Old 07-17-2005, 08:35 AM   #2101
berger's Avatar
R/C Tech Charter Subscriber
Originally Posted by BlackKat
OD, I hear your a great racer and very smart: YOU MIND SHOWING IT?
I can "kill" a stock motor in about a month of practice days (once-twice a week, 8 or so packs a day....all I do lately because the summer "death" of carpet) pull it out of the package, run it without any attention until it quits or slows down dramatically. I've run a stock motor with bearings on practice days for a month, pulled it apart and the comm looked great and it ran real good
I encourage anyone who bashes or who's track doesn't care (ask the race director first) to pop some bearings in to their stock motor. It really helps against comm wear. I did this for my practice motor when I raced Expert Stock (trying to break into 19t now)
To get them: Just ask for motor bearings at the LHS or search online (Tower, Stormer, eBay)
I doubt it makes any difference at all, if anything the motor would spool up a tiny bit quicker due to less resistance i think, but its so tiny it isnt noticable. I have bearings in half my stocks (legal for a series over here) and i cant tell the difference between the ones that do and ones that dont. But im cutting the comm every run, i would think you could do a meeting with one set of brushes and then cut it when you get home. But when i go racing i want to be as fast as i can, so if i have the time and equipment which i do, why shouldnt i cut every run, nothing to be lost by doing it, and performance gains!
berger is offline   Reply With Quote
Old 07-18-2005, 12:48 AM   #2102
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Here is some info i found on the Kawada GT 27t Motor
27 turn classes where popularity is spreading with race/lace of the recent every place.
It is appearance of the GT stock motor which is optimum to the 27 turn classes.
It selects 3 millimeter core 3 hole type which has established reputation with this corporation M11238 VT stock motor which is proud of preponderant popularity in 23 turn classes in the rotor!
Being to be the cooling fan attachment, it is superior even in heat dissipation characteristic.
Of course the DSE connector of brush stand one somatotype and electrification characteristic * maintenance characteristic are preeminent with standard equipment.
Race/lace and the real ワンメイクスレース which the inside of the companion just a little does are optimum as a motor for practice of course.
* Rotor
The 3mm core 3 hole (the cooling fan you attach)
* Brush
High power brush (M1B-01)
Stand rise
* Motor can
Chrome plating
DSE connector standard equipment (only female)
vi3tishduy is offline   Reply With Quote
Old 07-18-2005, 01:11 AM   #2103
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
* Rotor
* Brush
Stand rise
* Motor can
Chrome plating
This motor can't hold a stick to any of the 27T Stocks that are in the states... it just doesn"t have the RPM... it needs to be geared to the moon to get anything out of it..... But it does have quite a bit of torque
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-18-2005, 04:54 AM   #2104
pink pac man's Avatar
ok i just raced a titles and got my ass handed to me...... i know my motor tuning was the problem....
will getting this stuff help aid my situation?
:a new brca monstor pro stock motor
:an assortment of motor springs [ive always used the std springs]
:a hood alighnment tool
:a comm stick
:some spare bushings[thats if this will help]
:a larger assortment of brushes
:cutting the comm after every run [i useually do it after ever 8 runs]
pink pac man is offline   Reply With Quote
Old 07-18-2005, 08:01 AM   #2105
Still Bill's Avatar
Pink,
Those are some of the standard items I have in my box.
Using Reedy 767 brushes, I cut my comms at about 4 runs AND replace the brushes too. In most cases, I do the cutting of the comm to before the last qualifier of the race. Otherwise, depending on the importance of the race, I may do a light cut on the comm whenever it appears to need it.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-18-2005, 08:31 AM   #2106
diha's Avatar
Default HPI stock motor
Hi
Does anyone tried the HPI R2 stock motors?
Which one to recommend?
SS, SL, TS or TL?
diha is offline   Reply With Quote
Old 08-01-2005, 09:02 PM   #2107
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Guys I am not sure what do do at this point with my stock motor. I bought it new and "pro-tuned" from a reliable tuner nearby (Go Lightspeed!!) and have been running it in my TC4 for about 20-30 runs. Some 5 min racing, some 5 min practice runs, but all in the tc4. I have pulled it apart after every four runs, cleaned the com using q-tips and motor cleaner and then polished/cleaned it with the green comm stick. I have never gotten motor spray on the brushes, and they're not burnt. I have been gearing on the conservative side and my motor can temps around 170 after a five min run. I have the dual fan set-up that blows on the end bell so the endbell comes off the track around 135. I also run a motor spray saturated q-tip through the brush hoods after every four runs and lube the bushings (royal oil) after those four runs, sometimes two. I figured the comm was badly due for a cut, so I took some pre and post diameters from the comm. I was getting a very consistant .294" and .293" all the way around, and top to bottom. So I cut it, just shaving as little as I could to get it all the same color. I checked again and got .293" everywhere. OK, enought nerd data. I have the EXACT same set of brushes in this motor it came with. The serrations are gone, but they're not short by any means. What do I do now?
A. Run the motor at low volts for 300 secs to seat the old brushes to the new comm surface
B. Suck it up and spend money on new brushes and seat them at low volts for 300 sec.
C. Something else
Consider that the race immediately preceding teh comm cut I ran my best and fastest racve ever and won the rookie stock a-main in my club race. I mention this to highlight that I am looking for an economical way to keep it in at least as good condition as it was right before I cut teh comm. I mean, c'mon; I race rookie. I dont need a screamer, just a reliable motor. I'd rather spend the $$ on practice fees to get better
WHew!! What a book!!
Thanks for any and all comments
Andrew Doherty
Old 08-01-2005, 09:09 PM   #2108
Still Bill's Avatar
When serrations are gone, so are my brushes...
To keep costs down, I buy 100 sets of 767 brushes for $100-130. Share the initial cost with 1-2 other racer buddies and reap the benefits.
Old 08-01-2005, 10:04 PM   #2109
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
C. Something else
Andrew Doherty
reuse your brushes, just be sure that you're running them at the same direction you did before......
break the brushes in for about 1 minutes at 2 volts jsut to get them sitting well on the fresh comm......
you can use them till they get half lenght, as long as you keep the spring tension, so you have to increase spring tension as the brushes get shorter.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 08-02-2005, 12:10 AM   #2110
danjoy25's Avatar
Trader Rating: 37 (100%+)
Just got a tuned Monster based motor with a dyno printout that says:
Contant Volt 7.00
RPM TORQ WATT EF AMPS
25621 3.6 69 65 15.0
24399 4.8 86 68 18.0
23243 5.3 92 65 20.1
22417 6.2 103 66 22.1
21103 7.4 116 65 25.1
19908 8.4 123 63 27.8
Does anyone know what this means?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 08-02-2005, 04:31 AM   #2111
Thats a printout from a turbo dyno.....what most (including myself) consider to be the best load dyno......for a stock motor in 6 cell touring some of the most important numbers are the watt readings at the 20amp and 28amp load .....It's really impossible to compare dyno numbers for someone to tell you your readings are really great, or just average, It takes the owner of that particular dyno that your printout came from...knowing what a "track proven" really good (Monster) motor reads on his same dyno...and then comparing the two......but if I had to guess, I'd say it's not a bad motor at all....but the track is always your best indicator without owning the dyno
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 08-02-2005, 03:16 PM   #2112
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Practice stock motors for sale ;)
hey guys.. got 6 stock motors (2 epic and 4 monster pro) for sale in the for sale thread. or check out my signature. thanks!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-03-2005, 12:05 PM   #2113
BritRacer's Avatar
Hey andrew, its Andrew
You dont actually mention what stock motor this Lightspeed is based on.
I assume its the monster as this is the higher rpm motor.
If you want more rpm, and are sure you can lose some torque, you can try moving to softer springs.
You say you are gearing on the conservative side, try going up one tooth.
BritRacer is offline   Reply With Quote
Old 08-03-2005, 12:30 PM   #2114
I dont know 100% but I dont think its a monster because it doesn't have that weird green can color. I have a sneaking suspicion that its a binary because the letters BSLM are hand etched into the can. I am guessing this is lightspeeds way of identifying it as a Binary Stock Lightspeed Motor. Could be wrong. I think Im gunna keep the brushes that are in it. Ill break them to the new comm, and then if I I start posting slower times, Ill buy new brushes, cut the comm again, and break those in. Andrew you know where I am in comparison to the guys at Mikes so you know I wont notice a subtle difference in performance. PM me with your ph # if you want and Ill get you mine
Andrew
Old 08-03-2005, 02:49 PM   #2115
stegger's Avatar
Anybody tell me the correct way to breakin a monster stock motor, The right brushers and springs to use, how frequent to change them and when to skim the com. I will be running it indoors on a carpet track on a medium sized track???????
stegger is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
