Old 11-14-2005, 03:34 PM   #2176
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Monster with Red on Neg and Purple on Positive with 767's (use a fiddlestick)
Remember to break in brushes with same tension on each side and no fan.
dgullickson is offline   Reply With Quote
Old 11-14-2005, 03:55 PM   #2177
jw92656's Avatar
Thumbs up
Monster w/ same combo. Purple +, and Red -. But I am using 769 brushes. Have had decent success with it.
jw92656 is offline   Reply With Quote
Old 11-14-2005, 04:43 PM   #2178
Monster with either putnam green brushes or 767's and I rate my own springs I don't go by color, I go by tension,more accurate and consistent.
Hyper1 is offline   Reply With Quote
Old 11-14-2005, 04:57 PM   #2179
trx1's Avatar
Send a message via Yahoo to trx1
Arrow
What would be a good bashing motor for my b3,geared 21/87
trx1 is offline   Reply With Quote
Old 11-14-2005, 05:21 PM   #2180
P2K or P2K2
Old 11-15-2005, 06:38 AM   #2181
diha's Avatar
Default Sotck motor spring???
Hi all,
I am quite new to this hobby & would appreciate if someone can help answer my questions.
1) How do you guys define the spring used? by the angle?
2) Do yous guys normally put the stronger spring on the "+" / "-" side?
Thanks in advance for the help.
diha is offline   Reply With Quote
Old 11-15-2005, 08:01 AM   #2182
Usually by color for most (Trinity Springs) e.g. Blue,Green, Red and Purple
Some use a Fiddle stick to determine spring tension and to better match whats going on a motor.
Stronger is typically on the + side
Old 11-15-2005, 08:11 AM   #2183
Most go by color for Springs choices but if you do that you will need to stay with the same manufactor as they are all diffrent,which is why I rate my own with my integy spring checker,I use to use a fiddle stick but it was to inconsistent.
The stronger spring goes on the positive side of the motor.One thing that will be throwing people a loop now is the new batch of batteries require you to detune the motors a black art in itself.
Old 11-15-2005, 07:42 PM   #2184
bvoltz's Avatar
Trader Rating: 44 (100%+)
I prefer the following:
Stock only for me... I just started in the sport in July if this year.
off road - Truck - P2K pro, purple all the way around, 767 brushes. Ream out the bushings, for greater RPM, with 3 sec and comm drops. Batteries: 2400, getting killed out of the corner, going to try 3000 this weekend. But I also have to gear 2 more on the pinion then others to get the heat up in the motor. With this setup, when I come off the track the motor is 120, with outside temp is 78. Yes I have one of the fastest trucks on the track, with a completely stock setup RTR truck. Running 20 on the pinion, others are running between 16 and 18, with the same motor.
On road - Monster, purple all the way around, 767 brushes, Ream out the bushings, same as above. SMC IB3600. To new to this to say if this works or not..
Remember our tracks are short
bvoltz is offline   Reply With Quote
Old 11-16-2005, 02:57 AM   #2185
NOZ69's Avatar
Could you please elaborate on the DETUNING as i think i`m having some issues with my Monster stock & 1.85v IB3800`s....running purple "+" & red "-" with slotted "F" brushes.
Any help would be greatly appreciated
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 11-16-2005, 06:48 AM   #2186
zax
zax's Avatar
zax is offline   Reply With Quote
Old 11-16-2005, 07:18 AM   #2187
Originally Posted by zax
turn the endbell clockwise or anti clockwise to increase the timing when the endbell is facing up and motor can is facing down..?
Negative we're talking about stock motors here, you need to get the amp draw down,try taking abut .010 off the leading edge of the brush or try some less aggresive brushes with lighter springs.we're also talking about 4 cell oval here,just so you know.
Old 11-16-2005, 07:22 AM   #2188
zax
zax's Avatar
sure!!!
sure!!!
sure!!!
sure!!!
sure!!!
Old 11-16-2005, 07:52 AM   #2189
teamgp's Avatar
I use the Reedy 769's (767 compound with hole drilled in the center of the brush face) on all my motors. It is enough to reduce the amp draw and work well with the IB3800's for some motors. But sometimes I have to sand/cut off the leading edge as well.
Springs:
+ Trinity purple springs measured around 255 to265 on the Integy Spring Dyno
- Trinity red springs measured around 235 to 245 on the Integy Spring Dyno
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 11-16-2005, 08:00 AM   #2190
Still Bill's Avatar
Good posts to ponder.
Thanks teamgp and Hyper1.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
