Old 11-14-2002, 11:28 PM   #841
popsracer's Avatar
Default Waffle pattern brushes/Dyno Questions
Anyone tried the waffle pattern brushes on a P2K/P2K2.
If I buy the Fantom Facts Dyno, what else do I need to buy to hook it up to my PC.
What features does the Fantom Dyno offer over the cheaper Indi Dyno. (besides PC compatability)
Thanks,
popsracer is offline   Reply With Quote
Old 11-15-2002, 05:12 AM   #842
RC Nitro's Avatar
Pops: Never tried the brushes. Fantom, comes with all the hookups. You just have to register the sw with Dave C to print data and make changes. The indy dyno is not a "true" dyno. On the Fantom, look at the table results and not max numbers. Stock motors run between 20 - 28 amps. Tune in this area. I use a TD45 now so that is all I can offer. Sold my Fantom this summer. I use Tribo. Had good luck with them. JMO I put a drop of oil on my shims and use a teflon on both ends if possiable.
psycho is right not to tight. Had someone here at the track do that this summer. lost power due to drag and less rpm. Removed extra shims and motor came alive.
RC Nitro is offline   Reply With Quote
Old 11-15-2002, 08:04 AM   #843
i just bought a monster stock motor 1 st run ran a 31/118 3.6 ratio on debbies r/c world parking race they have a 110 ft. straight away alittle over geared it realy kicked butt at the end of the straight 2nd run i ran a 30/118 ?ratio this was the gear to run nothis motor today. i'm very pleased with the peformanceof this motor :
sorry xxx-s
bubbaicm is offline   Reply With Quote
Old 11-15-2002, 10:39 AM   #844
psycho's Avatar
Default Re: Waffle pattern brushes/Dyno Questions
I bought a Fantom dyno because of the instantaneous data that you see in the table and the graphs are pretty too! It works well as a tuning aid. You can see small changes that you wouldn't see on a T35. I decided against one of those dynos that you have to do the math to figure out the numbers because you only get the peak data.
psycho is offline   Reply With Quote
Old 11-15-2002, 11:04 AM   #845
popsracer's Avatar
Default So whats the best dyno for the $$$
My P2K2 is apart for a skim cut, so I will recheck the spacing. I haven't been spinning the arm to check spacing, but it seems to find it's center ok without. I will try spinning this time.
So what is everyone's preference in motor dynos, that are available in the USA?
Thanks,
Old 11-15-2002, 11:12 AM   #846
RC Nitro's Avatar
Dyno preferance: I had the fanotm and did not like it. Sold the unit and bought a TurboDyno used. Been very happy ever since. YOu can find them on the boards and e-bay.
Old 11-15-2002, 12:35 PM   #847
Pit-racer's Avatar
What car was it ran in?
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 11-15-2002, 01:35 PM   #848
popsracer's Avatar
Default My Car
I am running a HPI Pro-3 with a P2K2 Pro. The car is mostly Stock except for the aluminum rear mount and bulkhead.
Old 11-15-2002, 09:08 PM   #849
yodace's Avatar
R/C Tech Charter Subscriber
I was wondering which stock motor is better for Off Road racing? the MVP, Hellfire< P2k2, etc.....
yodace is offline   Reply With Quote
Old 11-15-2002, 09:16 PM   #850
shrekair's Avatar
Trader Rating: 9 (91%+)
in offroad, i think that if anything is geared right it will work vry well. lately my favorite motors in a truck have been core/hellfire (TOP tear down). in a buggy i think almost anything on the face o the planet will work. p2k's as well as any other, and they take the abuse well.
shrekair is offline   Reply With Quote
Old 11-16-2002, 10:21 AM   #851
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Motor Problems?
Ok guys, I assembled some of the motors I posted about a few days back. Some are p2k's and some p2k2's. I ran them in on a 4 cell pack with 767's, red + green - and there was a lot of arking on the 3 motors I assembled. The arking did get less at about the 3-4 minute mark but it was still noticable. I took the motors apart to check out the comm and it looked pretty bad. No discoloration or anything but it seemed as if the serations on the brush dug into the comm and caused a burn like mark on the lines that separate the comm segments. Also, the serations in the brush were almost completely gone. I believe I had to cut about 1-2 thou off of the comm to get them clean again. I am assuming this is not normal? Anything I can try to fix the problem?
Blake
Blakesrc is offline   Reply With Quote
Old 11-16-2002, 10:29 AM   #852
popsracer's Avatar
Default Arcing Brushes
Have you aligned the Brush Hoods yet?
Old 11-16-2002, 10:30 AM   #853
sosidge's Avatar
That's what happens with silver brushes like the 767's, they are hard on the comm so the serrations cut grooves.
It's normal - whether it's desirable is another question, I know trinity are releasing some brushes with angled serrations, which will wear the comm evenly.
Old 11-16-2002, 10:38 AM   #854
Blakesrc's Avatar
I havent tried aligning the hoods yet. I was planning on picking up a tool next week unless I can get away with it some other way? Should I use another type of brush to align the hoods?
Blake
Old 11-16-2002, 10:46 AM   #855
popsracer's Avatar
Default P2K(2) brushes
Everwhere I've looked. Almost everybody uses 767's in their
P2K's. That or another manufacturers similar brush & compound.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
