Old 03-27-2002, 12:44 AM   #466
thanks for your tips
i'm using the fantom 315 brushes and have blue springs. maybe i should try red springs and maybe gear down if possible.
btw, i have lathe the motor and already break-in the brushes.
anyone know what are those green compound that they used to coat the armatures so that they will not short. are those epoxy? i only know they use epoxy to balance the armature! any hints?
maski is offline   Reply With Quote
Old 03-27-2002, 08:55 AM   #467
Originally posted by Kraig
Now if you want some serious h.p. try a set of the Putnam brushes but they require a little bit more maintenance than the 315's, and 767's.
Which putnam brush's do you recommend for a stock motor? The green shunt or blue shunt brushes? Also, what type of extra maintenance do they require? Just more frequent cuts of the comm or something more?
Thanks,
Rob
R_Andersen is offline   Reply With Quote
Old 03-27-2002, 09:12 AM   #468
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Rob, I and I am pretty sure Todd Putnam would recommend a green on the positive and a blue on the negative. You are correct as I was talking about more frequent cleaning and possibly cutting of the com.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-27-2002, 11:10 AM   #469
i just run my fantom p2k2 with 24/78 on my yoke sp. i placed an old spring from my chameleon pro motor (red and blue i think). its fast but not as fast as others motor. any tips to increase its performance?
Old 03-28-2002, 06:24 AM   #470
BagofSkill's Avatar
Hi Guys,
In my Atlas (Matrix) I cut the brushes down just like big Jim says, but I'm wondering how you guys do it. The brush always crubbles on the edges. Is there a way to avoid this?
And will it benifit the 23T motors?
BagofSkill is offline   Reply With Quote
Old 03-28-2002, 06:00 PM   #471
Simon K's Avatar
Wink
I use quite a fine file, it's not very big and I don't put a lot of pressure on it. Are you using the #766 brush?
Simon K is offline   Reply With Quote
Old 03-29-2002, 09:31 AM   #472
Default heat sinks
I have clip on heat sink that came with my xxx-s when I bought it. If I use this heatsink with my stock motors it covers the holes in the motor can on one side. I was wondering if this is actually hurting the motor by not allowing proper airflow through it with the holes blocked up? There's no way to use the heatsink without covering up the holes on one side. I also read that the holes are there for more than just cooling. Could the heatsink also be hurting the performance on the motor by disrupting the magnetic field?
Thanks,
Rob
Old 03-29-2002, 01:38 PM   #473
Default heatsinks
rob,
i was wondering the same thing. i run both the tc-3 and xxx-s, and had heatsinks on both. while i was at the carpet nats last week, i was trying to lighten up my xxx-s. to make a long story short, i took off the heatsink, and saved a good chunk of weight. after running, i'd tech my motor w/ my heat gun, and it was still at around 140 degrees fahrenheit. as i toured through the pits, i noticed alot if not most didn't run heatsinks. one of associated's drivers once told me that once the heatsink heats up, it really has no place to dissipate the heat, so it ends up heating the motor. another thing, the lighter the color of the heatsink, the less heat it will dissipate. anyway, that's my opinion, other's might disagree, but try what works best for you.
d31
diesel31 is offline   Reply With Quote
Old 03-30-2002, 04:16 PM   #474
Team R's Avatar
Default Brushes
Hello all--
It has been 5 to 8 years since I did any serious racing, and I have some brushes that have been sitting around for that long. I'm wondering, can brushes go bad after a while. It may sound like a stupid question, but no question is stupid if you donít know the answer.
Thanx for any input you send my way
Rich
Team R is offline   Reply With Quote
Old 03-30-2002, 06:41 PM   #475
Simon K's Avatar
Wink
I think the newer compounds of brush would be better than what was available previously.
Old 03-30-2002, 07:06 PM   #476
Super Moderator
Grizzbob's Avatar
I agree, I think the newest brush compounds are the best bet for outright power, but I do know of a few guys who've had to use some old brushes that were laying around(especially when we had a brush shortage some time ago), & they seemed to work fine. Do you know exactly which brushes you have(the old ones, that is)?
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 03-30-2002, 08:02 PM   #477
when is the new motor with cobalt magnets comin?
Old 03-30-2002, 09:03 PM   #478
Team R's Avatar
Default Type of brushes
Grizzbob--
You asked what type of (older)brushes I have--
Mostly I have S and K Racing Products - med. density 1/2 cut
and some Trinity. One of the Trinity brushes is their laydown silver burshes.
Thanx for the info
Team R
Old 03-30-2002, 11:29 PM   #479
Super Moderator
Grizzbob's Avatar
Maski, there is no stock motor with cobalt magnets, Reedy's upcoming new stocker is codenamed Cobalt, but it will NOT have cobalt magnets(they're illegal & cost WAY too much). It's just the motor's name for now, & there's noo guarantee it'll still be called that even when it's released.......
Bob Seay
Go Pokes!!!
Old 03-31-2002, 07:29 AM   #480
oh, i see. i thought it will use cobalt magnets. so when is that comin?
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
