Old 11-13-2001, 03:03 PM   #211
Peter Busch's Avatar
R/C Tech Charter Subscriber
Thanks Speedo, why not 4.6 volts?
Peter Busch is offline   Reply With Quote
Old 11-13-2001, 05:28 PM   #212
Moderator
Cmotif's Avatar
Send a message via AIM to Cmotif
Default Prolong Oiler
I had one of those. I got it by buying a full prolong kit, that had the prolong oil treatment, gas treatment, a wd-40 type can of prolong, and a needle oiler.
I think that is the only way that you can get it.
Cmotif <><
International Racing Team Member #18
IRT Established: 1999
Everything About You -- Sanctus Real
www.dontblamejesus.com
Cmotif is offline   Reply With Quote
Old 11-13-2001, 06:55 PM   #213
Default comm drops
i have a p2k copper head pro motor and i just got formula 2000 comm drops. where do i put it and when. what are the benefits.
Gump0220 is offline   Reply With Quote
Old 11-13-2001, 08:15 PM   #214
Trader Rating: 69 (100%+)
rccadet: thanks!
rccarracer: i have the chrome rs stock and in my case, it suits a technical track. i run a gm3 on long tracks because it seems the chrome rs doesnt have enough speed on the straights. but i ran it on a shorter track and it's fast enough to keep up with other racers (the ones who pass me on the long track.)
marvi is offline   Reply With Quote
Old 11-13-2001, 08:19 PM   #215
Regional Moderator
daniz24's Avatar
Yes, Chrome Stock has alot of torque but less RPM
daniz24 is offline   Reply With Quote
Old 11-13-2001, 08:24 PM   #216
Regional Moderator
daniz24's Avatar
For long track I think Reedy Rage and Trinity GM3 works best
Old 11-13-2001, 10:17 PM   #217
Moderator
Speedo's Avatar
spongebob- it is just the most commonly used number, the standard, so you can compare numbers. I guess that's how it started, and it has stayed that way. It isn't much dufferent from 4.6 volts, so the difference is negligable.
Speedo is offline   Reply With Quote
Old 11-13-2001, 10:38 PM   #218
comm drops
Old 11-13-2001, 10:47 PM   #219
Trips's Avatar
Trader Rating: 16 (100%+)
Originally posted by Gump0220
comm drops
If you look at the endbell, you'll see an opening where you can see the copper commutator inside. Just put a drop on the commutator and rotate the motor back and forth by hand a bit to spread it. Another way is to remove the brushes and put one drop on each brush then reinstall, but it's not necessary to go to the trouble.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 11-18-2001, 12:50 PM   #220
Moderator
Speedo's Avatar
Got my P2K2 pro yesterday. Amazingly the hoods were perfectly aligned, so I just skimmed the comm and broke it it. Also had to play with the shimming a little. Put it on the robotronic, and it came out 128 max power, with 107 in the 20-30 amp range. Compared to my best P2K at 130 max and 111, that is pretty good. Spin up time is about 2 or 3 hundreths off what a P2K is, that is due to the torque. On torque, this motor looks like a GM3, and I can not get the torque up. It doesn't feel as punchy as the P2K. I geared it two teeth lower, in 56 pitch than my P2K, as per my dyno's instuction.
Have just re-serrated the brushes, and cut the comm again, so I'll try it out on the dyno later today.
Speedo
Old 11-19-2001, 01:30 PM   #221
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
speedo, what brushes-springs are you useing????i have green springs and team one 4140 brushes(like 767)
Matt M. is offline   Reply With Quote
Old 11-19-2001, 04:41 PM   #222
Moderator
Speedo's Avatar
I got the pro model, so it came with 4499s. I kept those on there, cause I know they are good. Also have the standard red/green springs. I tried red/red, but it showed no advantage. I plan on trying either some 766s or 767s next.
Old 11-19-2001, 09:41 PM   #223
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I like the 767's and purple springs. My FDR was a 5.51 and the motor temperature was 134 degrees so I could have gone up two more teeth. The P2k's are fast so I can only expect the P2k2 to be much faster.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 11-19-2001, 10:14 PM   #224
Moderator
Speedo's Avatar
Geez! I was thinking of purple springs, I might have to try that...5.51? I would be scared to go below 7.5, I don't know if I can get pinions that big
Old 11-20-2001, 10:32 PM   #225
badboy's Avatar
Trader Rating: 14 (100%+)
guys,
i have a gm3 motor and it has lots of play on it. i tried putting in 5 shims already and it still has lots of play. can you help me out on what to put in so the the play will stop? thanks!!!
badboy is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
