Old 04-09-2002, 09:53 AM   #496
psycho's Avatar
Mike F
It didn't seem too bad. Then again, I was using Tribo. At an event like that, everyone was cutting their comm for each race, so it's sort of hard to tell.
psycho is offline   Reply With Quote
Old 04-09-2002, 12:28 PM   #497
Default Orion Core and Peak Hellfire
I just bought 1 Core, and 2 Hellfires. I've played with the Hellfires on the dyno some, got decent #'s but nothing special. Just starting to play with the Core. In my truck, the Hellfire seems great, but haven't ran it in my sedan yet.
Anyone find any tricks or good setups for these motors?
I'm running Trinity 4499's with Purple/Red springs on the Hellfire. About 29thou RPM, 124w power, 81avg power I think. That's on a Robitronics @ 7.5v
JeffC is offline   Reply With Quote
Old 04-09-2002, 12:46 PM   #498
mike_Webb's Avatar
Send a message via AIM to mike_Webb
JeffC-
I centered the Brush Hoods on the Comm and am running the Peak 2221 Brush on the Hellfire. I drilled a hole in the brush just off center on the trailing edge of the brush. I use the Viper 115 on + and 135 on Negative. It is a pretty decent motor.
I am going to play around with 767 and 766 brushed and the 4499 brushes some more.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 04-09-2002, 01:05 PM   #499
I also centered the brush-hoods (actually just checked them, they were already very good), and on one Hellfire I reemed the bushings. Still waiting for my reemer to come before I can do all my motors.
Old 04-09-2002, 03:59 PM   #500
Regional Moderator
Send a message via AIM to Mike F
That Orion motors is pretty good, from what I read. A friend of mine got one and he did nothing to it and did OK with it. Reedy is coming out with a new motor (new design) in a few months, it suppose set the new standard for motors, can't wait.
Mike F is offline   Reply With Quote
Old 04-10-2002, 08:16 PM   #501
Simon K's Avatar
Wink
Mike W,
I use the same spring combo with my MVP's but I think you have them around the wrong way(or have typed them wrong). I run...
135 deg on +
115 deg on -
Big Jim has suggested tuning the Hellfire/Core motors similar to the MVP. Eg, Cutting the brush width down/align brush hoods etc. Keep the Viper springs as I was told they are similar to the Red/Green Trinity combo.
Simon K is offline   Reply With Quote
Old 04-10-2002, 08:29 PM   #502
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
What kind of dyno numbers are people seeing on these orion/peak stockers?
Speedo
Speedo is offline   Reply With Quote
Old 04-12-2002, 08:11 PM   #503
Speedo
On my Core, I just got 29.366rpm, 126.7w, 81.8w AVG, and 64.9%eff. Not too bad, but need to see how it is on the track soon. (Hopefully I can get out there next week.)
Old 04-13-2002, 12:32 AM   #504
Trader Rating: 69 (100%+)
any feedback on the fantom p2k2? i used to run a GM3 with 30/72 gearing on my tc3. should i gear it the same way or use a smaller pinion?
marvi is offline   Reply With Quote
Old 04-13-2002, 01:30 PM   #505
Super Moderator
Grizzbob's Avatar
Since we don't know the actual numbers from both of your motors, we can only guess at the right gearing, but in general you should gear a P2K 2 a bit taller than the GM3(that's numerically lower), but not as tall as you would a P2K, so you might give a 31 or 32 tooth pinion a try, & see how the car feels with it.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 04-13-2002, 10:48 PM   #506
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
For the TC3 with the Fantom P2K2 72/30 Works well...
ChristopherKee is offline   Reply With Quote
Old 04-14-2002, 12:14 AM   #507
thanks so ill just stay within the 30-32 range. but ill run on a shorter track next weekend so might go as low as 28. i need more acceleration on that track.
Old 04-14-2002, 12:17 AM   #508
rcruv's Avatar
I race TC3 at small tight track and use 27/72 to gear p2k2.
If I run 28 pinion it seems loose acceleration at inside corners.
I might go for 26 depends on the layout.
I tried 30 once then motor was almost burnt.
rcruv is offline   Reply With Quote
Old 04-14-2002, 08:44 AM   #509
i tried the 26t pinion this afternoon. acceleration was great. top speed is also good, but it doesnt matter because the straight is not that long. the comm and brushes are still in good condition after 5 battery packs. i think ill stick with this pinion, or go up or down a tooth after a few more experiments. thanks for the tips
Old 04-14-2002, 07:46 PM   #510
Regional Moderator
yeah you would burn that motor if you gearing that way. The P2K2 is like the MVP so you have to gear it about the same. With that standard 72 spur use either the 25 or a 26 and you'll be in the ball park
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
