Old 06-13-2003, 09:28 PM   #961
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Hey guys quick question...
If I have a stock motor that I plan to run in Touring car, if the motor on the dyno seems to be more of an RPM motor then torque, would you go up or down in gear...
If it matters I am running a TC3 with 64 pitch, 100 spur...I am currently at 36 pinion (6.8 gear ratio)
Thanks in advance...
TigeRyan is offline   Reply With Quote
Old 06-13-2003, 10:22 PM   #962
Tom
Tom's Avatar
EVAA-- Keep that p2k2 in the 6.6-6.7 range and you will see a difference!! Hope this helps--AL
i run my monster at 6.1-5.7
try p2k2 at around 5.9
Tom is offline   Reply With Quote
Old 06-14-2003, 12:15 AM   #963
Super Moderator
Grizzbob's Avatar
TigeRyan, how big is the track you run on? Does it have some long straights & sweeping corners, or is it smaller & tight, or something inbetween? The type of track is(IMHO) the single biggest factor in how you determine your car(& motor's) gearing. But if it helps any, I can say that I run my TC3 on a medium/small track with a decent balance of straights, sweepers & technical sections(average lap times in regular stock is about 10 seconds, in Expert Stock the times come down to the low 9's), & on it I gear my Monster at about an 8.6:1 final(that's a 100 tooth spur & 29 tooth pinion). Seems to be very close to right for that motor(& of course, it is a high-rpm motor). If you can give us some info on your track(& let us know just which motor you're talking about), we might be able to give you a decent starting point....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-14-2003, 12:20 AM   #964
Location: Built By The Racers For The Racers. Corona CA
Default Too Hott?
I just picked up a Monster Stock for my TC3. I ran a 72 spur and 25 pinion. The motor temp was 193.5 degrees after a 6 minute run.
Is this too hott? What spur/pinion combo works best for this motor.
I here 6.9 is good. I think with the tc3 that is 72s/26p
I dont know, would ya help a rookie out?!?
R/C HEAT is offline   Reply With Quote
Old 06-14-2003, 06:43 AM   #965
for electric motors you cant really tune them to run within a certain temp. range like you can gas engines. but i would say close to 200 deg. is too hot. just make sure you are not discoloring the brushes or comm. gear the motor accordingly so that it tops out 3/4 or a little past down the longest straight on your track. this would be the best procedure since there is no optimal gearing combo for any motor. you will probaly need to gear the monster a couple of teeth lower than you would other motors you have run at your track. last time i ran stock was in carpet season so i cant help you out. hope this helps.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 06-14-2003, 02:50 PM   #966
highwayman's Avatar
my monster stock just got fried this afternoon, was running 128 spur 32 pinion on my G+...
any comments on why this happend?
highwayman is offline   Reply With Quote
Old 06-14-2003, 03:01 PM   #967
TigeRyan's Avatar
I am running on a unprepared Parking Lot track, medium size, but usually pretty open and non-technical...but the layout does change from week to week...
The motor is a Monster Stock....
Thanks!
John
Old 06-14-2003, 06:36 PM   #968
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
how hot does your motor get?
Calvin Ng is offline   Reply With Quote
Old 06-14-2003, 06:43 PM   #969
Registered User
Calvin Ng's Avatar
how low have you gotten the monster to be at without frying it?? how hot does it get?
Old 06-14-2003, 07:29 PM   #970
Korey Harbke's Avatar
It sounds like you were overgeared... But this is just my perspective.
-Sushi Boy
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-15-2003, 12:04 AM   #971
Super Moderator
Grizzbob's Avatar
Ok, TigeRyan, if it's about the size I'm thinking of(kinda like the one I run on), then I'd suggest you start conservatively, with a bout a 7.8-8.0:1 final(start with a 31 or 32 tooth pinion), & try a run in practice. Pay particular attention to what part of the straights the car tops out on(you may be able to hear it since it's a TC3, I can with mine), ideally I'd prefer it to top out about 80-90% of the way down the longerst straight. If it doesn't seem to top out, then maybe you're still overgeared, or if it happens too quickly, then you can go to a bigger pinion. Just go up or down 1 tooth at a time until the car "feels" right, & then pay attention to how it does out of corners, if you feel it bog down or if it accelerates well & make further adjustments if neccessary....
Bob Seay
Go Pokes!!!
Old 06-15-2003, 06:03 AM   #972
Tom
Tom's Avatar
about 40-50 degrees C at 6.1
when i ran at 6.5-7.0 the motor was cooler then my tires at the end of the race
air temp is around 10-15 degrees C (race at night and its winter)
but my orion core runs at 90 degrees C
Old 06-15-2003, 08:47 AM   #973
diesel's Avatar
Default Electric Newb
Hi there,
I am pretty new to electric touring and intend to run a stock motor on my Xray T1 which i bought 2nd hand. I know nuts about the gearing ratio between the spur and pinion. I have this brand new Tamiya Dyna run racing stock motor. Can someone please tell me how many turns this motor is and wat no. spur and pinion gear i should use? Thanks for any advice in advance. Cheers.
diesel is offline   Reply With Quote
Old 06-15-2003, 01:35 PM   #974
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
That dyna run stock is 23x1. Gearing depends on track, temperature, etc etc. I'd probably start around high six low sevens then adjust
minicooper is offline   Reply With Quote
Old 06-15-2003, 02:55 PM   #975
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
diesel i would go out and buy yourself a rebuildable stock motor like a p2k2 or monster stock. Much less hassle...
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
