their gearing? it can help u to fine tune especially when u r running foams. i run on a tight hairpin oval and run between a 28 an 29 roll out with my tire ratio. (3.14xtire height in mm) devided by the fgr
tc3screamin is offline   Reply With Quote
Old 10-22-2001, 05:52 PM   #94
R/C Tech Founder
That's a good point...
Most of us around here run rubber exclusively -- at least in our TCs -- but if you are running foam it makes a difference, since tire diameter can vary greatly from set-to-set or from run-to-run.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 10-22-2001, 05:55 PM   #95
jcr
what do you guys think of the Orion Chrome Stock motor?
jcr is offline   Reply With Quote
Old 10-22-2001, 09:17 PM   #96
Jack_L's Avatar
I use the chrome RS. I think Iam the only guy that used it on saturday night and made the 'A' Main with un matched, 1yr old RC2000's! It's a fast motor, but i miss my p2k.
BTW, jcr, are you "Team JCR" that i know?
ttyl
Jack_L is offline   Reply With Quote
Old 10-23-2001, 12:53 AM   #97
Cole Trickle's Avatar
I've only tried it on tight narrow tracks. But I think it's great motor, durable, fast and with pretty good torque. However, the P2K is a little better. Geared equally to the Orion, they are equal. But the P2K can take one more tooth on the pinon, and then it both got better top end and better acceleration.
Cole Trickle is offline   Reply With Quote
Old 10-23-2001, 02:48 AM   #98
Trader Rating: 69 (100%+)
i use this motor on a short technical track. it has good torque and moderate top speed when i gear 27/72 on a tc3. i tried it on a fast sweeping track but it lags behind GM3's on long straights. i guess its ideal for shorter tracks.
marvi is offline   Reply With Quote
Old 10-23-2001, 04:55 PM   #99
Moderator
Speedo's Avatar
They seem to be a torquy motor...
Old 10-23-2001, 08:01 PM   #100
Trader Rating: 23 (100%+)
Originally posted by HarshGuy
I ran the P2K2 motor last night and it ran great! Can't wait till real motor builders get a hold of this motor and start working their magic on it. Here are numbers off of my Competition Electronics dyno:
Here are the stock numbers straight out of the box:
RPM Torq Watt EF Amps
18098 4.3 58 64 13.3
16668 6.1 75 64 17.3
15782 7.2 84 61 20.0
15127 7.9 88 59 21.8
14279 8.6 91 56 23.8
13375 9.5 93 52 26.0
And here are the numbers after a fellow racer (sting) & I spent a couple of hours on the motors (this is the motor the way I ran last night):
24941 2.4 45 50 13.3
22477 4.6 77 65 17.3
20543 6.2 94 69 20.0
19704 6.9 100 67 21.8
19080 7.6 108 67 23.8
18184 8.5 114 64 25.9
One of our local motor builders (acloco) is taking the motor and seeing what he can work with it.
Harsh,
What did you use for Constant Volts?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 10-23-2001, 09:05 PM   #101
HarshGuy's Avatar
HarshGuy is offline   Reply With Quote
Old 10-23-2001, 09:07 PM   #102
seems like the p2k2 likes softer brushes on the neg side
TEAMORCA.SHOP
Old 10-23-2001, 09:11 PM   #103
So far....
22314 4.8 80 65 18.1
21254 5.6 89 65 20.0
20174 6.6 99 66 22.1
18923 7.8 109 64 25.1
17411 9.1 118 61 28.1
16581 9.9 122 59 30.1
TEAMORCA.SHOP
Old 10-23-2001, 10:01 PM   #104
Moderator
Speedo's Avatar
that doesn't look so good. big jim's motors seem to be in the 100 watt range at 20A
Old 10-23-2001, 10:11 PM   #105
hey Speedo,
Dieters motors are better too, so what?
BJ has made references to 100W at 20A. and @28A mid 120's.
Being 11pts off at 20A and 5pts at 28A is workable. We have only had these motors for a week.
What is your hot setup for a P2K2?
TEAMORCA.SHOP
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
