Old 01-30-2007, 02:43 AM   #2641
As an addition to Colin's point above, he also tuned my motor. Apart from the fact Richmond and Elliott are better drivers and I was having a nightmare of a day, when Richmond came round to lap me and I held it together properly, my motor was definately on par peformance wise.
I was running an brand new EA ROAR, with purple/red springs and F-lines and I ran all 5 races without having to skim or re-brush. After the second final, I could still see the remnants of serrations on the negative brush. All I did between rounds was clean out with motor spray and use the hurricane motorsports red drops to re-lube. It was geared at 8.4 FDR.
I was running an MRT TSX on the lowest profile (1khz) and using the auto-roll on the top profile (20% power).
It was the first time I have ever gone through a 5 race meeting without having to skim or re-brush! I was well-chuffed
THancock is offline   Reply With Quote
Old 01-30-2007, 04:26 AM   #2642
stephen hilton's Avatar
Originally Posted by MR JOLLY
yes i checked & dubled checked with rich & elliot (knowing full well these speedo`s can burn things prematurly)
this was backed up by Nathan parker (they had he`s program)
both drivers had the same settings
anyway how did you manage to get a 11a motor!!!!
stephen hilton is offline   Reply With Quote
Old 01-30-2007, 08:01 AM   #2643
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Don`t know really
the batch of F-lines i have are all the same ,also that day 3-4 others had the brush`s & run with out any probs
so it was Elliots motor that was a bit concerning ,same motor checker ,same parameters i use & it was doing 11a + with ease
i`m yet to talk to Elliots dad as i was only there half a day for what else occured (it might be one of these advanced by 8 degree stocks that are out there
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 01-30-2007, 05:12 PM   #2644
Cristian Silva's Avatar
Hi everyone,
Got a problem with my stock motors I hope you could help me out to find the problem.
each motor I use, the shaft on the armature (pinion end) keeps creating a kink or wearing mark where the bushings sit.
Now I know its because of wear and tare of the bushing being distorted, which causes an awful sound to the motor.
Does this happen most of the time? as its happened to most of the motors Ive run.
Do I need to change the bushings more often or is their something els I can do to prevent the problem?
May this cause any radio interference and cause the car to steer erratically?
Any help much appreciated.
Team Xray Australia - HEI International ~ www.hobbyexpress.com.au - www.smaracing.org
Cristian Silva is offline   Reply With Quote
Old 01-30-2007, 09:55 PM   #2645
Trader Rating: 39 (100%+)
Default KOS
Has anyone used the Integy King of Stock motor w/Evo 30 endbell? Like? Dislike? Just wondering if there are any opinions on this. Thanks
Dragtruck is offline   Reply With Quote
Old 01-30-2007, 10:16 PM   #2646
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Originally Posted by Cristian Silva
Hi everyone,
You can add lubricant to the bushing to keep it from making noise. Also do this to a new motor as well. You can also take out the bushings and polish them to make them smoothe, and add the lube to it keep the bushing from drying out since they are suppose to be self lubricating. I am sure others can add to what I have said.
CarlosG. is offline   Reply With Quote
Old 01-30-2007, 11:34 PM   #2647
jgroenhof's Avatar
Default RE:problem with my stock motors
Are you buying the base level stock motors, or tuned motors? Even a Trinity "PRO" needs quite a bit of work.
I would do the following to most motors.
Chuck the arm into a dremel, polish the shaft with 1500 grit, and then 2000 grit. Follow with a metal polish (I use blue magic). Do to both ends.
I also put a Q-tip into the dremel and polish the bushings with metal polish.
Clean everything really, really well.
Finally, and probably most important. I center the arm in the motor, use teflon motor shims. It will not touch at either end when you finally get it right.
Oil liberally the pinion end before assembly, and a drop or two on the brush end.
Some motors (I buy Birdman) dont need any of this, except oil.
Johnny G
OCRC.
jgroenhof is offline   Reply With Quote
Old 01-31-2007, 01:18 AM   #2648
BigDaddyT's Avatar
Send a message via MSN to BigDaddyT
Hi everyone,
Those symptoms sound a bit like you may be setting your gear mesh too tight. Are you leaving a little bit of play in between the teeth? Too much pressure on the bushing will cause premature wear of both the bushing and the armature.
Grinding metal on metal contact like that could cause radio interference, although it wouldn't be the first thing I would guess.
T-Bang Hobby Technology Inc. - www.t-bang.ca
Extreme Performance RC Motors and Racing Supplies - Vancouver, Canada
Team Corally - Trinity - Dekelz.com
BigDaddyT is offline   Reply With Quote
Old 01-31-2007, 04:24 AM   #2649
Hi everyone,
also if your track allows it put bearings in as they wont wear.
hth
Old 02-01-2007, 06:48 PM   #2650
MEGAVOLTS's Avatar
Hello guys, In some recent posts some of you where talking about the f motor brush, Is that the fantom f brush that you are talking about or is there some other manufactuer that makes a better one? Thanks, AL
Remember, Every thing I post is just my opinion, But if you don't agree with it, You know where you can go.... LOL
Al Schwarze
MEGAVOLTS is offline   Reply With Quote
Old 02-01-2007, 06:50 PM   #2651
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i was told there was only one f brush but that's what i was told
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-01-2007, 06:59 PM   #2652
protc3's Avatar
the F brush is the finish line brush
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-01-2007, 07:41 PM   #2653
Default brush hacking
i just got a fantom dyno and it says to turn down the timming on the motor but it is a fixed end bell 24deg motor does anybody know abut brushacking to do that if so let me know how its done please thank you
jeremiahdenton is offline   Reply With Quote
Old 02-01-2007, 07:43 PM   #2654
Hello guys, im new in Rc hobby and im really enjoying it so far. I got myself a stock C027 motor and with it i played around using my MM motor master. Its so cool using the quick test with all the motor data showing up like RPM and AMP draw. Now i just wondered what is/are effects of the amp draw in a stock motor performance.
Changing brushes and springs gives me diferent readings on the RPM and AMP draw. How can i interpret its reading. hope someone an shed light on this matter for me. Thanks for your reply.
David
MiD CoRNeR is offline   Reply With Quote
Old 02-01-2007, 10:29 PM   #2655
MEGAVOLTS's Avatar
Thanks for the info on the f brush. I had seen them on left hander's site, but they didn't look like much, but I guess I'll look a little closer. Thanks, AL
Al Schwarze
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
