Old 10-09-2001, 01:36 AM   #31
When will P2K2 be in West coast?
ME-student is offline   Reply With Quote
Old 10-09-2001, 05:50 AM   #32
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
ME - My guess would be either right now... or within the next 2 weeks. I have mine on order, and expect them to be in next friday.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-09-2001, 05:53 PM   #33
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
ME-Darren said he should have them by the end of the month, though we didn't know they were already out, so he may have them sooner.
I would gear the P2K 1 or 2 teeth higher.
Speedo is offline   Reply With Quote
Old 10-09-2001, 06:04 PM   #34
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I got my P2K2 last weekend and all I have to say is that its smooooth and quiet. I did get it on a dyno at the track and it was close to the guys Green 3's but off on RPM and more watts. I ran it in my 12th scale and it was awsome. I lasted all 8 minutes not like the Green 3's that seem to fall short the last minute or so of the race. It never got hot or faded the whole weekend. My fastest run all weekend was with the P2K2. It looks like this might be the replacement for the green3 aka Smoked3.
Kevin K is offline   Reply With Quote
Old 10-09-2001, 06:24 PM   #35
Moderator
Speedo's Avatar
Kevin, do you remember the numbers? If so, please post them!
Old 10-09-2001, 07:30 PM   #36
AE_Racer's Avatar
Send a message via AIM to AE_Racer
P2K2 is out???? SInce when? Im still running an Axiom P2K
AE_Racer is offline   Reply With Quote
Old 10-09-2001, 08:37 PM   #37
Moderator
Speedo's Avatar
LOL, since this week...I didn't know till yesterday either.
Old 10-09-2001, 09:21 PM   #38
R/C Tech Founder
P2K2 was fast tonight. I ran two 5-minute practice runs, one with a decent (tuned) P2K and one with a brand new P2K2. The P2K2 definitely seemed to have a better distribution of power. While the top speed was similar to the P2K, the overall feel of the car was much snappier than with the original P2K.
The motor did run a bit hotter than the P2K, coming off the track probably at least 15-20 degrees hotter. Not sure if that was a gearing thing or just "normal behavior."
I ran the P2K2 with a 21T/88T combo in the XXX-S. Before running (and per mr.losi's advice) I broke it in at 2V for 10 minutes, trued the comm, replaced the factory brushes with nicer slotted ones, and then ran another 3 minute break in at 2V.
Overall, my first impression is favorable. Will race with one this weekend.
futureal is offline   Reply With Quote
Old 10-09-2001, 09:51 PM   #39
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
ok...i finnaly got my p2ks onthe dyno.....i have done no work on them exept
1 i broke in at 2 amps for 10 min....
2 i aligned the brush hoods
3 trued the comm
4 put in reedy 767
5 put red and green springs in
6broke in @ 2 amps for 200sec
7 ran in car one batt
here are the ##
p2k2 1
red+ green-
power 55.27
rpm [email protected]
torq .875
p2k2 2
green +/-
power 56.37
torque .895
all ## on a fantom dyno...i will rebuild the moters and true the com and redyno.....
all ### are right off the track....
Matt M. is offline   Reply With Quote
Old 10-10-2001, 05:30 AM   #40
AE_Racer's Avatar
I guess I will have to go buy one then!
Old 10-10-2001, 05:41 AM   #41
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Sounds like I'm gonna have to swipe one from inventory. We'll see what it'll do at the oval race this weekend.
Flash Gordan is offline   Reply With Quote
Old 10-10-2001, 06:03 AM   #42
RCTech Member #2
TSR6's Avatar
Maann.. You guys need to keep up on this stuff.
My P2K2 will be in later this week. I won't be able to runit for about 2 weeks due to my radio situation. Sounds like a great motor...
Troy
RCTech Member #2
Old 10-10-2001, 09:34 AM   #43
Mr. Losi when using your Fantom dyno what power sorce r u using (how many amps)
steel or alum. flywheel? try to compare #'s equally, thanks
rcspeed is offline   Reply With Quote
Old 10-10-2001, 09:55 AM   #44
Administrator
Matt M.'s Avatar
rc...i use a 75 amp power supply....with the alum. flywheel...my dyno seems to be a little more conservitive than most....a very good motor on mine would be 59-60....a good motor would be 55up....over 60 on mine you have a rocket.....
also, i have done no testing on springs and brushes....also, they need to be broken in better....the bushings are still a bit tight...
Old 10-10-2001, 05:42 PM   #45
Moderator
Speedo's Avatar
3 trued the comm
4 put in reedy 767
here are the ##
p2k2 1
red+ green-
power 55.27
torq .875
p2k2 2
green +/-
power 56.37
torque .895
man, those are good! Those numbers are about average for a p2K, not warm. But if those were right off the track, imagine what they would have been if the motors had been cooler! You may want to try the reedy 766 brushes too. I had a new pair of 767s in my P2K, and it kicked out crap numbers, so I put a pair of 766s in and broke them in, it made a world of difference. Let me know if you do.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
