Old 06-28-2002, 08:00 PM   #616
Send a message via AIM to ZER01
.271"
ZER01 is offline   Reply With Quote
Old 06-29-2002, 08:17 AM   #617
ok thanks
Jarrod Langlois is offline   Reply With Quote
Old 06-29-2002, 08:23 AM   #618
Trips's Avatar
Trader Rating: 16 (100%+)
Originally posted by ixlr8nz
I wouldn't recommend using dry ice or the like to cool motors before running, as it will make the bushings shrink causing a tight fit between the shaft and bushing IMO.
The ice will also cool and shrink the shaft at the same time, so the fit does not get tighter.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 06-29-2002, 09:37 PM   #619
Wouldn't the bushings shrink more than the shaft as it is a different material?
ixlr8nz is offline   Reply With Quote
Old 06-29-2002, 11:03 PM   #620
rcruv's Avatar
If the bushing shrinks it should widen the hole, 'cuz the material becomes compact as it shrinks.
Just my 2 cents.
rcruv is offline   Reply With Quote
Old 06-30-2002, 12:21 AM   #621
shrekair's Avatar
Trader Rating: 9 (91%+)
dry ice or regular ice?
shrekair is offline   Reply With Quote
Old 06-30-2002, 12:23 AM   #622
Trips's Avatar
OR maybe the shaft would shrink more than the bushings, as it is a different material too. Seriously, I don't know which would shrink more, but I have put stock motors on ice for an hour before a run and they run a lot better, no sign of binding or anything.
Trips
MARSHAL!!
Old 06-30-2002, 05:40 AM   #623
Red face
I do hereby repent of using ice cubes on my motor. I know that electricity and water do not mix. I will be careful to not do anything that will short out any of the electricials on my car. I will no longer miss qualifiers or mains because of using this unsavory combination. I am completely reformed. Hmmm, i wonder if i can find a source for dry ice?
Racin Rev is offline   Reply With Quote
Old 07-01-2002, 04:58 AM   #624
RC Nitro's Avatar
The ice is a big jim tip from the black book. use a bag. Both materials will expand and contact with heat. However brass does this at a faster rate than steel (shaft). The difference is not enough to worry about. The mass transfer rate of the materials is within tolerance or different material would have been used.
RC Nitro is offline   Reply With Quote
Old 07-01-2002, 05:20 AM   #625
Unhappy
the bag is a good idea, I have used an ice cube and have had myriad problems. BJ said that he didn't "think" that it would hurt anything, but I can tell you a motor later that it does. people at the track have told me: "big jim or no big jim don't put any more ice on your motor." and I agree. I see that the magazines have been jumping on this tip. all I can say is don't do it!
Old 07-01-2002, 05:28 AM   #626
RC Nitro's Avatar
I don't. I personaly do not do this or do I need to split hairs yet..... Need to get faster first I will heed the lesson.
Old 07-01-2002, 07:52 AM   #627
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
If you are going to use the ice cube put it in a bag like a sandwich bag and then put it on the motor. Don't put it directly onto the motor or you will experience problems like the poor Rev did. The water has to go some where.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-01-2002, 10:57 PM   #628
Simon K's Avatar
Wink
I had some small gel ice packs ready to go, just couldn't be bothered pulling the motor out and putting the ice packs around it.
The gel packs were defrosted, then an old motor can put between them then re-frozen(With a rubber band holding it all together). It meant that the can would be completely enclosed with icy gel pack if I had used them before a race.
Looked like a donut, just little frozen packs held together with the rubber band.
A better idea than just leaving an ice cube on the motor, I just never liked the idea myself.
Simon K is offline   Reply With Quote
Old 07-03-2002, 03:53 PM   #629
blueboy's Avatar
Some time ago I brought a P2K2 Pro and I was well happy with it, until I blew it up - overgearing, nothing to do with the actual motor. I went out and got a new one though, but it was a bit different. it has a pair of green springs instead of green/red, and the rpm on the dyno seems a little low. it says Pro on the can and packaging. what im asking is have Trinity changed the spirngs on the Pro version or did I get a flukey mistake motor?
blueboy is offline   Reply With Quote
Old 07-03-2002, 09:22 PM   #630
Super Moderator
Kraig's Avatar
Trinity recently switched to the Fantom Dyno. Your old motor was probably tuned using the Robitronics dyno. I don't know what voltage the Fantom Dyno ran the motor at but they do have the capability of testing them at 7 volts. I would venture to guess that the Robitronics tested motor was done at 7.2 volts.
As for the springs, only Trinity can answer that question. Maybe that motor liked those springs but that is just speculation on my part.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
