Old 06-11-2003, 07:31 PM   #946
xxxtracer32's Avatar
even brushes and springs?
xxxtracer32 is offline   Reply With Quote
Old 06-11-2003, 08:00 PM   #947
Super Moderator
Grizzbob's Avatar
No, brushes & springs are the exception to that rule. You can run ANY brushes & springs you want, I believe, you just have to be aware that some will be a lot harder on the comm than others...
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-11-2003, 09:54 PM   #948
big al's Avatar
I don't mean to come off as a know it all ( which I am not), but I find that if I use 767's or 4499's or putnam etc,etc.... NO single brush makes a big of a difference in the overall power as properly aligned brush hood. I have both a p2k2 and MHS, and they both rip. When compared, for example, 4499's & putnam blu/grn combo, you are only looking at a 2-3 watt advantage on average. I think it becomes a case of splitting hairs. An extra 3 watts is a good thing,but so few of us are able to run a flawless qualifier where this 3 watt advantage is not wasted. Now this approximation is from a post by Big Jim greenemeyer, so I don't doubt it. As I stated before, both my stockers are quite fast. each has NO blackening at all. I put 98% of my tuning efforts to attain this and feel it is probably one of the most overlooked (and most important) steps. A little food for thought for my fellow racers. --Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 06-12-2003, 09:12 AM   #949
popsracer's Avatar
Default Power advantages
big al;
I WISH that I could find a 3 watt advantage. ONE watt makes a noticeable difference in the Car.
For Brushes, the Putnam blue/green have given the best performance in my MHS.
I haven't bee able to find another motor that runs as good yet in my Car, yet.
popsracer is offline   Reply With Quote
Old 06-12-2003, 05:21 PM   #950
howard hudson's Avatar
R/C Tech Charter Subscriber
Default Re: Power advantages
Originally posted by popsracer
I haven't been able to find a motor that runs in my Car, yet.!!!!
SLOW POKE
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 06-12-2003, 05:45 PM   #951
big al's Avatar
That's strange pops, I went back to 4499's (had putnams before) and noticed a significant top and bottom end improvement. I actually went up to a 7.0 (from a 7.2) ratio. Honestly,if someone was handing out stock motors with a 3 watt improvement over mine....hell yeah, I'd take one, my point is that I feel proper hood alignment will give an overall higher improvement than just a brush change would. Assuming you already have "race" quality brushes. Either way Pops, one of these days I gotta make the trip down south and get myself a good ol' fashioned a$$ kicking. I've gone to the SoCal web page and that place just looks cool.
--Al
Old 06-13-2003, 09:37 AM   #952
evaa's Avatar
Originally posted by defMondo
There is more to motors then RPM, the most important things are power and torque.
How do the motors compare on the dyno in terms of power and torque.
I have a couple of motors with sticker numbers which are relatively low by comparison to others but the motors still run very nicely if you gear it properly.
Also depends a lot on your track, it it's tight and twisty you want something with lots of power and RPm's aren't very important.
Tony
tanx 4 d input, irecently ran on a tight carpet track and had the chance to test what i perceived was my strongest and weakest stock motors, namely the mvp reedy and banzai p2k2.
i timed my runs and my runs on both motors were nearly identical, i was hoping for a bigger gap between the two motors but was surprised that the mvp was quicker by only a couple of tenths.
i havent had the chance to change the gear ratio, i used 120/37 spur pinion combi, 4 my 414M thats roughly a 6.9 final ratio. i used the same pinion spur combi for both motors.
i'm racing tom in the same track and will try to mix and match gear ratios to find the best set-up.
i guess u were right, tanx 4 d info.
evaa is offline   Reply With Quote
Old 06-13-2003, 09:44 AM   #953
evaa's Avatar
Originally posted by schumacher
by definition power = torque x rpm
(its actually power = torque x angular speed but i have simplified it)
so the number to look for is power. If you have a motor which has lots of torque then it needs gearing longer and a high revving motor requires shorter gearing.
sanj
i'll take that into account when i race tom. i tested both the banzai p2k2 and the mvp yesterday and timed my runs, both run times were within tenths from each other. gearing was 120/37. that comes out to roughly 6.9 final drive ratio. tomorow during qualfying i'll try to experiment with gearing too see what gearing is optimal for both motors. i guess the clock does not lie, was about to sell the banzai, now i think i'll keep it and use it. tanx
Old 06-13-2003, 09:59 AM   #954
evaa's Avatar
Originally posted by syntex1
evaa what DYNO did u measure it on?
dose it only give rpm readouts?
another point to factor in the older the motor is the more rpm it produces this is due to weaker magnets or smaller comm
i forgot what the dyno was, but it gave rpm, condition and amp read-outs.
i believe the p2k armature (the older motor) is near its last few cuts, maybe thats why it churned out more rpms.
btw, i tested the banzai p2k2 and the mvp ydayand was surprised to find out that my lap times were nearly identical, the mvp was up by only a few tenths on the banzai. i'll race tom and will try experimenting with other set-ups in terms of gearing to find out which ratio works best with what motor.
tanx 4 d info
Old 06-13-2003, 10:03 AM   #955
evaa's Avatar
Default Re: Motor Dyno numbers
Guys;
Generally, You want to pick Motors with the Highest Power #'s. Torque will usually follow the Power, up or down. Proper tuning can help, but there is only so much you can do to a Stock Motor
and keep within the rules.
As for finding that "Magic" Motor, it's all luck of the draw unless you have several dozen to Dyno and pick and choose the best. (now who might be able to do this?)
Just my .020
ur right! i agree 100%. tanx for sharing ur thoughts
Old 06-13-2003, 10:09 AM   #956
evaa's Avatar
Originally posted by spaz456
if the motor that didnt dyno so well seems to be producing better performance on the track then chances are it is producing its power more in the usable amp draw range for your type of racing, as opposed to the other motors you have dynoed which produced better numbers but there power may be in an amp draw range those motors may never see in the type of racing you are using them for. just something to keep in mind.
tanx, i did some testing yday and found out that the mvp was quicker by a few tenths only over the banzai p2k2.
Old 06-13-2003, 11:23 AM   #957
sosidge's Avatar
There's no need to quote everybody and give essentially the same reply - one full answer will do.
Old 06-13-2003, 12:16 PM   #958
big al's Avatar
EVAA-- Keep that p2k2 in the 6.6-6.7 range and you will see a difference!! Hope this helps--AL
Old 06-13-2003, 08:02 PM   #959
evaa's Avatar
oooops! sorry for that.
Old 06-13-2003, 08:04 PM   #960
evaa's Avatar
i'll try that, will give results l8r.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
