Old 05-17-2002, 01:55 PM   #571
Regional Moderator
Send a message via AIM to Mike F
How you doin darksied - on that type of track, go into the mid to lower 7's.
Mike F is offline   Reply With Quote
Old 05-17-2002, 08:05 PM   #572
IceBerG71's Avatar
Anyone knew if a same type of batteries when put into stick pack or saddle pack, will there be any difference?
Saw a lot of pro using saddle pack....
Thanx
IceBerG71 is offline   Reply With Quote
Old 05-17-2002, 08:34 PM   #573
shrekair's Avatar
Trader Rating: 9 (91%+)
Darkseid - u cannot lug a p2k2 like that or it just plain wont come off the corner. on a large carpet track i wont run smaller than a 6.69 fdr. some i run at 6.86 on the same layout. and u described a tight or small layout, i'd run stock springs, 767 brushes, and a final drive of 7.15. some guys get the to work on our big track as well but its a tad short at the end of the strait. hope that helps.
shrekair is offline   Reply With Quote
Old 05-18-2002, 04:04 AM   #574
sosidge's Avatar
Iceberg - cells are cells.
The benefits of a saddle/side-by-side layout are weight distribution (lower in most cars), and the ability to use quality battery bars and solder joints (most stick packs use thin metal tabs spot welded on to the cells).
Old 05-27-2002, 08:36 AM   #575
Regional Moderator
Darkseid's Avatar
What final ratio are you guys running your P2K2 motors at? I'm running at a short track and a meduim sized track.
TLR 22...Tamiya F104...
Old 05-27-2002, 08:44 AM   #576
Regional Moderator
I stopped using mine but there's a guy at our track who has a Fantom P2K2 and he gears it at 7:0. Long Straights though, he pretty dominiated the race
Old 05-27-2002, 12:17 PM   #577
shrekair's Avatar
how long is your short and medium sized track? on road i assume?
Old 05-27-2002, 04:40 PM   #578
Regional Moderator
Darkseid's Avatar
shrekair: Well, I'm not sure what the exact sizes are. Yeah, its on-road. The short track is nearly all turns with a short straight. I don't even know why I mentioned the medium track since I use a different motor for there and the local large track.
Mike F: I'm on the verge of stopping using mine! It just hasn't performed like I hoped it would. Other locals are running the Peak Hellfire, and just plain flying. Besides that, the thing sounds horrible! The motor is the loudest stocker I have ever heard. It sounds like I'm dragging a chirpping bird around in my car! Its been that way since I took it out the package and hasn't changed.
Old 06-01-2002, 04:42 AM   #579
Default Peak Hellfire
Any good suggustions for motor set up on a Hellfire in a TC3?
Thanks,
Tracy
doorman is offline   Reply With Quote
Old 06-01-2002, 11:02 PM   #580
So far, after breaking in the bushings, I am using Reedy 767's and a tweaked red + spring & red - spring (trinity). Numbers on the Robi indicate this should be a very strong motor. 170 Nmm torque (p2k territory), 125 watts (this type of arm is not the wattage king), excellent efficiency, 30500 rpm (max)....but the average power numbers are very, very good.
Make sure the brushes are aligned!!
acloco is offline   Reply With Quote
Old 06-02-2002, 10:09 AM   #581
With my Hellfires and Core, I've aligned the brush hoods (all were good from factory), polished the bushings on 2, reemed the on the other, 4499 brushes Trinity purple/red springs, around 29.000rpm, 126-127 power, 81-82 average power. I forgot the torque though, but they're very, very strong motors.
JeffC is offline   Reply With Quote
Old 06-02-2002, 08:28 PM   #582
Joe
Joe's Avatar
I used my Core today, very strong motor-it felt like the torque of a P2K and the RPM of a P2K2. I ran a FDR of 7.1. However, it got really hot; given, the air temp was in the high ninties, but still hotter than my Trinity motors. Is anyone else experiencing this?
Joe is offline   Reply With Quote
Old 06-02-2002, 09:02 PM   #583
Simon K's Avatar
Wink
Try reducing the brush width slightly. This has been recommended due to the similarities between the MVP and Core/Hellfire motors.
Simon K is offline   Reply With Quote
Old 06-02-2002, 09:02 PM   #584
Mine get a little warmer than my Trinity motors, but not so hot that I worry about them.
Old 06-02-2002, 11:41 PM   #585
Joe
Joe's Avatar
Simon-cool, I'll try that. Do you know if it reduces torque any?
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
