Old 11-30-2001, 03:01 AM   #256
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I recently looked at the numbers of the P2K2 Pro's and I was not impressed. I don't recall what the numbers were exactly but know that things could have been better. My P2k Pro had better numbers from what I recall.
I am going to wait for that Orion Core to come out before I buy another stocker.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 11-30-2001, 03:05 AM   #257
Originally posted by wolfeman09
I just picked up a P2k2 Pro and here are the numbers.
RPM 32.214
Power 133.2W
Eft 70.2%
Torq 170Nmn
What do you all think? I have not had the time to try the motor yet.
Those numbers are decent and what I expect from a motor utilizing a new magnet type and can design. One other thing, are the brushes a bit wider? I could not use my brush serrator with the brushes that were provided with the motor.
V-Dezign 4.0
Old 11-30-2001, 07:56 AM   #258
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I think the stock brushes in the P2k2 are wider. I noticed the tighter fit in the brush hood. This was confirmed when I put in some Reedy 767's and Team 1 4140's. As for the pro version, I haven't had a chance to put my hands on one. I prefer to build the motors myself or let Team 1 do it, that way I know it is done correctly.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-30-2001, 08:20 AM   #259
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
me too.....
Matt M. is offline   Reply With Quote
Old 11-30-2001, 08:45 AM   #260
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
That motor is better than decent, if only the numbers were true
I also noticed the burshes are wider. I went to put them into my pro-match brush serrator, and they wouldn't fit! I had to file them down a little, to get them to fit. The older 4499s always fit...Must be something else to get what we don't need, revs!
Speedo is offline   Reply With Quote
Old 11-30-2001, 10:08 AM   #261
I wonder if Pro-Match will make a new base with a 'X' pattern groove to accomodate the wider stand-up and laydown brushes. I am not happy about having to conform to a new standard of brushes for the new Trinity motors.
I would not have filed the brush down to fit the channel in the serrator base. Turn the serrator upside down on the armature shaft and use the flat surface of the base and make a freehand cut for now. I will machine my base so it accepts the new brushes in the near future.
V-Dezign 4.0
Old 12-04-2001, 05:17 AM   #262
can anybody help me in how to gear the reedy rage? im using hpi pro 2 and im new in this hobby, thanks in advance
okidoki is offline   Reply With Quote
Old 12-04-2001, 07:21 AM   #263
I never used a Rage but would start at a 48 pitch 87 tooth spur and 28-34 pinions.
V-Dezign 4.0
Old 12-04-2001, 09:01 AM   #264
Okidoki,
If I remember right I ran the 35 t pinion on long flowing tracks but I had to go down to 32-33 t for tighter tracks with lots of tight turns. With the 35t the motor would get too hot on tight tracks.
Hope that helps.
Yorkie
Yorkie is offline   Reply With Quote
Old 12-04-2001, 10:54 AM   #265
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
You want to run the rage a couple of teeth down from a P2k Pro. On the TC3, i usually run my rage a 72/24-27.
Thanks for all the feedback on the my numbers for the p2k2pro. I took the motor with a person with a dyno and he freaked. He doesnt like Trinitys numbers and does his own thing. He said the motor is smoking. Lots of Torque and RPM.
wolfeman09 is offline   Reply With Quote
Old 12-04-2001, 05:34 PM   #266
thanks for the replies
Old 12-05-2001, 12:49 AM   #267
over gear's Avatar
anyone compared the Trinity GM3 and the Integy version GM3? The Integy is $10 bucks more.... is it really better?
over gear is offline   Reply With Quote
Old 12-05-2001, 11:41 PM   #268
Trader Rating: 69 (100%+)
any gearing tips for a gm3 on an mr4tc? ill be using a 78t 48p spur. the track has a long straight and sweeping curves. lap times are about 19+ sec for mod and 21-22+ sec for stock. thanks for any info!
marvi is offline   Reply With Quote
Old 12-05-2001, 11:49 PM   #269
Marvi start with a 28 tooth pinion. Monitor the temperature of the motor and change pinions and spurs based on the temp.
V-Dezign 4.0
Old 12-05-2001, 11:57 PM   #270
rccadet: thanks! luckily, i have a 28t pinion here. do you know what is the biggest pinion that will fit the mr4tc? right now, my spur gear choices are 75 and 78t. ill just experiment on our track. thanks again!
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
