Old 08-12-2002, 02:39 PM   #751
big al's Avatar
The reedy 767+/766- combo works really well on the mvp(cut brushes). This combo does extend the comm life,but I notice that the faster you get a stocker to go the more maintenance is needed! Even with "low wear" brushes such as 766's. Remember the good 'ol days when you could use the same two brushes in the same stocker?
I used putnam green+/blue- combo for the handout motor when nor. cal. had the on road indoor nat's. Very fast,but really jard on the comm. I'm saving the leftover green & blue for my next big event. Right now I'm using 767's on it, I'll see how it works out this weekend and report back--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 08-21-2002, 09:50 PM   #752
picco007's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Default ORION CORE
Does anyone know how or where to start gearing an orion core stock motor? This would be on a short indoor track in a xxxs touring car. Let me know..........
picco007 is offline   Reply With Quote
Old 08-21-2002, 10:21 PM   #753
I'd start out gearing it close to where you'd gear a GM3. Then decide if you want to go up or down depending on how the motor feels, and motor temp. They do run hotter than most other motors when geared right, but still keep it within reason.
JeffC is online now   Reply With Quote
Old 08-22-2002, 12:01 AM   #754
shrekair's Avatar
Trader Rating: 9 (91%+)
springs also make a big impact on the p[erformance of the core motors, and when built right, the springs can change upto 2,000 rpm's and 4w of power. so be careful
shrekair is offline   Reply With Quote
Old 08-22-2002, 11:21 AM   #755
yodace's Avatar
R/C Tech Charter Subscriber
Has anybody tried the Promatch cavity brushs? Are they similar in compound to Reedy or Fantom brushs.
Is better to run serrated 767 brushs for onroad racing? I looking to get a good balance between torq/rpm?
yodace is offline   Reply With Quote
Old 08-22-2002, 11:45 AM   #756
Alot of people get some great numbers using a full face on the + and a cavity on the -. I generally start with 767's + and -, but once I get some 769's I'll be puting them on the -.
Old 08-22-2002, 11:45 AM   #757
Oh, the 769 is just a 767 with a cavity. I can make my own cavities, but it's hard to get them consistant.
Old 08-22-2002, 12:03 PM   #758
yodace's Avatar
Why are people using two different brush for their stock motor? What does it do for the motor.
Old 08-22-2002, 03:41 PM   #759
shrekair's Avatar
cavity - hole in the face of the brush, allows for a little more rpm, someitmes power comes up aswell, all depends on the motor
slot - horizontal or veritcal slots effect every motor different, but some help rpm, others help torque. to big of a variance to tell ya anything forsure.
if u run 767 +/- you will always bee close. find someone with a dyno and find the best springs for the motor w/ 767's and you'll be consistant and fast. if u wanna get fancy with brushes, then u have to have a way to know what your doing (ie. dyno). otherwise you'll drive yourself crazy and you become really random, senseless, and out to lunch (sounds like me before the use of a dyno)
good hunting
Old 08-24-2002, 01:55 AM   #760
Anybody try the V10 from Integy yet? Will post LATE tomorrow night on how it does. L8R
acloco is offline   Reply With Quote
Old 08-24-2002, 08:26 AM   #761
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
acloco: let us know....
I have a 12th scale waiting for one......
I have ran some of the Atlas Mods....
They ran good......
Tres is offline   Reply With Quote
Old 08-25-2002, 11:21 AM   #762
Did not get home until 2 a.m........so....will post later on today.....ugh......tired.
Old 08-25-2002, 01:55 PM   #763
I used bulit motorsports purple power drops work good on motors especially with brushes that have a high silver content like putnam brushes. It doesn't make the motor dirty and last a full race.
rowdyrj is offline   Reply With Quote
Old 08-25-2002, 02:28 PM   #764
I used 3 different motors yesterday in the three qualifying rounds of TC Stock. Track setup was a very flowing track with 3 low speed corners. 120 foot straight. High traction, sprayed asphalt. Ran Sorex 36R's with HPI blues - first two rounds and Sorex 36R's with Sorex Type A firms in the third. Used Sanyo HV's on all rounds charged at 6.5 amps. I did use Tribo synthetic comm drops on each motor.
Atlas Stock - beginning gearing (TC3) - 98 spur, 33 pinion = 7.42
- used Putnam Green & Blue brush combination with tweaked Epic Red & Green springs (15 degree extra spring tension)
Best lap time 15.7 (track temp over 120) - could have geared up one more tooth on the pinion
GM3 - 98 spur/34 pinion - 7.20
- used Putnam Green & Blue brush combination with tweaked Epic Red & Green springs (15 degree extra spring tension) - Best lap time 15.8 Track temp over 110
P2K - 98 spur/41 pinion - 5.97 - used Putnam Green & Blue brush combination with tweaked Epic Red & Green springs (15 degree extra spring tension) - best lap time 15.6 - Track temp at 89
The new Atlas stock is a tri-rotor design, has one more lamination than a GM3 in the center rib. Out of the box, one brush hood perfectly aligned for each motor, had to slightly adjust one hood on each of the two motors purchased.
I did NOT dyno either of the motors.......sorry.....dyno in for repairs. Besides.....the TRACK is the real dyno test!
I do believe this will make a killer motor for 1/12th, TC, and oval racing.
If you have good/great corner speed, the motor will perform. For those that do NOT have the corner speed, go find it in your chassis setup.
Old 08-26-2002, 04:18 PM   #765
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Anybody know anything about the new Orion motors?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
