Old 05-02-2007, 02:42 AM   #2776
LOSI123's Avatar
Trader Rating: 63 (100%+)
what are max and min sizes of co27 (epic27) comm's?
like what size comm is almost gone and what is a good measurement still with life left?
thanks.....
LOSI123 is offline   Reply With Quote
Old 08-01-2007, 02:38 PM   #2777
swopemike's Avatar
I have 3 "new" motors that I'm pretty sure are leftover Paradox handouts. Would like to set them up and break them in and give them to some new racers. Might even run them for a club race. Just curious how to set them up (springs, brushes) and what rollout to use. Did a fair amount of searching and all I found was 1 post (red/green springs) and another 24-26mm rollout (0.95 - 1.05 range). Large track with several tight corners. I have a motorchecker but not a load dyno and usually our track doesn't give us much practice time with the computer set up, so hoping to get close without taking much time on it.
swopemike is offline   Reply With Quote
Old 08-02-2007, 06:45 AM   #2778
swopemike's Avatar
Allright... you can stop laughing now. I know some of you have run these, it's only been 3 or 4 years... so please let me know (questions above).
Old 08-21-2007, 02:54 AM   #2779
Fuzzy's Avatar
Default Help with Core Stock
The Cleveland Indoor Champs just announced that the hand out motor for this year is Orions Core Stock. I've never run these types of stock motors, so I could use a little help with setup. Any suggestions on brush setup and gearing vs. the Co27 in 12th scale?
Fuzzy is offline   Reply With Quote
Old 08-21-2007, 03:20 AM   #2780
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
havent seen this thread in a while...lol
fuzzy....just steal gearing and setup when you get there... thats the easiest way, since orion is sponsoring i assume there will be enuf brushes for all...
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 08-21-2007, 10:04 AM   #2781
swopemike's Avatar
Any suggestions?
Old 08-21-2007, 07:43 PM   #2782
Fuzzy- according to Big Jim he said they should be set up like a Reedy MVP. 767 brush on the positive and 766 on the negative. With spring tensions of 6.5 + and 6 - from a fiddle stick gauge. I just found this info from another forum yesterday from a link somewhere in this thread. I think it was at rccars.com I have my son's car running a 35/100 gear combo for our local track with his rollout being around 29-30 and final ratio at 7.14 in a TC4. He is consistently quicker than the Co 27's, but his motor has not been rebuilt yet with the above info.
ercwhtsd is offline   Reply With Quote
Old 08-21-2007, 08:24 PM   #2783
What current limit would you recommend for 27T? I find that when I hit something occasionally my power goes down because of the current spike. So if you limit the current this won't happen so much. How far do you go though?
thanks
Mike
ixlr8nz is offline   Reply With Quote
Old 08-21-2007, 08:31 PM   #2784
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
What are F Brushes considered ( RPM or Torque brushes)?
CarlosG. is offline   Reply With Quote
Old 08-21-2007, 09:06 PM   #2785
P2
P2's Avatar
Trader Rating: 15 (100%+)
High RPM w/loads of torque
Carlos, you have Team Kwik, EA Motorsports, and Trinity driver right next to you. You should ask them, that's what the sponsored drivers are there for. To help the local racers.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 08-30-2007, 02:33 AM   #2786
hey guys,
I've picked up some f-line brushes and was wondering how long you break them in for ? they seem to take an age to get any comm wear marks on them.
Also, a little off the main topic, but the same question for the checkpoint infinity brushes on a 19T money motor
chris_dono is offline   Reply With Quote
Old 08-30-2007, 02:50 AM   #2787
usually on the f-brush it depends on the batch but andwhere from 5 min to
15 , just run for 5 min then check the brushes if not broken in then check them every min or two, you want all the serrations to be shiny..
as for the checkpoints i break them in for 12 min at 1.0v....
same thing tho, make sure that the serrations are shiny
Old 08-30-2007, 03:49 AM   #2788
Great, thanks
I'll try that
Old 09-04-2007, 07:15 PM   #2789
Default Question on motors
Originally Posted by EddieO View Post
Increase spring tension to increase RPM.....decrease it to increase torque....
The 4499 is a very RPMish brush, so thats a good place to start.
Later EddieO
I always get confused could you tell me if I had high AMp readings on the motor does that mean higher RPM or higher torque and with the high amp should I need to adjust to a larger pinion or a smaller pinion to accomplish fewer minutes per lap.
thanks
bakertc3 is offline   Reply With Quote
Old 09-08-2007, 06:24 PM   #2790
Stock racers I have a quick one here I got the new Orion stock 07 motor and tried it today but the motor was slower than my other stock motors I gear it like the CO27 and the motor got real hot 195 deg so I went down on the gearing and the motor got even hotter, my setup was red's on both sides with 4499 brush, can someone give me the setup on how to get this motor to run right, thank you.
Ramyuras is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
