Old 11-03-2002, 12:32 PM   #811
shrekair's Avatar
Trader Rating: 9 (91%+)
so help us out greenemeyer.
by the way, nice suspension on ur pontiac.
shrekair is offline   Reply With Quote
Old 11-03-2002, 03:12 PM   #812
Send a message via AIM to ZER01
Well we were rained out so I didn't get to run it
ZER01 is offline   Reply With Quote
Old 11-03-2002, 10:24 PM   #813
shrekair's Avatar
i was 3 teeth smaller then my gm3's some guys were 4 teeth.
Old 11-03-2002, 10:33 PM   #814
Originally posted by shrekair
all in all we ran these motors between 7.70 - and 8.20 many guys tried 6's and low 7's but they all kept droppin teeth off their pinions. i ran setup # 4 a 7.81 FDR. track is 120x50
Man those are high numbers. Trinity Team driver Bill Rondeau is saying gear them around 6.69.
Old 11-03-2002, 10:39 PM   #815
shrekair's Avatar
for what size track? technical or open?
here ares has a whole 120 ft straight. and its tight but still flows through the infield. motors at 7.8 are still gaining at the end of the straight for me.
Old 11-03-2002, 10:47 PM   #816
He didn't say but at 6.69, it better be open and have at least a 100' straight!
http:///tt/showthread.php?threadid=2938&perpage=15&pagenumber =2
Old 11-04-2002, 05:57 PM   #817
The new Monster motor armature appears VERY similar to the MVP and Peak/Orion motor. However the lamitations are cut as to time the magnetic field. It also does not have the " Power Tunnels" I am curious to know if this motor performs as well or better than the Peak/Orion motor. i am using one in my XXXT on a VERY small track, but I am eating every one up (Peak RS24) I am only geared 1 tooth smaller than a P2K. This motor is less smooth than and of my P2ks though and am wonder if this new Trinity motor is smooth and quite, and does it get REALLY hot???
Pit Crew is offline   Reply With Quote
Old 11-05-2002, 05:04 AM   #818
RC Nitro's Avatar
Pit Crew: Try a narrowed 766 brush in the MVP/Hellfore/Core. These work well and then gear like a P2k. Reduces the heat of the motor and produses more torque.
RC Nitro is offline   Reply With Quote
Old 11-05-2002, 12:02 PM   #819
How narrow are you cutting them. I have heard to cut them to around .140-.150 I was also thinking of cutting them to the width of the P94 brush which is 4.5mm or about .180.
Old 11-05-2002, 04:10 PM   #820
Hi guys,
just a little question for you...
i have a MR4 TC Worlds Edition which i am running indoors on a fairly small carpet track with one longish straight of about 30/40yards, the rest of it made up of hairpins, 90 dregree corners and couple of corners you can take almost straight lined of about 20 yards.
i am running Orion Core stock with a final drive ratio of 7.15 (78-24). does this sound about right to you or should i be looking to change?
any info greatly appreciated, i have been racing about 2 months now and not doing too bad (generally placed 3rd or 4th) but want to improve
thanks for your time
Mort
Mort is offline   Reply With Quote
Old 11-05-2002, 06:12 PM   #821
shrekair's Avatar
add a tooth and drop a tooth and test. thats about as much as anyone could say w/o being on the track
Old 11-05-2002, 06:54 PM   #822
psycho's Avatar
A good way to find a starting point on gearing is to watch where the speed tops out on the longest straightaway. You want it to top out just as you approach the turn at the end of the straight, so increase the pinion one tooth at a time until you get it right. Once you get that set, you can tune it for the rest of the track. That should make it pretty easy to get the most out of the car even if the track changes layout. Good luck!
psycho is offline   Reply With Quote
Old 11-06-2002, 04:13 AM   #823
RC Nitro's Avatar
Pit Crew: .140" wide Try this info from Big Jim Greenmeyer
Old 11-06-2002, 11:21 AM   #824
it seems like that is about the height of the brush. So why even use laydow. This is like using a stand up brush, but less surface then that. I will try it and see how it works, but it seems to me less current carying ability.
Old 11-07-2002, 12:02 PM   #825
ok, thanks Shrekair and Physco.
i'll try that
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
