Old 10-07-2001, 11:26 AM   #16
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Originally posted by Cole Trickle
Maybe I should add, I'm using Orions Speedy Drops for about every 5-10 packs.
Just got my P2K.
My Spitfire blueprinted data:
Max 23.011 rpm
8,6 torque @ 16650 rpm
105 watt @ 16650 rpm
62% is the best effiency @ 18595 rpm
P2K:
Max 27.988 rpm
189 Nmm torque
129 watt
72,5%
Hard to wait...
By the way, do anybody know what's the unit for measuring the Spitfire torque?
Your spitfire numbers are off a Turbo Dyno, while the P2K numbers are off a robi, you can not compare them. I don't know anything about Turbo Dynos, but I have a robi, and the P2K numbers are very good.
Anyone seen any actual numbers for the P2K2? It looks very interesting!
Speedo is offline   Reply With Quote
Old 10-07-2001, 01:27 PM   #17
Marvi,
Do you know how they get those numbers? Put the motor in the refrigerator for a couple hours.
The TRUE test of a motor, dyno it back to back, and use the second dyno pull as the test for the motor.
acloco is offline   Reply With Quote
Old 10-07-2001, 04:01 PM   #18
Moderator
Speedo's Avatar
yeah, but RCCA's dyno also put the P2K at 140+ max watts...Their dyno is screwed up. I have only ever had a motor-a P2K- get above 130.
Old 10-07-2001, 08:25 PM   #19
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I was able to run a GM3 today with a 6.75:1 ratio in my Kawada and it barely got warm! So much for the up in smoke theory! I have 3 GM3 s and have had not one single problem.
Core Creations is offline   Reply With Quote
Old 10-08-2001, 02:08 AM   #20
Cole Trickle's Avatar
Sad! Anyway, it was too good to be true. So all these motor specifications, are they only marketing bla bla? If they're not measured the same way, they doesn't matter...
However, do you know what's the unit for measuring the Spitfire torque?
Cole Trickle is offline   Reply With Quote
Old 10-08-2001, 05:53 AM   #21
Cosmo's Avatar
Have any of you used the new P2K? I'm not sure what it's called, but the one with the black can.
Two of them came into our LHS a few days ago, and by the time I got there to buy them, they were gone.
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 10-08-2001, 09:43 AM   #22
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Cosmo, we got a couple P2K2 motors also. Haven't had a chance to try one yet. Hopefully at the next race I'll have one. The one thing that I noticed on the motors we got, is that there aren't any dyno numbers anywhere on the package or the motor.
Flash Gordan is offline   Reply With Quote
Old 10-08-2001, 10:01 AM   #23
Cosmo's Avatar
Is that what they're called? Doesn't exactly roll off the tongue, does it?
Anyways, I know the first ones probably won't have dyno sheets. Only the "Pro" motors have those. They "Pro" motors won't be out for a litte while still.
Old 10-08-2001, 06:03 PM   #24
Moderator
Speedo's Avatar
Cole, the numbers you get with the motors are barely believable. As for comparing them, it has to do with the different specs of all the dynos. If they were all the same, well, they would all be the same.
So, the P2K2 is out? I'm getting one, or two...If it's better than the P2K, man! If anybody gets dyno #'s, post them! Prolly didn't have dyno sheets cause they were the standard model, not the pro model.
Josh
Old 10-08-2001, 07:57 PM   #25
You're right speedo, it was probably the standard model. Cause it didn't say pro anywhere on the package. Also I'd love to see the dyno specs if somebody can do a dyno run on one of these.
Old 10-08-2001, 08:05 PM   #26
R/C Tech Founder
Just got myself the P2K2s this evening. Going to break them in at the track tomorrow. mr. losi has a few and is gonna stick them on the Fantom Dyno sometime later next week.
Anybody have any gearing tips yet? I am gonna start with something really low, like a 7.2 or a 7.3 and then work my way up from there. I was running P2Ks with a pretty tall ratio, somewhere in the low 6's, but I don't want to smoke one of these off the bat. Hopefully they will be as strong as the P2Ks, but you never know...
futureal is offline   Reply With Quote
Old 10-08-2001, 08:59 PM   #27
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i will break them in and run them tomorrow, then i will dyno them....i will let you know asap.....
Matt M. is offline   Reply With Quote
Old 10-08-2001, 09:08 PM   #28
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I have a P2K2 that should be in next week. Lemme know what you guys think!
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-08-2001, 09:18 PM   #29
Moderator
Speedo's Avatar
Cool
Cool...I'll have one in two weeks, next time I race...So I'll put it on my dyno then.
Old 10-09-2001, 12:16 AM   #30
Since the data of a Spitfire and a P2K cannot be compared - any suggestions about gearing, compared to a Spitfire? On or track 93/23 (48 pitch) is great with the Spitfire...
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
