Old 01-14-2007, 04:38 PM   #2596
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Freewheelin4eva
Just wondering what benefit would narrowing the brush faces, give?
for example on big jim's site he sells these brushes.http://www.bigjimracing.com/pictures/140brushes.gif
would they give you higher rpm?
Narrowing the brush will take away overlap on the comm which will lower amp draw and drop RPM....but it will increase Torque by quite a bit and lower motor temps which will allow you to gear up. It works very good in some situations such as super high bite or really tight tracks.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-14-2007, 04:40 PM   #2597
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Originally Posted by Dasupacat1
Which brushes make the most power in order from highest to lowest? I heard it was the F brsuh.
F
766
4499
767
putnam green, blue?
Any others I forgot?
Its hard to give a solid answer to those questions however I will try,
The F's will produce the all around best combination of power/rpms, they are the brush used almost totally by the top stock drivers across the US.
The 4499s will in most cases produce a few more RPM's but give up to much power making the F's a better option.
The 767s will last longer but not provide the rpm or the power of the above brushes.
The putnams from my experience have an issue burning up and being good for more then 1 run, if your going to run them in a monster or a roar stock they are the combo to have however in the Co27's they are surpassed by the F brush.
Another nice thing about the F is that it is good for mroe then one run, I have been getting somewhere around 4 on mine and its accepted that they will be at their best on their 2nd run. Simply skim the com and re break in and your ready to go.
Kevin
Kave is offline   Reply With Quote
Old 01-14-2007, 09:43 PM   #2598
Still Bill's Avatar
I truly agree with Kevin's observations; however, I have had poor results using F brushes outdoors on hot days. Specifically, at the 2006 Asphalt Nationals (with 90F+ temps), my F brushes looked terrible after only one run. I had to revert to 767s to get the brushes to hold up for a couple runs.
Otherwise, the F brushes rock; and, I always look to EA's insight for how to best use them.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-14-2007, 09:52 PM   #2599
Still Bill's Avatar
About a month ago, I started using Checkpoint motor spray to clean the comms on my C027s. Pretty much think that their product is superior to anything I have used before. Does anyone know the difference between the various motor sprays out there?
Old 01-14-2007, 11:10 PM   #2600
jgroenhof's Avatar
Default motor spray
[QUOTE=Still Bill]About a month ago, I started using Checkpoint motor spray to clean the comms on my C027s. Pretty much think that their product is superior to anything I have used before. Does anyone know the difference between the various motor sprays out there?[/QUOTE
The only sprays I am familiar with are Motor Quench, and brake cleaner. The brake cleaner doesn't work. The quench seems fine, but goes too fast.
Are there any brands, or spray caps out there which still stream, but maybe a little smaller stream. I wouldn't mind dipping a motor into a jar of cleaner, but that stuff evaporates so damn quickly, I'm not sure that would be practical.
Johnny G
OCRC.
jgroenhof is offline   Reply With Quote
Old 01-14-2007, 11:23 PM   #2601
jgroenhof's Avatar
Angry Pitting on comm
Today, when tearing down and cleaning my motor I noticed quite a bit of pitting on the trailing edge of my comm slots. Generally the comm looked real good however. No burning and no groove. If not for the pitts it would have required just a skim.
Spring/brush wise It's 766 red-/+767 purple.
Any guesses?
Johnny G
OCRC.
Old 01-14-2007, 11:25 PM   #2602
Still Bill's Avatar
Any guesses?
What is the diameter of the comm?
Old 01-14-2007, 11:34 PM   #2603
jgroenhof's Avatar
About, yea big.
Kidding. Not sure how big, but i,ve done two races on it. (CO27) An initial skim after one run. A cut after about 6 runs, and another 6 or so runs. (Pitted)
It's pretty new, should just be starting to shine I'd say.
Johnny G
OCRC.
Old 01-14-2007, 11:40 PM   #2604
Still Bill's Avatar
About, yea big.
Could be the number of runs between cuts. I usually cut the C027 comms after 3-4 runs.
Or, is this on an outdoor track with a lot of grit flying around?
Just some guesses...
Old 01-14-2007, 11:57 PM   #2605
jgroenhof's Avatar
The track is real clean, it's indoor. No dust problem.
Probably just too many runs. I was wondering though if brush hood alignment plays a roll in comm wear, or is it just a performance issue.
BTW, Trinity CO27 "pro" is built so poorly that a beginner like me can vastly improve it's performance with only the most basic of tuning tricks.
Johnny G
OCRC.
Old 01-15-2007, 08:36 AM   #2606
Satish's Avatar
is it possible to change the bushings on a stock motor to bearlings?
I have the Co27 and was wondering if its possible
Satish is offline   Reply With Quote
Old 01-15-2007, 08:57 AM   #2607
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
fwik there's a can with bearings available from Trinity. check out their website.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-15-2007, 10:37 AM   #2608
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
EA - when you talk of narrowing the brushes - is that link to the picture the final result your talking about? Or are you talking about a different method/final result?
XMSRacing is offline   Reply With Quote
Old 01-15-2007, 11:42 AM   #2609
Company Representative
Team Kwik's Avatar
Send a message via AIM to Team Kwik Send a message via MSN to Team Kwik
I would have to agree with Bill, with a C027 running 6-cells and being sprung somewhat heavy you should be able to skim every 2-4 runs and not see the pitting. When you start putting more and more runs on a motor that's not true it sort of compounds the problem of wear and tends to cause more damage.
Let us know how it looks after a just few runs.
Nick
Team Kwik
http://www.teamkwik.com
Team Kwik is offline   Reply With Quote
Old 01-16-2007, 06:11 PM   #2610
hey guys can i have a brush spring combo for a co27?
its on medium to open aphsalt low grip.
btw whats a good starting ratio? finally is f brush still the brush to use?
cheers guys
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
