Old 02-27-2007, 07:49 AM   #2746
RocketRacer's Avatar
Originally Posted by Z.Hallett
for tc start around a 35mm
for 12th start around a 40-43mm.
what brushes and springs are on the motor? what surface type are we talkin?
-Zac
sorry, i should have told you all of that first.
here goes:
outdoor asphalt, high grip, tight track, longest straight is +/-30m (100ft) , foam tyres,
motor: CO27, putnam green shunt brushes(high Silver), std brush springs (purple)
my chassis : Tamiya TB Evo 5 Internal Ratio is 2.437. i currently have a 99T spur in the car.
hope the info helps.
thanks
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 02-27-2007, 09:03 AM   #2747
Iceracer's Avatar
Could someone check my math on this rollout calculation?
C027 motor, 6 cell, touring car, 58mm foam tires, 114t spur gear, internal ratio 1.7, target rollout 35mm as per above recommendation.
58mm diameter is 182mm circumference. 114/29pinion x 1.7=6.68 ratio
182mm/6.68 ratio=27 mm present rollout.
I come up with a recommendation of 37t pinion for 58mm tires and 39t pinion for 55mm tires following a 35mm rollout.
Yikes, if that's right, I'm way off on my gearing!! I've been running a 29T pinion and the motor gets up to 75 C maximum. That works out to a 27mm rollout.
Iceracer is offline   Reply With Quote
Old 02-27-2007, 09:14 AM   #2748
We run 26 to 29 rollout at our track with a co27 w/ sedan. 100 ft straight semi technical.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 02-27-2007, 09:33 AM   #2749
Trader Rating: 8 (90%+)
35mm is a rediculous rollout for a CO27. I run between a 26-29 rollout.
Johnny Carey is offline   Reply With Quote
Old 02-27-2007, 09:44 AM   #2750
26mm~29mm sounds spot on. i have been always running between those figures. that has been pretty much where most of our local fast guys have been rolling out. thanks for the help guys.
RocketRacer
Old 02-27-2007, 09:48 AM   #2751
Iceracer's Avatar
Thank you gentleman. The 27mm rollout is what I arrived at through my own experimentation based on motor temp and performance. The hottest the can has ever gotten is 75 degrees C.
Old 02-27-2007, 12:04 PM   #2752
DriftDreamer06's Avatar
sorry for the dumb question but who makes the "f brush" i been useing the trinity 4499 and 4504
DriftDreamer06 is offline   Reply With Quote
Old 02-27-2007, 12:33 PM   #2753
corradopsi's Avatar
Send a message via AIM to corradopsi
Finishline
Mine: Nomadio Sensor; T2'007, Keyence, Express; ZX-5 SP, Mamba Max; XB8, OS V-spec and NR P5; ProBoat Shockwave 36
My Son: Futaba 3PM; T4 RS; Clodbuster; TT-01;Zig-Zag racer
corradopsi is offline   Reply With Quote
Old 02-27-2007, 12:34 PM   #2754
I believe it's finish line.
Obsidian is offline   Reply With Quote
Old 02-27-2007, 12:54 PM   #2755
how are you guys getting the tire circumference 58mm tires at 182 i like to run my tires at 57mm so how do i find out what the tire circumference is thanks
miamifanatic is offline   Reply With Quote
Old 02-27-2007, 12:59 PM   #2756
57 x 3.14
Steve Walter
Old 02-27-2007, 02:42 PM   #2757
thank you for the help also one more question if i go to run a 19t should i use the same roll out as the stock?
Old 02-27-2007, 02:55 PM   #2758
KD19T is normally the same or 1 tooth over a co27. Other 19T's are different.
Steve Walter
Old 03-07-2007, 01:05 PM   #2759
moony where do you find the silver and copper solutions. what type of solutions are they? i'm very interested in trying this on my motors and any additional help would be greatly appreciated. thanks
johnnyblade666 is offline   Reply With Quote
Old 03-11-2007, 12:48 AM   #2760
lignum vitae's Avatar
bmi racing website has some info on recopper armature electrolasis
lignum vitae is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
