Old 03-04-2002, 09:35 AM   #376
Jack Smash's Avatar
Trader Rating: 29 (100%+)
You may have to gear that MVP way different from the rage. Stock motors these days produce way different powerbands from one another. You will also have to gear a stock MVP differently from an MVP tuned to Big Jim specs.
Jack Smash is offline   Reply With Quote
Old 03-04-2002, 05:49 PM   #377
Trader Rating: 69 (100%+)
hey jericsm havent seen you in a while. im on the park square track this sat, probably with fish, gary, etc. lets race open stock gary's MVP was really fast last time out, though he did use a smaller pinion than with his GM3. i saw your Rage in action and its fast on the straights. i might get a new stock motor within a few days, my GM3 is on its last cut before i retire it. i think ill go for whatever's available in our lhs. each stock motor seem to have its strengths, i just have to look for the correct gearing and some performance tweaks. if youre free, see you this sat and good luck in TCS!
marvi is offline   Reply With Quote
Old 03-04-2002, 07:20 PM   #378
Send a message via AIM to Ovalman19
Default Putnam Brushes
I don't know if anyone has brought them up or not, but Putnam Green and Blue shunt Brushes are amazing in stock motors. Green Positive and Blue Negative. This combo will work awesome. Try it.
Ovalman19 is offline   Reply With Quote
Old 03-04-2002, 07:40 PM   #379
jericsm's Avatar
hey marvi....
yup, i probably have to gear it more agressively, but what i liked about the rage was it can hang out with you guys in my tc3 with a 72/28 gearing, and it was relatively cool after the run..... not so much in the torque, suited for the park square track....
i'll try to see if i can run stock touring this saturday.... tweak my mvp for you guys
Jack Smash, yup.... might have to play with the gearing.... our track is a fast but loooong track, a-main mods doing 23 second laps..... open asphalt, sometimes used as parking.... lots of loose dirt/small stones so guys really opt for 48-pitch. On my Rage, as I mentioned, I was going 72/28 on a TC3. I'll be trying a 29 or 30 this weekend..... MVP = more tourqe than Rage, less top speed? seems that way to me.....
jericsm is offline   Reply With Quote
Old 03-04-2002, 07:48 PM   #380
Orion Core Stocks: Are they available yet, and if so are they fast?
Petenis
petenis is offline   Reply With Quote
Old 03-05-2002, 09:42 PM   #381
Super Moderator
Grizzbob's Avatar
Jericsm, you do need to gear most MVP's taller than you would a GM3 or old Reedy Rage(pretty close to how you'd gear a P2K), but regardless how you gear it, that MVP may run pretty darn hot(but doesn't seem to be bothered too much by it). I've had some success getting good power out of an MVP, but I never could lick the heat problem. However, I've noticed that the P2K 2, when set up right, has a powerband nearly identical to the MVP, but it runs cool & more efficiently. For a really big track, you probably are best off with a GM3, but you can also do well with a P2K 2 or properly set up MVP(those two are probably the most versatile stock motors available right now, no real weakness in the powerband).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 03-06-2002, 12:53 PM   #382
LooseCannon's Avatar
Petenis
I heard they pushed them back again for some more tweaks / testing.
LooseCannon is offline   Reply With Quote
Old 03-06-2002, 01:35 PM   #383
Axiom racing motors recieved the OEM version of the Hellfire Last week. We ran some at the Region 11 carpet champs last weekend and they seemed really fast. They do heat up a bit in a heavy sedan in 5 minute races. With the proper springs and brushes these will be good motors.
Chad
ChadK is offline   Reply With Quote
Old 03-07-2002, 07:31 PM   #384
what is the best stock motor for a tc3 on carpet
cantbestopped44 is offline   Reply With Quote
Old 03-07-2002, 09:43 PM   #385
Ovalman,
Where do you get Putnam brushes? Thanks.
coolrcdad is offline   Reply With Quote
Old 03-08-2002, 12:05 AM   #386
Registered User
coolrcdad: try kthobbies
beowulf is offline   Reply With Quote
Old 03-08-2002, 04:58 AM   #387
You can get them in bulk from rc4less. They are a little more expensive then 767's or 4499's, but they have tons of power. I used one pair of brushes for 6runs(2 practices, 3qualifiers, and 1main) and I still ended up winning the Amain by a lap.
Old 03-08-2002, 05:22 AM   #388
Send a message via Yahoo to miniman
Default timed brushes?
Does anyone have any experience with timed brushes? thanks
miniman is offline   Reply With Quote
Old 03-08-2002, 08:53 AM   #389
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
coolrcdad, I have both green's and blue shunt brushes ready to ship for $3.25 a pair. I can ship them U.S.P.S. to help reduce cost to you.
beowulf, thanks for the plug.
miniman, I have only experienced them on the dyno. When you put them in one way you loose rpm and gain torque, flip them and it is just the opposite. I have found aligning the brush hoods to be the best for performance. One thing to keep in mind that I have just started messing with is when the com starts to get smaller that sometimes triming both sides of the brush down helps. I got that idea from Big Jim and from Jim D.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-08-2002, 10:18 AM   #390
Registered User
Kraig: I just e-mailed you. I need a serrator (pro-match). hope you could help me out.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
